Question about Konica Minolta bizhub C450P Laser Printer
C-2251 We recently replaced the black toner and after closing the door, the Error code, C-2251, came up. I took it out and put the old black toner in again was was given C-B116 error code. I reset the machine was given the C-2251 error for both new and old toner.
  • Konica Minolta Master
  • 1,294 Answers
Please the copier machine type and model corect.
Posted on Feb 05, 2013
  • 4 Answers
SOURCE: Konica Minolta Bizhub C352 error C-B116
try with trouble reset
turn off the machine, press and keep pressed utility counter, turn on the machine
on the display you'll see the Trouble reset button on the display, touch it and turn off and on the machine
check if error disappear
Posted on Oct 19, 2008
SOURCE: Konica Minolta C450- error code c-2251
It's been a while since you posted that but you may just need to slide it back out and shake it back and forth (long ways) a few times. We had the same problem and the konica minolta tech told us to do that. It worked. DO NOT turn it upside down though.
Posted on Jul 18, 2008
SOURCE: replaced drum unit and came up with error code
c-2251 - K PC Motor’s failure to turn
The Motor Lock signal remains HIGH for a predetermined continuous period of time while the Motor is turning.
Reemove the unit and try to rotate the drum and the developer gears by hand, you should be able to rotate it fairly easy.
Posted on Aug 23, 2009
  • 6 Answers
SOURCE: Toner problems with Konica Minolta 2450
very annoying message i agree - most likely caused by toner dust.
The printer uses a carousel to rotate the toner cartridges. Dust and toner can easily spill as the cartridges rotate. The error can appear at any time but seems to be most annoying after a paper jam or other error. It is also important to make sure that the cartridges themselves are clear of toner dust. Pay particulair attention to any copper contacts on the cartridge.
http://www.zinetic.co.uk/toner_refill/magicolor-sensor-errors.aspx
Posted on Apr 27, 2010
Bizhubman
  • 108 Answers
SOURCE: machine gives me C-2251 error code after replacing
If the drum units have been in storage too long they will bind up a little.
Lightly tap the drum unit on the ground. Look on the back of the drum unit and locate a white cam gear. Take a pair of pliers an rotate this gear until it moves more freely.
Posted on May 22, 2010
What does Error Code C2564 Konica Minolta Bizhub 552 mean
Black drum ATDC replace the black developer unit, also check to make sure the black toner is getting into the black developer unit. Open close the front door to reset the code (Not the Toner door)
Apr 24, 2012 | Konica Minolta Bizhub C552 Copier
How do i override an empty color cartridge so that I can atleast print in black?
There is an error in the control logic of the printer that you can exploit like this:
  1. Start printing your document, you will receive the error message "missing toner"
  2. open the front door and close it again, this will reinitialize the test cycle
  3. the printer will now print one page before verifying the toner content again
  4. after one page you get the"toner empty" message again. Reopen the door and close it again to print another page.
This is only an emergency workaround if you really need to print something black urgently, in the long run you still have to buy a new toner.
Apr 15, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Keeps giving error code 061
Hello sir; Did you recently replace new toner, if you did, please go back to check out does the door close right, otherwise you have to check the corona wire is broken?
Jan 04, 2010 | Canon CLC-700 Copier
Remove all toner cartridges
It took me some time but I found the sollution:
Remove the powercord from the printer.
Open the front door and remove the first toner.
Close the front door and open the top door, remove the photo conductor.
When the front door is closed, you can turn the toner trommel and move it so that the second toner gets in the remove position.
Open the front door and remove the toner.
Close the front door and turn the trommel.
Repeat those steps until all are removed.
Jul 30, 2009 | Epson Aculaser C1100 Printer
ERROR MESSAGE C-2557 CAN I FIX IT??
Yes, open and close front door. And or power off both power switches. Wait ten seconds then turn it on again. The code is for the black image unit lack of toner. Check the image unit, and ensure toner is installed. Model type? would also be welcome
Jul 29, 2009 | Office Equipment & Supplies
Replaced drum unit and came up with error code c-2251. have replaced toner. ran out of toner the other day and someone tried to refill the toner with ink. could this have contributed to the problem? help...
Jul 07, 2009 | Konica Minolta bizhub C450P Laser Printer
Sudden toner outage
yes, error 74 points to toner empty. open front door, press "options" then "start" then "1" and "0". once shows accepted, close front door. make note of this as it very well may happen again.
hth,
razors
Mar 23, 2009 | Brother MFC-7820N All-In-One Laser Printer
Error code on panasonic copier fp-1670
Welcome to Fixya.
Hopefully we can answer some if not all of your questions.
An E3-01 is an error code for your toner hopper. Did you just recently change your toner bottle?
If so, open your front door, take the toner bottle out. Close the front door, turn the machine on, and let the machine cycle and stop.
After the machine is stopped, then open the door and then place the toner cartridge back in.
Close the door, and if the error code doesn't come back your problem should be fixed.
Let me know if you have any other problems.
Good luck
Please post a rating if I have helped you with your question/problem.
have a good day
Mac =)
May 20, 2008 | Computers & Internet
Dell 1720dn Error and Toner light on
After replacing the drum unit you have to tell the printer that you've done it(it's not smart enough to figure it out itself). Have the front door open and press and hold the Cancel button on the printer until all lights flash in sequence then let go. Then close door and try.
Apr 09, 2008 | Dell 1720dn Laser Printer
Toner end life
it is printing with this blinking or not?
Jan 04, 2008 | Samsung ML-2510 Laser Printer
Konica Minolta bizhub C450P Laser Printer Logo
142 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
