Question about Kenmore Single Room Air Conditioner
Cannot change temperatuer controls on lra08pzu1
How do I find the temperatue control module on a
the year and motor size would really help and 2wd 4wd and xlt or lx or slt
Sep 28, 2014 | Cars & Trucks
Blower works but no heat
could have faulty thermostat.make sure engine coolant level not too low.if all is good you could have clogged heater core or heat control mode temperatue control switch faulty or the heater control cable or air door actutor not working.
Feb 01, 2013 | 2005 Suzuki Forenza
Have a gs201eta ww refrigerator ice maker problem Unit makes ice, light works and water dispenses from the door. However ice cubes and crushed iced does not dispense from the door. The dispenser motor...
The fridge gets its cold air from the freezer through a vent between the freezer and fridge. the fan in the freezer blows air through it. there is a flap you adjust with the fridge temp. control.
Make sure it's opening and closing when you adjust the fridge temp. try to chec in the user guide.
Hope helps.
Jul 07, 2010 | Refrigerators
Hi, My Jetta3 cli guage is showing that the car is overheating. The electronic console unit reports correct temperatue 94 degrees. The car is using in excess of 14L/100km. This is attributed to the car...
May be oxygen sensor which also regulates fuel. That plus temp sensor is main inputs to fuel control. As 02 sensor fails computer can send wrong amount fo fuel and this will eventually burn up your cataylic convertor which will cause more problems. scanners are hard to come by on bosch systems but you need to get some info on voltages coming from 02 sensors and look for cross counts which is an indication of reaction times for the sensor. It should show movement from high to low voltage as the computer adjusts fuel. If the signal is staying in one range the computer will keep adding fuel thinking it is running lean. Hope this helps a little. If so please reply as this helps me continue to answer questions here and good luck
Apr 29, 2010 | 1995 Volkswagen Jetta
Frs23h5asb6 is freezing food on refrigerator side. Turned refigerator control off, still is 33.5 deg. Took out all bags to increase air flow. Is thermostat bad?
first of all are you talking about summer or winter, i dont know what state you live in. the weather and humidity play a big part on your unit,is your kitchen as warm as in is is winter,if not turn down the freezer control down ,turn on refrigator control 1/4 of the way.until you get both sides of the unit working at the right temperatue.you may have to adjust the settings a few times.using the freezer and refrigerator controls back and forth. also in the summer you can usually back down the controls to adjust in the temperatue change. no more frozen lettuce in your fridge,i hope.,,,,,,,,dave
Jan 25, 2010 | Frigidaire FRS23R4A Side by Side...
BMW 320i year2002 e46
I don't think your trouble is on the ignition side of it but I am sure that you must have a look at the idle speed control(stepper motor).
If with temperatuer your "misfire"changes to better, it means that it's probably running too lean at cold, normally the stepper motor or ISC does this job.
Let us know how you get on.
Cheers.
Sep 06, 2008 | 2003 BMW 325
Kenmore Single Room Air Conditioner Logo
18 people viewed this question
Top Kenmore Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
