SOURCE: radio code 1998 volvo v70
your going to have to call up your local volvo dealer and give them your vin number and they can look it up for you. You can try using radio-code.com but i wouldnt recomend it. Your best bet is calling your local volvo dealer and they will help you out.
SOURCE: Volvo V70 xc AWD '98 - fuel filter change
Brandonlo168,
The fuel filter can be located under the carpeted cargo storage floor at the rear of the wagon. Remove the four 10mm bolts, remove the cover. You will then see a removeable plate to the right just behind the rear passenger seat. Fuel filter can be seen through hole in hole. Replaced from underneath wagon. Be sure to make sure lines are fully inserted onto filter. Check for leaks. No smoking, extinguisher handy. Note arrow on filter for correct fuel flow.
Ron
SOURCE: Volvo V70 and the stereo is locked
What an idiotic answer. I would never let Technomad work on my Volvo. Call the dealer and they will provide you with the correct code. If they tell you to come down in person or try to charge you, then call another dealer. It takes five minutes to look up the code.
To reset the code after being locked you must turn the key to the on position and leave it that way for about 2 hours (I can't rember the exact time but that's close) and the radio will reset and allow you to enter the code. No kidding. So if you can park it in your garage or otherwise keep an eye on it while doing that, then you don't have to worry about leaving the key in the ignition for that long.
SOURCE: radio code ( 98 Volvo S70)
Look in the manual for the code - usually someone has written it in there. If not, call the nearest Volvo dealership and give them the VIN - they can tell you what your code is. Then, with the engine off, turn the key to the "I" position (Roman numeral one) and leave it for at least 4 hours. The radio should then read "Code. and you can enter the 4 digit number! Good Luck!
SOURCE: Hi, I have a 1991
Remove the postive battery from the battery touch it to the negtive for 20 secs and reconnect this will reset all computers to factory settings..
Enjoy you tunes!
Testimonial: "Thanks a lot this really helped!"
