Question about Toshiba Portege R100 Tablet PC
Usb cd rom will not boot can i boot from sd card
Can i boot from sd card or make it boot from usb cd rom
  • 70 Answers
Yes you must change the boot order and activate the legacy USB support if exsisted
Posted on Jan 25, 2009
  • 31 Answers
Depends. you will have to enter the BIOS and select the boot order. set usb to first priority. should work
  • Bogdan Robert Marius Jun 22, 2013
    its has no usb option....lol ....you dumb
    the thing with this r100 is that is limited in bios to boot with only 2 external thing:so Toshiba sells two external drives for the system: a USB 2.0 floppy drive and a PC Card-based DVD-ROM drive.trust me i have try all the things with this portable with no succes ,i have instaled the win 7 ,win vista ,with the pxe method over the lan with succes and windows xp wont work even with the nic drivers from the toshiba.com.
How do i use recovery cd's if i have no cd rom drive? i have an external cd/dvd drive plugged into usb port but the fujitsu 1510d lifebook does not recognise it? thanks dave
When you boot your computer, start up your BIOS, then under the boot menu, make sure USB is listed as the 1st option.
To log into your BIOS, press the "Boot Option" key. It might be F1, F2 or Delete
Feb 28, 2011 | Fujitsu LIFEBOOK P1510D Tablet PC
Hi, 1. How to transfer/copy bootable XP files onto SD card and then boot up Toshiba Portege M205 from the SD card? 2. Is it possible to made an image of my Windows XP CD on SD card? Regards Tad
Requirements
  • PC running Windows XP/2000 with a CD/DVD burner.
  • USB Flashdrive (Or some way to transfer files to the 3epc once Windows is installed)
  • SD Card, a fast SDHC is recommended of at least 2GB.
  • XP3eSD Utility
  • Hitachi Microdrive Filter Drivers
  • Partedmagic (or another bootable CD with disk cloning software)
  • Windows XP CD (SP2 Only Tested, may work with others)
  • Asus Eee PC (Of course!!)
Instructions:
  1. Copy all files from your XP Install CD to a folder on your Hard Drive
  2. Download the XP3eSD utility and run it to create a new install CD capable of installing Windows to boot off the SD card reader
  3. Boot your 3epc from the CD made in step 2
  4. Install Windows onto a FAT partition, deleting all the existing partitions
  5. When windows boots for the first time turn off the swap file, system restore, and the screensaver.
  6. Then stick your USB thumb drive into the EEE with the Hitachi Microdrive Filter.
  7. Next copy the files from your thumb drive to the desktop and then properly remove the thumb drive.
  8. Unzip the microdrive files to a folder on the desktop. And Insert your SDHC Card into the EEE.
  9. You need to then Hit Start go to run, and type regedit. Navigate to HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Enum\USBSTOR\
    Inside that you should find a directory called something like Disk&Ven_USB2.0&Prod_CardReader_SD0&Rev_0100. Open it. Inside that you should find another directory wich is just a bunch of numbers. Open it. In the right pane you should see a key called "Hardware ID" Right click on it, and select modify. It should list about 7 lines of text. Copy ONLY the first line to the clipboard. Hit cancel, close regedit.
  10. Open cfadisk.inf in the directory you unzipped the microdrive filter to. Edit the section called [cfadisk_device] so that rather than containing 11 lines, just have one line. The line begins with: %MicroDrive_devdesc% = cfadisk_install,
    After the comma, hit ctrl V to paste what you coppied from the registry into the file then save the file.
  11. Go to Device manager. Under disk drives, you should see SiliconMotion and USB2.0 Card Reader. Right click on the card reader and click update driver. Direct the driver updater window to the Hitachi driver you just edited. It won't detect the driver automatically, you have to specifty that your supplying the disk for the hardware and force it to use the driver.
  12. Reboot using the Partedmagic CD or USB Flashdrive, Download it here
  13. Create a FAT32 partition on the SD card, same size as the one on the SSD in your 3epc
  14. Use 'fdisk -l' to find out the partition names of your SSD and SD.
  15. Type this command into a prompt: 'dd if=/dev/sda1 of=/dev/sdb1' When it finishes (it will take some time) type this command: 'dd if=/dev/sda of=/dev/sdb bs=512 count=1' (Note: If fdisk reported your SSD and SD as different than sda and sdb respectively, you must change that in the dd commands, if unsure ask in the support forums)
  16. When it finishes the task is complete, reboot and select to boot from the card reader
  17. Re-image the SSD of your 3epc with your restore DVD or USB.
Jan 27, 2011 | Toshiba Portege M205-S810 Tablet PC
Toshiba 3505 not booting from usb cd rom
OK, Do 1 thing, start pc press del go in side of BIOS.
Set the 1st booting drive as USB CD ROM. and save that. then restart your system.
Jan 30, 2010 | Toshiba Portege 3505 Tablet PC
Fujitsu Lifebook P1120 Won't Boot To CD\DVD
Fujitsu seems to have secretly added a Hardware black list for Booting USB DVD-rw.CD-rw drives.
I have a Stylistic ST5032D slate.
Your either going to have to buy fujitsu's over priced external drive or buy fujitsu's over priced dock.
Or What I do is Bought WinImage or any other software that allows writing a ISO image to USB flash drive, this should almost always work.
I had to install Windows 7 on my tablet this way.
Choose your poison.
Good Luck.
Oct 03, 2009 | Fujitsu LifeBook P1120 Tablet PC
Install new os on motion le 1600
You can use an external USB drive, either CD or DVD dependent on your OS media.
I used a Phillips drive, with external power supply, to restore to factory settings using their restore CDs. I also installed Windows Vista Ultimate from DVD, without issues :)
Mar 30, 2009 | Motion Computing M1400 CENTRINO 1.1G 512...
I have no CD rom in my T3010 then I want know how to install Win xp for it. Lasantha From sri lanka
Use a USB driver or download the windows OS on your hard drive and install from there. both should work as long as you setup will boot to USB devices.
Good Luck.
one more option connect to a network that has Windows OS installable on the server or other computer then install to your tablet.
Mar 20, 2009 | Fujitsu Siemens LifeBook T3010 Tablet PC
Boot up problem
NOTE: Ususally when computers DO NOT find any startup information on the SELECTED DRIVE (like when you click a key) it goes to the default drive.
WHICH IS YOUR HARD DRIVE.
Meaning it is probably your Harddrive is broken, or your connection from hard drive to motherboard is broken
Burn a Live CD bootdisk of some linux distribution
liek Slax, google it.
Burn it to a bootable CD and put it into your drive, then select to boot from it.
If it boots only using your CD ROM drive, if that works then its probably not your BIOS/rest of computer, which is good.
And while in the live cd, you can see your harddrive and see files, that means its not broken its just your connection to it....either way im guessing youll have to send it in.
Jan 10, 2009 | Toshiba Portege R100 Tablet PC
After a hard drive falure I need to install windows xp
At this moment I have taken the HDD out of the case, bought an adapter for its 1.8" interfce and proceeded over the USB. I was, however, installing Linux, with practically no experience with Windows.
Oct 21, 2008 | Toshiba Portege R100 Tablet PC
Loading Windows 2000 on a formated hard drive
Try detecting cd rom in bios and boot from Cd rom. and then istall windows.
If not you should have drivers in floppy during installation it will ask for drivers F6 [function key]
Best Regards
rafique
Feb 18, 2008 | Fujitsu Stylistic LT C-500 Tablet PC
Toshiba Portege R100 Tablet PC Logo
3,561 people viewed this question
Top Toshiba Tablets & eReaders Experts
micky dee
Alun Cox
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
