Question about Fujitsu Siemens AMILO Xi 1546 Notebook
DVD DRIVE ON LAPTOP
I USE CONVERT XTODVD TO CONVERT MOVIE THEN IT STARTS TO BURN BUT WHEN IT HAS FINISHED THERE IS NOTHING ON THE DISC.I HAVE USED IT DOZENS OF TIMES AND NEVER HAD ANY PROBLEMS I DONT KNOW WETHER THE PROBLEM IS THE CONVERTER OR THE DVD BURNER
  • car0line May 26, 2009
    Fujitsu Siemens Amilo M1405......dvd drive has just vanished was working fine, looks like I need to reinstall the driver. Anybody know where to download this from as I have tried the main site but nothing there...
How can I copy from vcr to dvd without aremote
As for such situation, you may need a DVD Creator.
Leawo DVD Creator can convert video and burn video to DVD-5/DVD-9 content with abundant DIY features to customize DVD movies.
  • Create DVD-5/DVD-9 disc, folder or ISO image files from recorded videos, online videos and other videos;
  • Preset 40+ disc menu and template models for DVD burning, even allow DIY disc menu and template;
  • Convert 2D video to both 3D and 2D DVD movies, with 6 different 3D effects available for choice;
  • Practical and user-friendly video editing features to get customized DVD movies;
  • Fast DVD burning via Intel Quick Sync accelerating technology;
Besides, if it is necessary, you can also use Leawo DVD Copy which can help you copy and backup DVD discs, DVD folders and ISO Image Files to PC or disc, with marvelous bonus features.
  • Copy DVD to DVD disc, file folder and ISO Image File with no quality loss;
  • 1:1 disc to disc duplication while retain original disc quality;
  • Copy DVD-9 to DVD-9, DVD-5 to DVD-5, and even compress DVD-9 to DVD-5 with high quality;
  • Copy DVD contents in different copy modes: Full Movie, Main Movie and Custom Mode;
  • Copy and backup CSS-DVD discs and common DVD discs easily;
Easy to Convert Any Videos to DVD Disc Leawo DVD Copy Software Clone Copy DVD movie to DVD RW disc or hard drive...
Sep 19, 2016 | Televison & Video
Tip
How to remove iTunes DRM copy-protection and burn iTunes movie to DVD?
Many friends ask me how to burn iTunes movies to DVD, so that they can enjoy their movies on large screen TV. For computer newbie, I will recommend them to get an Apple TV; it can connect your iTunes library to TV, the only thing you need to do is to sync movies from iTunes to Apple TV box. An Apple TV costs $299, if you think this is beyond your budget, you can use software to do that same thing, which is a lot cheaper.
Now, let me explain the details. Because movies and TV shows purchased from iTunes store have DRM copy-protection, you have to remove the DRM protection before burning them to DVDs for playback on your home DVD player.
What you need are: Aimersoft DVD Creator & Tunebite. You can download them from:
http://www.topsreviews.com/dvd-creator/dvd-creator-aimersoft.html
http://www.dvd-video-converters.com/dvdvideosuite/backup-copy-protected-music-and-video-with-tunebite.html
Download Aimersoft DVD Creator
    Part1. How to remove DRM copy-protect from iTunes purchased movie or TV shows?
    Step1. Download and install Tunebite, just follow the installation wizard, this software will install several high-speed dubbings to speed up the conversion, when you see the pop up warning messages, just click “Keep on going” to finish the installation, which may take a few minutes.
    Step2. Then run Tunebite, click “Add” button to load your iTunes purchased movies or TV shows, the default directory is My Document\My Music\iTunes\iTunes Music
    In the “Convert Video to” drop down list, select “WMV7 (1024 kbps)”, then click “Start” to begin the conversion. If you don’t know where the converted videos are saved, you can click “Folder” to locate the files on your computer.
Tips: this software can also remove DRM from purchased music and audio books; it also works for other online stores such as Zune, Amazon, etc.
Part2. How to burn DRM-free iTunes video to DVD?
Step1. After you remove the DRM copy-protection from iTunes purchased movies, download Aimersoft DVD Creator and install it. (Note, you need a DVD Burner to burn DVD, so make sure your DVD Drive has DVD+RW or DVD-RW symbol)
Step2. Run Aimersoft DVD Creator, click “Load Video” button to import your DRM-free videos, and then drag the videos to the storyboard. If you want to burn videos to dual-layer DVD (DVD-9), at the bottom of the interface, select “DVD-R 9.0G”, you can also customize video quality there. And the used disc space is shown on the disc space bar underneath the storyboard.
Step3. If you just want to burn the video to DVD without adding any special effects, just click the “Burn” tab. Here you will see the following options:
“Burn to”: you can burn the video to DVD or create an ISO file on your hard drive.
“Drive”: If your computer has multiple DVD burners, you can select any of them.
“TV Standard”: NTSC is 30 fps. It’s used in USA, Canada and Japan. PAL is 25 fps and it’s used in Europe and Asia.
After the above steps, put a blank DVD disk into your drive and click “Start” to burn your movie.
