I have just bought a euroline 40 glass washer but it keeps tripping all my fuses when I turn it on I have tried different circuits but still trips
  • Washing Mach... Master
  • 17,130 Answers
Possible there is short within the power board and so it uses more current than designed. You can remove the panel and check for short within the panel board. Check for visible damage to the board. It can be shorted surge capacitors, protectors or rectifiers. If not there can be damage within Also disconnect the motor drive , isolating the circuit and if the power does not trip you can check this circuit.
Posted on Jan 18, 2013
SOURCE: hotpoint wd440 flashing dryer heat button and onoff button !
I had to have a tech come out for the same problem two weeks ago. They had to clean the lint collector which you cannot get to on your own. He said now that this has been done everytime I use the machine, take the clothes out and then run a rinse spin cycle.
Posted on Aug 07, 2008
  • 135 Answers
SOURCE: Washing Machine trips circuit breaker when Drying
This will be the dryer heating element needs replacing.
Hope this helps.
Posted on Jan 22, 2009
SOURCE: LG washing machine trips GFI Circuit Breaker
WASHING MACHINES ARE NOT TO BE CONNECTED TO GFI OUTLETS AND TRY TO CONNECT IT TO A CERCIUT THAT IS NOT WITH YOUR DRYER. (REG) OUTLET.
Posted on Jan 31, 2009
barkencoa
  • 3463 Answers
SOURCE: my aquairius hotpoint washer dryer wd62 keeps tripping electric why
Remove top cover, and unplug motor, try it, and if it does not trip, then motor is causing prob.
If it still trips, then heater is probably causing problem.
Please rate my advice.
Thanks.
Posted on Jun 01, 2009
  • 97 Answers
SOURCE: LG Tromm WM2277H washer won't start after tripping breaker
no fuses only control boards.with power off pull the top off and check wires at your power supply board(not the one with buttons). Look for burn or damaged wires. no luck with that, will probably need power board(usually the board that goes out). Call LG and speak to cust service....sometimes will cover the board.
Posted on Jun 11, 2009
40 amp fuses continue tripping in a 1996 Chrysler Concorde
The owner's manual should delineate which circuits each fuse pertains to. Are they fuses that are blowing or circuit breakers that trip and can be reset?
Apr 18, 2014 | Vehicle Parts & Accessories
1995 Mercury Grand Marquis blowing 40 amp fuse as soon as I turn on ignition
It will help if you can identify the 40 Amp fuse that is being toasted when the key is turned.
I looked briefly at a fusebox diagram and found 3 circuits protected by a 40 Amp fuse. The Lamp circuit protects several circuits which have smaller rated fuses on each separate wire. The 40 Amp protection seems to be a safeguard if all the smaller circuits are active in total. Turning off the automatic headlights, should reduce power drain.
The next circuit is the Rear window defroster. Can easily pull 40 Amps, but once the 40 Amp fuse breaks, it should have no effect on the engine.
The last circuit, on the cars with Trailer Tow or Police package has a
40 Amp fuse on the Battery charge Relay. This is a remote possibility. But the engine should be able to run without an Alternator for several minutes using Battery power.
Have them check the fuel pressure. The Inertia switch could have tripped while the car was being repaired. It does not explain the wiring short, but can explain the no start condition.
Again, if the same 40 Amp circuit is overloading, identify the circuit with the fuse box diagram.
Feb 18, 2014 | 1995 Mercury Grand Marquis
Our old Hoover washer dryer had been working perfectly and then started tripping out - it would seemingly lose power mid cycle. We tried it in different plug sockets and using an extension lead with a...
ok I assume from what you are say that the circuit breaker in the consumer unit (fuse box) trips it could be that the circuit breaker is beginning to fail (they can go weak after prolonged use) and will tend to be a problem on high load appliances the water heater will take around 12.4 amps as will the dryer heater get the circuit breaker changed
Oct 24, 2013 | Hoover Washing Machines
Washer keeps blowing fuses
Do you mean the houses circuit breaker? If so, WHEN in the cycle does it blow the circuit breaker? WHEN it trips will tell you what to look at. I.E. If the circuit breaker trips during the fill cycle then it would be the walter inlet valve or the timer in the control panel; if it trips as soon as it is in the agitator cycle - then the motor or transmission; if it trips in the spin cycle - then the drain pump or transmission or control panel.
Jul 15, 2011 | Maytag LSG7806A Front Load Stacked Washer...
My Nobel dishwasher keeps tripping the circuit breaker. I think it is when the detergent door flips open it shorts the sytem? anybody know what I can do?
Something to try. Get a short HD extension cord and plug the washer in to a outlet just outside of the kitchen and see if a different breaker trips. Turn off and or unplug all small appliances when using washer. Could have a defective breaker. Good luck, best regards.
Feb 01, 2011 | Dishwashers
My microwave oven keeps tripping the circuit breaker.i replaced the outlet that it plugs into but it still trips it. is there an internal fuse in the oven that may be bad?
If a fuse inside had blown, that would definitely reduce the current flow rather than trip the breaker.
I have replaced several breakers over the years; they no longer last forever.
Try your Amana on a different circuit, not in the kitchen; if that other circuit likes the oven, the breaker is bad. If the alternate circuit breaker also trips, then you have not a blown fuse in the Amana but rather a shorted component inside and repairing the oven will likely cost about the same as replacing it.
Nov 22, 2009 | Amana Radarange Microwave Oven
Hi, my hotpoint wd860g washer dryer keeps tripping the fuse box. sometimes 20 mins in to a wash and sometimes up to 40 mins and then will keep tripping over and over. then it will run for a bit again and...
The most common reason for this is a Short circuit dryer element.
the best way to find out is to isolate the dryer and try it.
UNPLUG FROM MAINS FIRST... remove lid, you will then see the dryer box. on there is a fan (2 wires) thermistor (little wire plug goes in there) possibly a thermostat with a red or yellow dot in the middle or it could be a thermal fuse which looks like a long yellow thick wire, and finally the element, There are 2 different types of element, what you need to do is disconnect the wires to the element, put insulation tape around the ends of the wires and tuck them out of the way of the metal dryer box.
Put it on a wash cycle, if it does not trip then it is the dryer element.
Please note, with these wires disconnected, you will not be able to do a dry cycle as lights will flash.
Hope this helps..
Please rate my help.
Regards
Sussex engineer
Oct 22, 2009 | Hotpoint Ultima WF840 Front Load Washer /...
Sony Bravia LCD TV is tripping the fuse in the house
These things draw a huge surge current when turned on. What size fuse are you blowing? These things can surge 10-12 amps on turn-on. What about a fuse with a reset button. They will take alittle more surge before they go. Don't matter about the insignia working before because the cheaper sets tend to stay powered up more when off....thus not surging on from a dead start. Could you try a different plug on a different circuit/fuse? and see if that makes a difference. If you have a 15 amp fuse, then your pretty close with other stuff plugged in. What size is your service? Do you still have an original 60 amp box with screw in fuses? Is it an old house?
Sep 08, 2008 | Sony Bravia KDL-40S4100 40 in. LCD TV
Washing Machines Logo
57 people viewed this question
Top Washing Machines Experts
