Question about YouTube Videos
Johanathan nii aryeetey - YouTube Videos
I have a McCulloch 35cc 14in chain saw. It has given good service but now runs intermittently. When it stops it is hard to restart.
in the gas tank is a filter. you can use a clothes hanger to fish it out, remove it blow it it out backwards with air . or replace it. if this don;t work buy new fuel lines ,carb kit,carb cleaner spray(parts master #1736 my fav) and a new spark plug. when doing the carb just replace gaskets and diaphragm .. don't worry about all the other stuff in the kit, you are just washing the carb to get gunk or dust out of it .. all back together and wa la.. ning ning niiing.. back in biz.. one other thing that goes bad is the crank shaft seal( the 1 next to the clutch) and it can be a pain to replace ! vote if'n i was of help.. remember BUY USA MADE PRODUCTS.. Jay
Aug 21, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
I want to attach the chain saw to the pole
ahhhg i would say NO if its made for a pole get the right pole ! you will find that the first time you use it you come back with just the pole and no saw.. and the you break you neck trying to retrieve your saw way up in the tree.. WHY U ASK ? the saw blade will get pinched . means stuck in the cut. and will need another saw to rescue it.. fun huh .if you need a little extra height use a truck bed. never use a ladder . good luck be safe..in the gas tank is a filter. you can use a clothes hanger to fish it out, remove it blow it it out backwards with air . or replace it. if this don;t work buy new fuel lines ,carb kit,carb cleaner spray(parts master #1736 my fav) and a new spark plug. when doing the carb just replace gaskets and diaphragm .. don't worry about all the other stuff in the kit, you are just washing the carb to get gunk or dust out of it .. all back together and wa la.. ning ning niiing.. back in biz.. one other thing that goes bad is the crank shaft seal( the 1 next to the clutch) and it can be a pain to replace ! vote if'n i was of help.. remember BUY USA MADE PRODUCTS.. Jay
Aug 08, 2010 | Remington Electric Pole Saw
Hi, i've been using my K800i for about about 2 years now , i have change the charger once, now once in a while the screen goes off , what is the problem now. Nii
is it just the screen that goes off of does the phonbe restart? if its just the screen then the lcd screen may need replacing, if the phone restarts it needs new software, read here http://forums.se-nse.net/topic/23459-tutorial-general-usage-xs-v31/
Apr 14, 2010 | Sony Ericsson K800i Cellular Phone
Macam mana nak bukah security code fon saya.model 1208
hp 1208 terblokir nii
gmn cra buka security nya
Jan 20, 2010 | Nokia 1208 Cellular Phone
My computer will not turn on no power
or *********** board is faulty or your power supply is faulty..
Nov 02, 2008 | Koss KS3102 System
Reporting my inactive printer
To clear this error: Power the printer off and let it stand for at least 30 minutes to allow the fuser to cool. Remove the coating roller from the top of the fuser unit to reveal the orange fuser rollers underneath. Check to see if any paper/transparency has become wrapped around the fuser rollers or jammed in or above the fuser unit itself. Since some paper jams can be very difficult to see with the fuser installed, remove the fuser and check for paper/transparency jams under the unit as well. A jam in that area can cause 993 errors. If there is no media jam and the error remains after the printer is restarted, try replacing the Oil Coating Roller (OCR). The OCR comes with the black toner cartridge. (It can also be purchased separately. Click here to do so.) If the error remains after the OCR has been replaced. If that does not help I would highly recommend taking it back to the place you bought it from
May 06, 2007 | Lexmark Optra C710 Laser Printer
YouTube Videos Logo
24 people viewed this question
Top YouTube Computers & Internet Experts
Rizwan Hanif
Level 1 Expert
LP
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
