Question about Husqvarna Garden
Chainsaw won't start
My chainsaw stopped working right after I finished cutting up some wood some time ago. When I tried several times to restart it didn't. As I had finished the job I put it aside and only took it out the other day, hoping for it to work. But it didn't.
I have dismantled and checked the carburetor, the exhaust muffler is not blocked, the fuel intake filter in the tank is clean but there does not seem to be any ignition regardless of what I do including pouring a small amount of petrol straight into the air intake and also into the cylinder through the plug hole. I would have thought that I'd get some ignition even it would splutter and not keep running.
With the spark plug removed and held to the engine body there is a spark. Would it be that if the ignition module was faulty, eg a shorted turn in the coil etc, it would not produce a spark when the plug is in the cylinder under pressure.
Has anyone some experience or comments on that. I have no means of testing the coil and I am reluctant to get a replacement ignition module, at the price they charge for it in our part of the world and then find that it didn't fix the problem. It's cheaper to buy a new chainsaw.
Your help would be appreciated,
Steve
  • steve556 Jan 29, 2009
    Hi dspear99ca,
    Thank you very much for your comments. I never thought of doing the compression test. I have now measured the the compression and it was down a bit, around 65-70psi. With some oil in the cylinder it now gets up to 100+ psi. I am now going to do the rings (or the ring, I think there is only one in those engines. I will also do the carbie overhaul, I think it's been some years since I replaced the gaskets, but I have dismantled the carbie and blown out the passages several times since.then.
    I wonder when doing the rings, if I need to replace the piston as well? I recall in my young days replacing rings in my then old cars but don't recall having to replace any pistons.
    Anyway I will order the parts in the next few days, in our part of the world it is not that easy to get parts for old stuff like this and it always takes a long while.
    Once again your comments are much appreciated and I will post the results when all gets done.
    Kind regards
    Steve
Not an uncommon problem at all. The orifices in the carbuerator body on chainsaws are TINY. They easily get plugged. Also, the gaskets and jet require periodic replacement. You can get a kit to rebuild the carb which consists of the gasket on the fuel entry side, diaphrahm and gasket on the opposite side, a fuel screen, and a new needle jet (and sometimes spring). I don't know why, but these gaskets need periodic replacement... they just do. Also, if the spark plug is old or has a build-up of carbon on it you won't get a hot enough spark. Replace the spark plug, blow out all the air passages in the carb body with compressed (canned) air, and do the carb kit and there's a very very good chance the saw will run fine. If you have a compression tester check that first as there's no point in doing the carb if the compression is inadequate... if compression is down (<80psi) pour a little 90W gear oil in the cylinder through the spark plug hole and try again. If it's good compression with the oil in the cylidner your rings are shot. Bear in mind it may need to be tuned. Start with the idle jet turned out maybe 2 turns and the high jet about the same.
Posted on Jan 26, 2009
  • dspear99ca Jan 29, 2009
    Hi Steve:
    there are more than one ring, otherwise the piston would bind in the cylinder, generally there are 3 rings. It sounds like the saw is just tired.
    Oh, and there's no need to replace the piston. You can carefully take off the carbon build-up off the top with fine emery cloth.
When go to cut engine is runnig but chain stops when touch the tree
Hi Pam:
Using chain saws takes a bit of getting used to, and it can be DANGEROUS.
- The chain must be sharp to be able to cut properly, and a sharp chain "bites" into the wood.
- Before you touch the chain into the wood, you have to speed up the engine. This takes some getting used to.
- Try this technique: With the chain about an inch above where you want to cut, squeeze the throttle about half way so the chain is spinning. Touch the chain to the wood and increase the engine speed as the chain starts to cut. The harder you cut, the more power you need to apply.
After a while it gets to be second nature.
Work Safe, and get an experienced friend to help with some "hands on" coaching.
Cheers.
