I have just bought a euroline 40 glass washer but every time I turn it on it trips my fuses I have tried different circuits but still trips manual says standard 13 amp power so what is wrong?
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 66 Answers
Element id say
Posted on Jan 18, 2013
  • 183 Answers
SOURCE: Washer Tripping 20 Amp Breaker
probably a faulty heater.
Posted on Dec 27, 2007
  • 97 Answers
SOURCE: LG Tromm WM2277H washer won't start after tripping breaker
no fuses only control boards.with power off pull the top off and check wires at your power supply board(not the one with buttons). Look for burn or damaged wires. no luck with that, will probably need power board(usually the board that goes out). Call LG and speak to cust service....sometimes will cover the board.
Posted on Jun 11, 2009
  • 512 Answers
SOURCE: We moved the washer to a different room. When we
Was the place where it was the original laundry room. If so outlet was probably a dedicated line not hook to any other outlets. Now you moved and plugged into outlet that is not dedicated other items are probably being used on same circuit or breaker is to small, should be 20amp.
Posted on Jul 09, 2009
sx-engineer
  • 10 Answers
SOURCE: hi, my hotpoint wd860g washer dryer keeps tripping
The most common reason for this is a Short circuit dryer element.
the best way to find out is to isolate the dryer and try it.
UNPLUG FROM MAINS FIRST... remove lid, you will then see the dryer box. on there is a fan (2 wires) thermistor (little wire plug goes in there) possibly a thermostat with a red or yellow dot in the middle or it could be a thermal fuse which looks like a long yellow thick wire, and finally the element, There are 2 different types of element, what you need to do is disconnect the wires to the element, put insulation tape around the ends of the wires and tuck them out of the way of the metal dryer box.
Put it on a wash cycle, if it does not trip then it is the dryer element.
Please note, with these wires disconnected, you will not be able to do a dry cycle as lights will flash.
Hope this helps..
Please rate my help.
Regards
Sussex engineer
Posted on Oct 23, 2009
  • 410 Answers
SOURCE: When I press on the power button/trips circuit at the fuseboard.
I am not a repair professional. I am just a 78 year old man who has been making his own repairs for about 50 years. Therefore the washer ID doesn't mean
anything to me. It's been about 55 years since I had experience with front load washers. However I can refer you to Applianceaid.com where they have very good and complete trouble shooting and repair information on front loaders. I think you'll find what you need there. Don't worry about the timer, they hardly ever go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
Posted on Nov 25, 2009
40 amp fuses continue tripping in a 1996 Chrysler Concorde
The owner's manual should delineate which circuits each fuse pertains to. Are they fuses that are blowing or circuit breakers that trip and can be reset?
Apr 18, 2014 | Vehicle Parts & Accessories
1995 Mercury Grand Marquis blowing 40 amp fuse as soon as I turn on ignition
It will help if you can identify the 40 Amp fuse that is being toasted when the key is turned.
I looked briefly at a fusebox diagram and found 3 circuits protected by a 40 Amp fuse. The Lamp circuit protects several circuits which have smaller rated fuses on each separate wire. The 40 Amp protection seems to be a safeguard if all the smaller circuits are active in total. Turning off the automatic headlights, should reduce power drain.
The next circuit is the Rear window defroster. Can easily pull 40 Amps, but once the 40 Amp fuse breaks, it should have no effect on the engine.
The last circuit, on the cars with Trailer Tow or Police package has a
40 Amp fuse on the Battery charge Relay. This is a remote possibility. But the engine should be able to run without an Alternator for several minutes using Battery power.
Have them check the fuel pressure. The Inertia switch could have tripped while the car was being repaired. It does not explain the wiring short, but can explain the no start condition.
Again, if the same 40 Amp circuit is overloading, identify the circuit with the fuse box diagram.
Feb 18, 2014 | 1995 Mercury Grand Marquis
Our old Hoover washer dryer had been working perfectly and then started tripping out - it would seemingly lose power mid cycle. We tried it in different plug sockets and using an extension lead with a...
ok I assume from what you are say that the circuit breaker in the consumer unit (fuse box) trips it could be that the circuit breaker is beginning to fail (they can go weak after prolonged use) and will tend to be a problem on high load appliances the water heater will take around 12.4 amps as will the dryer heater get the circuit breaker changed
Oct 24, 2013 | Hoover Washing Machines
I have just bought a euroline 40 glass washer but it keeps tripping all my fuses when I turn it on I have tried different circuits but still trips
Possible there is short within the power board and so it uses more current than designed. You can remove the panel and check for short within the panel board. Check for visible damage to the board. It can be shorted surge capacitors, protectors or rectifiers. If not there can be damage within Also disconnect the motor drive , isolating the circuit and if the power does not trip you can check this circuit.
Jan 17, 2013 | Washing Machines
Every time we turn on the glass plate warmer, there is a "pop" sound and the circuit breaker trips in the outside fuse box.
The glass plate warmer element is faulty and short circuits every time you turn it on. The 'pop' you hear is the active short circuiting to earth. It needs replacing.
Mar 02, 2011 | Falcon Kitchen Ranges
I have a HB Water cooler Model 2312C, Type WD01,
Problem: Water is not hot
Possible Causes: Dispenser is unplugged
Solution: Push plug completely into outlet
Possible Causes: Heating switch not on
Solution: Check to be sure heating switch is turned to ON
Possible Causes: The fuse is blown/circuit
Solution: 1. Replace house fuse or reset breaker is tripped circuit breaker.
2. If too many items are plugged into a single circuit, move some items to a different circuit
Possible Causes: Temperature limiter tripped
Solution: 1. Set the hot and cold power switches to OFF
position.
2. Wait five minutes, then set switches to ON position.
3. Wait 30 minutes for water to heat or cool
Link for owners manual: http://useandcares.hamiltonbeach.com/files/840178800.pdf.
Feb 18, 2010 | Hamilton Beach Water Cooler with Storage...
Sony Bravia LCD TV is tripping the fuse in the house
These things draw a huge surge current when turned on. What size fuse are you blowing? These things can surge 10-12 amps on turn-on. What about a fuse with a reset button. They will take alittle more surge before they go. Don't matter about the insignia working before because the cheaper sets tend to stay powered up more when off....thus not surging on from a dead start. Could you try a different plug on a different circuit/fuse? and see if that makes a difference. If you have a 15 amp fuse, then your pretty close with other stuff plugged in. What size is your service? Do you still have an original 60 amp box with screw in fuses? Is it an old house?
Sep 08, 2008 | Sony Bravia KDL-40S4100 40 in. LCD TV
Dishwasher tripping the circuit breaker
Andy, leave the breaker off and remove the toe panel (bottom panel) from the dishwasher. Remove the cover of the junction box where the cord connection or wiring is made. Look at the wire caps and see if they are not burnt. Sometimes these connections become loose and arch, tripping the breaker. If so, cut the wires, strip a new end and reconnect. Catriver...post back.
Aug 21, 2006 | Hotpoint 23 in. BF50 Built-in Dishwasher
Bosch 5315 dishwasher
A fuse may have blown or a circuit breaker tripped. Replace fuse or reset circuit breaker at your fuse box/breaker box windman
Jan 30, 2006 | Bosch 24 in. SHU53 Built-in Dishwasher
Washing Machines Logo
Top Washing Machines Experts
