Question about Casio Exilim Card EX-S600 Digital Camera
Casio EX-S600 The answer may be right in front of my eyes but, I wanted to know if there was some automatic lighting for this camera aside from the Flash that is accessible when in a dim lighted enviroment. I was out for dinner & wanted to take pictures with my camera and the lighting in the place was very dim and when I focused my camera I could not see on the screen the people I was trying to take the picture, it was only after the picture was taken because of the flash that I was able to see what the people looked like.
  • 374 Answers
Try out your "Best Shot" modes and see if you have a high sensitivity mode on that model. It works great for low lit areas. Other than that there isn't any kind of "auto light" that I know of on that model.
Posted on Jul 14, 2007
SOURCE:
Why does "raise the flash" come on the screen when I turn my coolpix s5090 camera?
I do not know allot about the s5090, but I can give you general information based on how most Nikon pocket cameras are designed to work. If the Nikon is set to one of the automatic modes it is designed to prevent you from taking a picture if it senses that there is insufficient light to get a properly exposed picture. The camera may be telling you to rase the flash because it needs more light. Also, somewhere on your camera there is probably a menu that allows you to choose the flash mode. It may be in your regular menus or, if your camera has a round left-righ-up-down switch on the back, you can select the flash mode by pushing up and then using the right-left keys to choose the flash mode. The mode you select is locked in when you push the button in the center. In general, the modes are automatic (the camera decides when flash is needed), red eye reduction (the flash activates twice; once to cause your subjects eye's iris to close and the second to take the picture), flash always (flashes regardless of the ambient light) and flash off.
Jul 12, 2014 | Nikon COOLPIX Cameras
I have olympus fe 4010 camera and I can't take a picture when flash on. Any idea to slove it?
Although it is difficult to understand what you mean, I will try to help you.
The camera does not know a setting with flash on. The options you have is flash auto, red eye, fill in and flash off.
So if you want to use the flash, chose flash auto, or fill in. When you are in a dark room, and making portraits, us the option red eyes. When you have the camera to full auto, you don't need to worry about the flash, because when the camera thinks there is not enough light it will flash automatically. When you chose flash off, and it is too dark the camera can't focus and can't shoot a picture.
Jun 08, 2014 | Cameras
Hello! I have problems with my flash. Untill yesterday, when I take photos they make multiple light on exposure objects, but not anymore. Now, wheni I turn on automatically flash sometimes it not working,...
Perhaps you only changed the settings. As long as you are on automatic, and don't force the flash off, the flash should work when needed.
The multiple flash you mention, is the flash used to avoid red eyes.
With the first flash(es) the eye closes the pupil, so ref;action of the retina is minimal.
Sometimes the camera also uses the returning flash light to fine tune the focus, if on auto focus.
Just check if the camera is in the setting you always used. Just check if you have the best results with this setting.
Mar 09, 2014 | Sony Cyber-shot DSC-W130 Digital Camera
How do i turn the flash off
Welcome to FixYa.
The FORCED OFF mode is the setting where flash is not activated in any recording condition. this mode used when taking pictures in places where the use of the flash is not permitted.
There are other 5 different mode/setting in using photo flash.
1. AUTO - flash automatically activated according to the recording condition.
2. AUTO/Red-eye reduction - flash is automatically activated according to the recording condition. It reduces the red-eye phenomenon by triggering the flash before actually recording the picture. After that, the flash is activated for actual recording again.
3. FORCED ON - use the when your subject is back-lit or under fluorescent light.
4. FORCED ON/Red-eye reduction - use this when you set the camera to PARTY MODE
5. Slow sync./Red-eye reduction - use this when you take pictures of people in front of a dark background.
I hope this solution will help you. Just send us you comments or suggestion if this solution was helpful.
Thank you for using FixYa.
Apr 08, 2011 | Panasonic Lumix DMC-FX8 Digital Camera
I have a Nikon Speedlight SB-800. Before I take a picture from my Nikon D70 the flash will click about four times while there are spurts of light coming out of the bulb then the picture will take. Never...