Tip. You can use this software to add special effects to your videos and also create a DVD menu so you can use DVD remote control to control the playback.
Besides this you can also ues other softwares to help you to solve some related problems. I
have being used software called dvd burning
software
, which is easy to download and install, most of all ,its price is considerably
reasonable, if you are interested in it you can have a try. Best wishes for you! Of course you can have more choices for you, you can have a close look at best video editor to get more useful and
practical information for you!
on Jul 26, 2010 | Computers & Internet
Tip
How to burn protected iTunes stuff to DVD?
Many users want to burn DRM protected iTunes videos/movies/TV shows to DVD playable on home DVD player and enjoy on the widescreen TV. I know you can enjoy iTunes movie on TV with Apple TV, but why do you have to spend more $299 if you can do that with some easy software. What you need to do are just two steps:
1. Remove DRM protect from purchased iTunes video/movie/TV show to unprotected video.
2. Burn the non-protected video to DVD.
This step by step iTunes to DVD guide will teach you how to burn iTunes video to DVD, let’s start it.
Step 1 of iTunes to DVD guide: Remove DRM protect from purchased iTunes video/movie/TV show
Step1. Download iTunes DRM Remover, then install this DRM removal software, click button “Add” to input DRM protected movie or music, you can also directly drag-drop them into the main processing window.
Step2 Set the output settings
Choose your file and set the output settings in the "Convert video to" area:
Step3. Begin to convert DRM
After finishing all the necessary settings and editing, click the "Start" button to start converting, That's all.
Step 2 of iTunes to DVD guide: Burn the non-protected video to DVD
Please download and install the Cucusoft Video to DVD Burner at first.
Launch Cucusoft AVI to DVD/VCD/SVCD Converter pro, you will see the right UI.
1. Select radio button "To DVD"
2.choose the "merge" or "batch" tab.
3.Click "Open" button to open your movie file(s)
4. (optional) Set your preference. Region "4" in red frames can set the output MPEG properties.
5. (Optional) Set the advanced settings as following.
6. Click "Convert" button to start the conversion task
7. After you click "Convert" button, the following dialog will pop up automatically.>
8. After video conversion done, the "CD/DVD Burning engine" will be launched automatically. Please choose the DVD burner.
9. Please place a DVD-/+R/RW disc into your DVD burner. If it is a rewritable disc, the program will erase the disc before burning DVD disc.
10. When burning DVD is done, the DVD disc will be eject automatically. You can also find the output file at the output folder.
Done!
Source from:
http://www.dvdtoitunes.net/itunes-to-dvd.html
iphonebooy,know nothing but news about Apple's.
Just jailbreak ipad,ipad transfer,
mac video converter ipod transfer.
on May 24, 2010 | Computers & Internet
How to backup Outlook for Mac on an external hard drive?
How about giving this DVD Creator a try?
Leawo DVD Creator provides the easiest-to-use and friendliest solution for movie fans to convert video and burn video to DVD-5/DVD-9 content with abundant DIY features to customize DVD movies.
  1. Create DVD-5/DVD-9 disc, folder or ISO image files from recorded videos, online videos and other videos;
  2. Preset 40+ disc menu and template models for DVD burning, even allow DIY disc menu and template;
  3. Convert 2D video to both 3D and 2D DVD movies, with 6 different 3D effects available for choice;
  4. Practical and user-friendly video editing features to get customized DVD movies;
  5. Fast DVD burning via Intel Quick Sync accelerating technology;
Hope it is helpful for your issue.
Sep 14, 2016 | Apple Mac Book Pro 13 In Laptop Computers
How to burn iTunes purchased movies to DVD disc?
Hi, Carol. Generally speaking, the iTunes purchased movies can't be copied anywhere .due to the fairplay DRM protection. It of course can't be burnt to DVD disc.
But there are some 3rd party iTunes DRM removal software to help you. I recommend you take TunesKit iTunes DRM Media Converter for Mac and BurnX freeware for a try. iTunes DRM Removal for Mac Remove DRM from iTunes Rentals and Purchases...
TunesKit for Mac is a professional DRM removal application to help Mac users remove DRM from iTunes purchased and rented movies and convert iTunes DRMed M4V to MP4 format with lossless quality. After converted, you can burn the DRM free MP4 video to DVD disc freely with any DVD burner tools, like Burn, BurnX, Simply burns, Liquid CD and so on.
If you are running Windows, you can try Aimersoft DRM Media Converter and use the same Windows DVD Burner tool.
How to Burn iTunes Purchased M4V Videos to DVD
Aug 21, 2014 | Apple iTunes
Tip
Teach you the easiest way of converting torrent movies to DVD on Mac OS
Nowadays, more and more people like downloading free movies, TV shows or videos from Internet, and torrent becomes the best way to get them, being totally free and without any viruses. People can easily get torrent movies, TV shows or videos with a P2P client such as BitTorrent, uTorrent, Vuze, LimeWire, eMule, Ares, BitComet and FrostWire. But these torrent files free downloaded usually take too much space on your computer. In this circumstance, to burn torrent files to DVD becomes a good way to make eternal storage of them. Besides, you can play torrent movies, TV shows or videos on DVD player freely.