Nov 26, 2015 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Ryobi pcn 4040 chainsaw won't start What is the
1st add fuel/oil mix to fuel tank , then top off oil tank with bar oil , place saw down on flat surface , press 'ON" button above trigger handle to ON (its marked on case) then pull out blue choke handle till it clicks and stays out , press primer bulb with thumb 8 to 10 times bulb will become harder to press as it fills carb , push chain brake forward (on) ` place left hand on top of saw and right hand on start cord , hold saw down firmly and pull cord vigorsly several times till it sort of starts (sound) , squeeze trigger in and pull cord once more , saw should take off running , chain wont move ,walk to wood pile then disengage the chain brake and cut wood , if saw fails to start after this procedure then there must be a fault in saw , consult a exp small engine dealer for repairs
Sep 01, 2013 | Ryobi 18-inch Electric Chainsaw Chain Saws
Chain stops when offered to the wood to cut
either a bad clutch or a bad gear in the drive head
Aug 19, 2012 | Bosch AKE 35 SDS Electric Chainsaw
Poulan Pro PP3816AV does not start
try and run it without the muffler there is a screen inside that plugs up if ok with the muffler off open it up and clean the screen off
Jul 06, 2012 | Poulan Pro PP3816AV 38 Cc 16" Anti - Vib...
Chainsaw won't start. Has spark, has fuel, chain
It starts but won't stop when switched off by stop button it's a husky55
Apr 04, 2012 | Homelite Garden
Chainsaw runs 1 minute then suddenly stops. Won't restart until cooled down. Cleaned carb & fuel pick-up also changed plug.
A number of reasons for this, poor quaility fuel causing vapour lock, over heating due to starter cover vents blocked,cylinder fins clogged, running too lean on the carb mixture settings, fuel tank breather clogged ( slacken off fuel cap when it starts to die, if it picks up again, replace tank breather, or ignition unit breaking down when hot ( only cure is to replace the unit )
Oct 11, 2011 | Garden
OTEL1HOW TO TYPE
Hi abhotel1...
If I got your question right
1...How to oil the chain and bar...if it does not come with an auto oiler then fill a hand pump oil gun with "Bar and Chail" specially made for chainsaw bars and chains and oil the chain and bar with it while you cut your wood...give it a squirt of oil about every two minutes of cutting, adjust the lenght of time if you need to
2...type of oil...Bar and chain Oil
Please take time to rate me thumbs up
Sep 13, 2011 | Garden
Have an old Home Lite chainsaw not used since before I had it running when I had some woods to cut a long time ago. The chainsaw (over 25 years old) won''t start when I try....not sure if it just needs a...
Replace the fuel filter, fuel lines, primer button (if equipped), and disassemble the carburetor, clean, and re-kit. Jet needles are preset at 1-1/2 turns CCW from stops (lightly). Make sure the spark plug fires a snappy blue spark when pulled through. If nothing, ignition parts prices and availability may justify replacing the saw with a new one. If sparks ok, start the engine and let warm up. Open the throttle and adjust H needle CW till the engine speeds up, but still 4-strokes. Proper setting is when the engine will 4-stroke, but immediately 2-stroke when cutting. Let the engine idle and adjust L CW so that the engine idles fairly well, but allows the engine to 'follow the throttle' Hope this helps!
Apr 17, 2010 | Garden
CHAIN SAW QUITS CUTTING AS IT HITS WOOD.
The make, model, and occationally the serial number help us solve your problem.
Does the engine quit running? (Carburator needs adjustment)
Or does it continue running and chain stops? (need clutch refaced or replaced.) (to aggressive a chain for the size of the engine)
I think you replaced parts unnecessarily. Maybe quicker and cheaper to visit your friendly neighborhood chainsaw shop. A good one can repair it even if they do not sell your brand.
HTH
Lou
Sep 09, 2009 | Homelite Garden
Stihl chainsaw
I have a stihl ms 180 that leaks bar oil all the time
Aug 31, 2008 | Makita DCS6401 20 20",64cc Chainsaw 2...
Garden Logo
226 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