The pre=flashes are for reduction of red eye and also for TTL indormation for camera to wotk properly with flash. Read Flash manual and some info in camera manual
Jan 10, 2011 | Nikon Speedlight SB-800 TTL Flash
Flash on camera not working lg viewty
hi, even i have the same problem, probably i don't think the flash doesn't work, but even i didn't know how to use it. however, the instruction manual says there are 3 options in flash, they are auto- that is it turns flash automatically on when it turns on. red eye reduction that is it says it will flash twice to reduce red eye but i never see the flash on and the flash off, that is it will not turn on and usually whenever you exit the camera the flash will default to turn off mode. you will need to switch the flash back. hope you understand.
Jan 20, 2010 | LG KU990 Viewty
How do I remove the double flash from Vivitar 8025?
on some cameras (like sony) there is a very fast double flash .. you see only one .. the first sets up the shot the second takes the picture ... its not likely that your vivitar has this feature so i am thinking that your "noticable" double flash is caused by "red eye reduction" being turned on .. on my vivitar (dc8600) the flash mode including red eye reduction is selected by the 4 way switch .. by pressing the right tilt you can cycle thru all the flash modes ... that includes no flash, forced flash, automatic flash and red eye reduction..maybe other modes as well .. the flash is in fully automatic mode when no sysbol appears on the screen .. thats probably where you want to be ... that will flash only once per shot and only when needed .. ..
Jul 25, 2009 | Cameras
Nikon D50 : how do I ensure the flash will fire on day shots?
Auto mode only allows for "Auto Flash", "Auto Flash with red eye" or "Forced Flash Off". Forced, flash "ON" does not exist in Auto.
Put it into "P" for programmable mode. Then press the flash button on the left-face. The flash will pop-up. While holding the button, turn the selector dial to select what you want the flash to do - the little flash icons will display on the top panel as you do this.
Cheers.
Jun 08, 2009 | Nikon D50 Digital Camera
Can't turn the flash off
Hi The product you have given has Built-in flash with Auto, Forced on, Red-eye on, and forced off (Red-eye reduction On or Off).
There is a 1 1/8" diameter lens with a built-in lens cover that automatically opens and closes when the on/off button is pressed. Above the lens is the viewfinder window, flash and tiny (almost unnoticeable) microphone. There is also a small circle that has three functions: the autofocus assist beam, red-eye reduction lamp, self-timer lamp. A wrist strap comes with the camera and attaches through a slot on the front of the camera near the side.
To the right of those buttons is the four-way controller, used for menu navigation as well as:
  • Up - Metering (Evaluative, center-weighted, spot)
  • Down - Drive (Single-shot, continuous, self-timer)
  • Left - Focus (Auto, macro, infinity)
  • Right - Flash (Auto w/redeye reduction, auto, flash on w/redeye reduction, flash on, flash off)
Dec 28, 2008 | Canon PowerShot A400 Digital Camera
Red eye
RED EYE is caused by the sudden flash from your camera and the eyes reflex reaction to the sudden light. So what the red eye reduction does is to double flash to counter the reaction. You can try adding an external light source to to your subject. in addition to the following procedures for your camera in the manual, the indicator location on page 64 Flash On Flash Off Red-eye reduction C REC modes on page 52, Snapshot; pg 64, have the flash fire automatically when required (Auto Flash) * Turn off the flash ... recording with flash, reducing the chance of red-eye in the image (Red- eye reduction) In this case, the flash fires automatically; Also, be aware of the following: The approximate effective range of the flash is shown below. Wide Angle Optical Zoom: Approximately 0.4 to 2.9 meters (1.3´ to 9.5´) (ISO Sensitivity: Auto) Telephoto Optical Zoom: Approximately 0.4 to 1.6 meters (1.3´ to 5.2´) (ISO Sensitivity: Auto) * Depends on zoom factor
Aug 22, 2007 | Casio Exilim EX-Z750 Digital Camera
Casio Exilim Card EX-S600 Digital Camera Logo
172 people viewed this question
Top Casio Cameras Experts
Ekse
atollminsk
Level 1 Expert
Parshiv Luthra
Are you a Casio Camera Expert? Answer questions, earn points and help others
