Operation system for Solton Ketron X1 - Computers & Internet
My Ketron Sd5 seems to play a different key on the right than on the left. For example if I play a beat in the key of G (left) the right hand side plays in A. Can you help?
You need to check your manual for instructions on key transpose. The right side has been transposed one key higher. If you don't have the manual, try resetting the instrument by removing the internal battery and reinstalling it. Good luck!
Aug 01, 2016 | Ketron SD5-61-Key Arranger Workstation...
The function key is not working to change the soft keys and as a result the battery life drains very fast?
Try reinstalling the drivers for the Lenovo:
http://support.lenovo.com/us/en/documents/x1-carbon-help
Good luck !!!
Nov 21, 2014 | Lenovo ThinkPad X1 Carbon Laptop
Disk to fat converter
Your hard drive via USB connection did not power on your hard drive so your PC can't detect the drive. I don't believe the cause is your software. Try another UBS port, if that doesn't work power down your PC, connect your drive and boot up to see if the program detects the drive.
Nov 05, 2013 | Computers & Internet
Audio driver for dell latitude x1
I see this is a pretty old message, but in case anybody else is looking for the sound driver (and the rest of the machine's drivers) here is a great link to Dell's site:
Drivers for Latitude X1
Nov 30, 2012 | Dell Computers & Internet
Solton ms60 keyboard... volume stuck , can't adjust sound once set
There are a number of ways to adjust the volume. 1) Normally a button or keys on the keyboard will adjust the sound volume. You might have to press and hold the FN key or the Alt key then hit the key that adjusts the volume up or down. 2) If you right click on the megaphone at the bottom right near the time you can adjust the volume. If you click Start/Control Panel and look for Sound and Audio Devices you can adjust it there. 4) If you click Start/Programs/Accessories/Entertainment you will see a way to adjust the volume.
Apr 02, 2012 | Computers & Internet
It seems my desktop file SEARCH locator is mulfunctioning... why cant this DOG be able to look for my files and folders anymore, why is everything blank in this window except for the dog
tell that dog to go away and download a new one from MS web site.
You may have to re-index your content, but that beats your current situation.
Better still, give X1 a try. It's free for 30 days, but I'll bet you'll love it and gladly spend $50 for superior indexing and retrieval. It's not freeware, but it's the best fifty-dollar ware on the planet if you have to use Windows and need to find your stuff !
Download the X1 Professional Client http://www.x1.com/resource_center/downloads.html
Mar 12, 2010 | Microsoft Windows XP Professional
Need 5-digit code for universal remote on DAV-X1
There may be no code in the library of your Insight remote. You may have to try a different universal remote.
Apr 04, 2017 | Sony DAV-X1 System
Input a number and then show the fibonacci sequence of the input number in a C++ program.
I'm assuming one of two things, either
A) You need help for a programming class?
or
B) You're just curious?
Either way
#include <iostream>
#include <algorithm>
using std::swap;
using std::cout;
using std::endl;
// Function f returns n'th Fibonacci number
// It uses Algorithm 2C: non-recursive loop
unsigned int f(unsigned int x) {
unsigned int x1=1;
for(unsigned int i=1,x2=1;i<=x;i++) {
x1+=x2;
swap(x1,x2);
return x1;
// Function f_print prints out n'th Fibonacci number
void f_print(int n) {
cout << n << "th Fibonacci number is " << f(n) << endl;
// main is the entry point in C++
int main() {
f_print(46);
Feb 18, 2009 | Computers & Internet
BSOD
...The BSOD is displayed because the OPERATING SYSTEM on your HARD DRIVE doesn't like some HARDWARE/ SOFTWARE recently installed... Try removing ALL newly installed stuff then attempt reboot & run. ...
To troubleshoot to the CAUSE of the DBSOD (dreaded blue screen of death), install suspect critters ONE AT A TIME, to see which is the REAL CRITTER... Doug R.
Jan 15, 2009 | Dell Latitude X1 Notebook
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
