Question about Carrier Weathermaker 8000 Gas Furnace 125k Btu
Thermostat doesn't activate unit
The thermostat stopped working so I replaced the thermostat being careful to follow the wiring diagram. But still the unit doesn't go on.
  • Carrier Master
  • 9,742 Answers
Put a volt meter on the red wire and the C terminal. You should get 24 volts AC. If not then the control transformer is shot
Posted on Jan 29, 2014
My fuel guage doesn't work
you don't, it either works or does'nt, check all grounds, put power to it (12) volts, sending units are very delicate, care must be taken when replacing, in tank, . a wire diagram would show you the power wire, the ground wire, etc., maybe you can check it ?
Mar 06, 2013 | 1981 Chevrolet Corvette
Fan on paslode does not work after cleaning
It is activated by the micro switch near the top of the tool. It is pushed on by a metal arm with a roller at the end of it. Now I am going to assume the fan is plugged in at the motor and the ground wire is installed. If so you can partially disassemble the tool and CAREFULLY, keep fingers away from the fan, manually activate the little switch to see if the fan works. If it doesn't then either the fan motor went bad or it is a bad micro switch which is part of the circuit board. To see if it's a motor or board you can test for DC voltage with a basic multimeter at the wiring plug where it goes into the fan. If there is voltage (compared to what the battery has for a charge) to the motor then and it doesn't work then that is most likely bad.
If the fan works when depressing the micro switch then check the items to activate it. A model number always helps as then I can bring up a parts diagram which makes it easier to explain.
Jul 01, 2012 | Air Tools & Compressors
I have a domentic rm2652 rv refrigerator/freezer. the unit was working but now it won't work. The power light doesn't come on and it won't work on gas or electric.
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS____
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Most overlooked dryer energy saving problem EVER!
http://www.fixya.com/support/r5739846-most_overlooked_dryer_energy_savingr
REF THERMOMETERS TIPS
http://www.fixya.com/support/r10177561-second_biggest_refrigerator_energy
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Sep 23, 2011 | Dometic RM2652 Refrigerator
Model ss5410 top and bottom not cold just purchase unit
NOTE: This
Leo Ponder
Sep 18, 2011 | Fisher and Paykel Fisher Paykel E522BLM...
I stopped using my tender three weeks before moving. I switched it off and then switched in on in the new house and the display blinks, and the unit doesn't cool. The fan seems to work on low but...
NOTE: This
Leo Ponder
Sep 10, 2011 | Krups BeerTender B95 Beverage Dispenser
I have a Samsung top refrigerator and bottom freezer. Two weeks ago the freezer stopped working and last night the refrigerator stopped. They both stopped suddenly. I have unplugged the unit for about 8...
NOTE: This
If this doesn't work Do this
That is probably the compressor relay
The relay is on the compressor and needs replaced
Leo Ponder
Aug 17, 2011 | Refrigerators
Installed a new Filtrete thermostat on a new Carrier high-efficiency furnace. I followed instructions exactly. It doesn't work. What did I do wrong? Furnace was installed in December. Broom handle...
Hi smargyle,
Welcome to fixya!
I can provide you with diagrams for the old Carrier therm and for the new Filtrete therm. But, I would need to know what the model numbers are for each therm plus how many speeds AC you have.
Please reply back with that information and we will get your AC back in working order.
Thanks,
Handie Andie
Jul 22, 2011 | Heating & Cooling
I'm trying hook up an aftermarket car stereo and i cant figure out where to hook the orange and orange/orange and white wire. I need the factory wire diagram
http://i267.photobucket.com/albums/ii320/RonJ_HCF/picture_2980.jpg
The picture says it is for 1999-2000 models, but also works for 1998.
Honda does not have orange wires, i checked a Pioneer and it doesn't either. Could it be that the yellow wires look orangeish?
Be careful, because many aftermarket units have 3 power wires: Unswitched (memory cable), switched (power cable) and dimmed (match the dashboard illumination intensity). Also, most aftermarket units have a power out, to activate the power antenna. Connecting this cable in the wrong position will probably lead to a serious short.
Jul 03, 2011 | 1998 Honda Accord
Dryer runs but doesn't heat I have a Roper RES7646KQ2, l have replaced the following parts: 1-Thermostat 2-Thermal cut off kit which replaces (hi limit and Thermostat 3-Heating Element Still...
If I remember correctly, this model has a switch on the motor which activates both legs
of the 220 to allow the heating element to come on. There is a wiring diagram under the
lid of the dryer and should show this. Hope this helps.
Jun 21, 2011 | Dryers
NO DISPLAY ON UNIT
Pull your display off wall and see if your unit has batteries. If you have a blue wire or, a wire connected to the "B" terminal in your thermostat(the part connected to wall, this should produce the power to show display. If you do not have a blue wire, it is dependant on the batteries for display. Change out batteries and see what happens. Obviously with no display, your system won't work. If this doesn't solve your problem, replace the thermostat.
Apr 26, 2011 | White Rodgers White-Rodgers 1F85RF-275...
Carrier Weathermaker 8000 Gas Furnace 125k Btu Logo
106 people viewed this question
Top Carrier Air Tools & Compressors Experts
Tom Chichester
ray gallant
Are you a Carrier Air Tool and Compressor Expert? Answer questions, earn points and help others