What you need to burn torrent movies to DVD on Mac OS X?
That’s easy to burn torrent to DVD on Mac OSX. Things you need are a Torrent to DVD Converter for Mac and a blank or rewritable disc. For the Torrent to DVD Converter, you can use this Daniusoft DVD Creator for Mac which can help you burn torrent files to DVD on Mac easily. For the disc, either D5 or D9 is OK, depending on your file size.
Below is the step by step guide on how to burn torrent to DVD on Mac OS X
Step 1. Load files
Just click “+” button to import the free torrent files to this program or simply drag and drop them to it. And rearrange the file list by using the up-down arrows.
Tips: You can freely drag and drop the thumbnail to merge or split the video files.
Step 2. Edit files (Optional)
To personalize your DVD files, you can edit the video files and slideshows as well by clicking “Edit” button. For video files, you can crop the frame size, trim into several clips, append effects, add picture/text watermark and rotate.
Step 3. Create DVD Menu (Optional)
This Mac DVD Creator also allows you to create your own DVD menu with rich selections of DVD menu template. Simply click “Menu” button to select one and set the “Frame”, “Button” and “Text” to customize your DVD menu.
Step 4. Start to burn
After all necessary settings, you need to insert a blank or rewritable disc to your Mac if you want to burn video files on DVD disc. Or you can simply convert torrent movies to DVD folder, .dvdmedia or ISO file on your Mac for later burning.
With the above 4 steps, you can finish burning torrent movies, TV shows or videos to DVD on Mac. And you can play the free torrent files on DVD player freely.
Related articles:
AVCHD Lite to DVD Mac VLC to DVD Mac
YouTube to DVD Mac Flip video to DVD Mac
on May 21, 2010 | Computers & Internet
Tip
on Feb 05, 2010 | Computers & Internet
My cd/dvd drive will not burn cd/dvd's properly. it goes through the motions, but the discs come out as blank, i was able to burn cds at 2x speed, but that was it. any movie, or anything else will go...
ok..
what kind of application you use for burning??
try it again then double check if you really choose the right path of th drive you want to use as burner..
then you are sure that you burn the music as audio cd not data cd..as well as the video cd not data cd..
because if you burn data cd only computers can read that.. not your aplliances like for example your dvd player,cd,etc.
Feb 08, 2010 | Computers & Internet
How do i get movie files on my pc and burn it to a blank disc
insert a blank CD on your PC, then right click on the movie file and click on send to- CD/DVD drive
then follow the screen by clicking on next until you get finish.
Sep 03, 2009 | Samsung Super-WriteMaster SH-S162A DVD?RW...
Tip
How to burn iTunes music to CD, Burn iTunes videos movies to DVD?
You have a large collection of film movie Video TV Shows files purshased from iTunes library and want to burn part of your iTunes TV episodes movie to DVD disc in order to backup, share with your friends or watching them on either on computer , a DVD player or large screen tv. here is a quick tutorial about how to burn iTunes movie TV Shows to DVD.
As the movie bought from iTunes has apple digital rights management (DRM) license protection which don't allow users to burn iTunes Video Movie TV Shows files to DVD with DVD burning software directly. Commonly, we will need a DRM Removal software to strip iTunes DRM and convert itunes video to mpeg 2(DVD format) first, then burn converted itunes Video to DVD, now, the whole operation will go easy and convenient, the tool we use in this article can remove DRM from itunes, burn iTunes to DVD with only a few steps.
What we need is Daniusoft Media Converter Ultimate - the flagship product of Daniusoft DRM removal software series integrated full function of DRM removal, DVD Ripper, Media Converter, DVD Creator, Media Transfer, etc.
Now, let's start:
Easily install and start DMC ultimate, click 'add' button to load iTunes media, usually they are stored in *:\My Documents\My music\iTunes\iTunes Music, including movie and TV show folder. With all settings are finished, click button 'start' to begin the conversion.
Now is coming to the main part to burn iTunes Movie to DVD. With steps above all are finished, we have actually removed DRM protection of iTunes Video. Click button 'burn-dvd.jpg' on right of DMC ultimate, open the burn option conversion. Add files and folder you want to burn.
DMC ultimate contains several DVD menu templates, or you can even customize title, background, font, etc. click 'next' DMC ultimate will automatically estimate result file volume. You can decide whether to keep files or not according to the estimate result.
Then next step is to start burning process. Within several minutes if you see pop up message saying 'DVD successfully burned' then congratulate to you for your effort success of burning and DVD will automatically pop up.
Tips:
1. Above are the whole processes to burn or store iTunes Video files to DVD to play on home DVD or TV sets.
2. Windows Media files contain also DRM protection system. This process can also to be used to burn Windows Media WMA/WMV files to DVD.
on Jan 13, 2010 | Computers & Internet
Fujitsu Siemens AMILO Xi 1546 Notebook Logo
116 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
