Question about Locks & Locksmithing
I forgot the combination to my 3 digit master lock 630d how can I open it with getting a new lock
  • 3,904 Answers
Locksmith can get this open for you. Other way is process of elimination methodically trying every code. Not as hard as it sounds with a 3 digit.
Posted on Jan 21, 2013
SOURCE: Forgot combination to 1500id master lock how do I
Forgotten my combination, how do I open and reset a new combination??
Posted on Feb 18, 2012
SOURCE: i got the master lock speed dial and forgot my combination
Try your old password but push the shackle towards the lock once then put in your old password twice then pull the shackle
Posted on Oct 10, 2011
  • 38 Answers
SOURCE: master lock combination for school
when I went to school we were required to give our school the combination in the event of any emergency. If you did not have to do this and can not find your combination anywhere then your only alternative is to consult a locksmith and they will be able to get you your combo. Manufacturers will not give this out for security reasons and neither will a locksmith unless you call them to come out and can verify it is your lock. If the service charge is going to cost more than a new lock have your janitor or maintenance man cut the lock off for you and put a new lock on. I hope this helps.
Posted on Sep 11, 2008
Richie_asg1
  • 1036 Answers
SOURCE: Master Lock luggage lock
This PDF document explains it carefully -
http://www.masterlock.com/faq/pdf/620_630_646_647_Instruction_Sheet.pdf
Hope this helps.
Posted on Jun 12, 2008
SOURCE: my master lock 1547 lock combination was changed and i cant open it
it worked for me .. a good flashlight and magnifying lens will help.
http://www.lockpicking101.com/viewtopic.php?t=15243
Posted on Jun 07, 2010
How to reset combination
To set a new combination:
The initial combination is set at the
factory to 0-0-0-0
1. Open the compartment door
2. Push the reset lever left and down.
The lever remains in this position
3. Rotate dials to your desired combination
4. Push the reset lever, up and right, back
to the original position
5. Close the key storage compartment door
6. Scramble the combination dials to lock
the door and conceal your combination
7. Close the shutter door
Sep 03, 2014 | Master Lock 5400d: Portable Select Access...
I got the master lock speed dial combination lock but forgot my combination and it won't open. can somebody please tell me if i can reset the password?
1. Contact Masterlock.com and fill out the form, get it notarized and send it in for the combination to unlock it based on the S/N which is on the lock.(http://www.masterlock.com/faq/LostCombinations/). Good luck on this since Masterlock will end up finding something that will prevent them from giving you the combination. Its quite frustrating and NOT worth the trouble.
2. Go to home depot. Buy a 24in bolt cutter ($22) cut the stem of the lock. and replace with a new lock that you can buy from home depot for $ 29.00. If you have a key that is inside the lock box that you really need, You will now need to drill out the combinations piece by piece and the door will pop open or send the lock back to Masterlock. They will retrieve the key for you and send it back.
Aug 27, 2012 | Master Lock 5400d: Portable Select Access...
I set a code in the master lock speed dial 1500id, and it will not open. I cannot reset the code and do not know how to get this open. I have read the other suggestions and nothing has worked yet. Anyone...
Try 2 options:
1. just squeeze the shackle twice and pull it out. This is in case you forgot to enter new combination.
2, Make the 2 combination together, the old and the new as one sequence. This in case you forgot to squeeze the shackle before enter new combination
Ity
Sep 06, 2011 | Office Equipment & Supplies
How do you open a master lock model 5400d if you forgot the combination
It would appear that you made a mistake in setting your new combination on your Master Lock 5400d and did not register the combination at Masterlockvault.com. The only way to open your lock is by using the correct combination. There is no other way. Most mistakes are normally one or two digits out, so you may wish to try variations on what you thought you set.
Apart from that you can either try every possible combination or you will need to contact the manufacturer. But they cannot assist you if the lock does not have a serial number (they recently stopped applying serial numbers for greater security) and they will not assist if the lock is already secured to anything. There are a number of other hurdles as well, click here for details. Given that they state that you will have to wait four to six weeks for an answer, it's going to be far quicker to just try every possible combination.
Jul 14, 2011 | Master Lock 5400d: Portable Select Access...
I forgot the combination to my master lock box. What do I need to open the box?
If you do not have the combination, try to contact the manufacturer directly. There may be a serial number on the lock that they can match the combination to.
If that does not work, you will need to contact a locksmith.
Apr 20, 2011 | Master Lock : Locking Combination 5-Key...
HELP needed to open combinaiton lock
side latches of my samsonite brei case is open but cant get the combination lock to release
Jan 21, 2010 | Samsonite Case & Tripod Kit for Digital...
I got the master lock speed dial and forgot my combination
Sep 16, 2009 | Master Lock 5400d: Portable Select Access...
Get the numbers master dial combination lock
Buy the identical lock if possiable and return as defective and they will reset. Otherwise odds or 1 in 999,000 differant combos. This is airport baggage security lock.
Please rate. Thanks
Feb 21, 2009 | Hardware & Accessories
Locks & Locksmithing Logo
1,971 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
