Question about Belkin (F5D7230-4) Router (587009)
My router keeps disconnecting its self - Belkin (F5D7230-4) Router (587009)
  • 7,627 Answers
Check and reseat ALL cables, connectors, splitters, etc. Contact your ISP to analyze the signal, have a ISP tech come out to verify the signal. It may be outside equipment.
Posted on Jan 17, 2013
Why does my Lacie Wireless Space Disconnects every evening?
Someone is pinging you off , so they must know your router name ssid and or ip.you can change this by 192.168.0.1 reset it and give it a new name and fix the ip to a specific number I.e. 192.168.0.73
Aug 23, 2014 | LaCie Wireless Space 2TB Wireless Storage...
My router disconnect frequently
Question: the connection to router disconnects OR the internet disconnects,
If router disconnect: then try being in range, choose a better spot, keep router in a good spot,
If internet disconnects, cal ISP get it checked, make sure you run ping test to make sure its consistent , here is an example,
E.g:
open run: type cmd, hit enter,
type : ping google.com -t
hit enter, it should give regular pings without timeouts....if too many timeouts, internet service has issues,
call them and report..
Nov 29, 2013 | TP-LINK 300Mbps Wireless N ADSL2+ Modem...
Jordan
Sounds like your router is too hot. try turning on a fan to blow right on the router. if that doesn't help I suspect a bad router.
Jun 08, 2013 | Linksys Computers & Internet
Keeps disconnecting
A wireless router that keeps disconnecting can be caused by any number of things. Please click on this link and follow my instructions which may help solve your problem.
http://www.fixya.com/support/r3559120-wireless_router_disconnecting
Apr 19, 2011 | Linksys WRT120N Router
The router keeps on disconnecting, too hurting and I have a lot of clients! Only works after I shut it off.
A wireless router that keeps on disconnecting can be caused by any one or more problems. Please click on this link and follow my instruction to determine the cause :-
Normal 0
Oct 02, 2010 | Computers & Internet
My fiat punto (2002) keeps stalling by its self and i have to press the acceleration pedal to start the engine. there is also a clicking sound that the engine makes which stops when i press the clutch...
sounds like the idle control valve needs replacing, or could be stuck, you could try disconnecting batery for a few mins and then reconnecting, switch on ignition, this will reset the position of the valve. If this doesnt work have the valve replaced, its a simple job and not too expensive.
May 15, 2010 | 2wire 2700HG-B Router (2700HGB)
WRT54G keeps disconnecting itself, requires disconnecting/reconnecting power and running setup disk again to reconnect. System info: 12 mb/s cable broadband ISP, Motorola SB5105 cable modem, WRT54G...
Go to Administrative Page on your router at section Setup - Basic and activate: Keep Alive : Redial Period 30 seconds.
After that restart your router
Mar 04, 2010 | Linksys Wireless-G WRT54G Router
Laptop and xbox keeps disconnecting on wifi.no
your wifi may have a weak signal. Either the devices aren't close enough especially when running both and eating up all that bandwith, or you need a more powerful router.
Dec 16, 2009 | Zyxel Prestige 660HW Wireless Router...
Laptop keeps disconnecting then connecting every so often.
Has the computer ever stayed on long enough to connect to the internet?
Is there a wired computer working when attached to the router?
If not, if possible please try to connect the laptop wired to the router as a test and tell me if it works.
I am trying to determine if your router works with the internet before considering the wireless connection simplying the initial problem. Once the router works wired is time to try the wireless. Once the wireless works unsecured you may want to change the router and wireless adapter to secure the wireless network. So this can be a three step process.
Jan 03, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How do I get rid of the router using an automatic private address which keeps disconnecting?
the router will give you a private address , that is the functionality of the router, the problem is not with your connection, try to upgrade the latest firmware inthe router and reconfig the router in a pppoe mode that will fix your problem..
Dec 20, 2007 | Linksys WRT54GX2 Wireless-G Broadband...
Belkin (F5D7230-4) Router (587009) Logo
16 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
