Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Fault displays check door - Bosch Nexxt Premium WFMC6400UC Front Load Washer
  • Bosch Master
  • 17,130 Answers
Possible that the lock or the door switch is not aligned or is out of contact. You can remove and check the assembly. Click on Door
Posted on Jan 18, 2013
2001 chrysler town and country. A\C heat Blowers will not work when controlled my front main pannel. It is a auto temp controlled system. The rear blower will work but no heat when controlled by the rear...
This may be similar to what I just fixed on an '00 dodge:
http://www.dodgeintrepid.net/showthread.php?t=89711
Accessing the Integrated Diagnostic System:
Procedure for Automatic Temp Control (ATC) equipped vehicles:
With the engine ON and the vehicle stopped set the temp to 75*F. Next hold down the Floor, Mix and Defrost buttons until the ATC display begins to flash. While the display is flashing, the system will run it's tests and calibrations.
When the display stops flashing, the tests and calibrations are complete.
The ATC display can only display one error code at a time. Any stored codes can be scrolled through by pressing the Panel mode button once for each code. DO NOT press any other button or you will have to start the test over. Note the codes and refer to the list below to determine what system is malfunctioning.
List of Climate Control DTCs:
23: Blend door actuator feedback failure (bad servo)
24: Mode door actuator feedback failure (bad servo)
25: Ambient temp sensor failure
26: ATC In Car thermister failure (ATC only, bad ATC head or ATC head disconnected while battery is connected)
27: ATC in car sensor failure (ATC only)
31: Recirculation door actuator stalled (stuck door or bad servo)
32: Blend door actuator stall failure (stuck door or bad servo)
33: Mode door actuator stall failure (stuck door or bad servo)
34: Engine temperature message not received (ATC only, bad ATC head or bus failure)
35: Evaporator sensor failure
36: ATC control communication failure (bad ATC head or bus failure)
37: Blend door actuator output shorted to battery (bad servo or wiring fault)
38: Blend door actuator output shorted to ground (bad servo or wiring fault)
39: Mode door actuator output shorted to battery (bad servo or wiring fault)
40: Mode door actuator output shorted to ground (bad servo or wiring fault)
41: Recirculation door actuator output shorted to battery (bad servo or wiring fault)
42: Recirculation door actuator output shorted to ground (bad servo or wiring fault)
43: Common door shorted to battery (probable wiring fault, could be a servo that failed in an odd manner)
44: Common door shorted to ground (probable wiring fault, could be a servo that failed in an odd manner)
45: A/C control blend door input open or shorted with respect to ground (MTC only, wiring fault or bad servo)
46: A/C control blend door shorted to battery (MTC only, wiring fault or bad servo)
47: A/C switch failure (MTC only)
48: A/C control mode door input shorted to ground (MTC only, wiring fault or bad servo)
49: A/C control mode door input shorted to battery (MTC only, wiring fault or bad servo)
50: A/C control electric backlite (EBL) switch fails (MTC only)
51: System voltage too low for calibration!!! (check battery cables, battery and alternator!)
Dec 10, 2014 | 2001 Chrysler Town & Country
Where is located sensor of. Fuzzy logic t7517tepto
dE
Washing machine door detected as being open Door open error code can also be displayed as "dOE"
Very simple error, the fault code indicates that either the door is indeed open or that the door lock or door interlock mechanism cannot inform the electronics that the door is properly closed. LG door locks are known to and do commonly fail, the common one used in most LG washing machines and washer dryers can be found here with a link to a lower cost alternative part. However the door handle (can be found here) is also a common source of trouble and, if the catch doesn't engage into the lock properly you will get this fault code being displayed.
On non-display panel models this fault code is denoted by the light for the door lock being lit or flashing.
  • Check door is closed correctly and latched
  • Check door handle for damage or wear
  • Check door safety lock if inoperative replace door lock
  • Check door lock wiring
  • If there is a clicking sound once or twice when the Start/Pause button is pressed the main control board may be faulty
Dec 10, 2014 | Washing Machines
Wont start machine error come up
Door open error code can also be displayed as "dOE" On non-display panel models this fault code is denoted by the light for the door lock being lit or flashing.
Apr 08, 2014 | LG WD-1280FHD Front Load Washer
My machine keeps displaying a E9 fault, what should I do to repair this?
You have not mentioned the make and model. Now the error is an indication of the fault or a protection indicated.
So remove power and plug in after making sure the door is shut - the door switch is checked to work.
If the error comes on , check on the power to the control panel, observe board for visible damage, check the inlet valve, check for working, check the drive motor, capacitor and drain pump/valve. Once confirmed that all these are working check for line break , if there was damaged done by rats/insects.
If none of these show an indicative fault then the program controller can be faulty.
Apr 11, 2011 | Washing Machines
I have a whirlpool electric dryer Model No. GEW9200 and lights come on, it appears to be sensing moisture content, but the drum won't turn
The cause of the problem is either a blown thermal fuse, a faulty belt switch (loose or worn out belt), a faulty door switch, or a faulty machine control board. Activate the "Diagnostic Test Mode" to determine which you should check first to avoid unnecessary disassembly of the machine.
Diagnostic Test Mode Activation Procedure
  1. Unplug the machine for fifteen minutes.
  2. Make sure the machine stays in standby mode when it is plugged back. That is, no indicator light is on.
  3. Press the following button sequence within five seconds: More time>Less time>More time>Less time
  4. All of the indicators on the console should light on and "88" is displayed on the Estimated Time Remaining display panel. It means no fault is detected and the belt switch is faulty or the belt is worn. Replace whichever is necessary to be replaced.
  • If E1 or E2 flashes on the display, the thermistor has failed and the thermal fuse is open. Replace both.
  • If E3 flashes on the display, there is a fault in the machine control board. Check the board for loose connections or replace it.
  • Open and close the door. There should be a "beep" everytime the door is closed and opened and "OE" is displayed whenever the door is opened. The door switch is faulty if no "beep" is heard or if "OE" is displayed even when the door is closed. Check the wiring harness connection or replace the door switch assembly.
Please inform me about the result of the test to give you the exact repair/replacement procedure.
Jan 17, 2010 | Whirlpool GEW9250 Electric Dryer
The oven isn't working and it says FO in red letters
GE / Hotpoint / RCA
Oven Fault Codes
Display Condition Remedy
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F4 Shorted wire or Sensor locate short and correct it
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Amana / Caloric
Oven Fault Codes
Type with display - glass link ERC
F0 No Safety Signal Replace adapter board
F1 No Safety Signal Replace ERC
F2 Oven over heat Replace defective Sensor
F7 Shorted Touch Panel Replace Glass Panel
F9 Door Latch Error Check latch
FF Lock Error Check switch and motor
ERC III - Relay board with separate board/push buttons
F0 Shorted Push Pad Replace Push Pad
F1 Defective ERC Replace ERC
F3 Oven Sensor Open Check/Replace Sensor
F5 Defective ERC Replace ERC
F6 Defective ERC Replace ERC
F7 Shorted or sticking button Clean button or replace touch pad
F8 Defective ERC Replace ERC
The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
Whirlpool / KitchenAid / Roper
Oven Fault Codes
Ovens with 4 digit displays
F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Ovens with 2 Digit Displays
F0 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F9 Door Latch Error Check latch and latch circuit
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 18, 2009 | Ovens
FDL fault code on kenmore elite washer
F DL
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
Nov 08, 2009 | Kenmore Elite 45986 Front Load Washer
Hotpoint WMA13 door lock fault
If the door locked light is flashing , then the main board probably has a fault on it, due to a problem with the motor, or the board itself being faulty.
Recommend calling an engineer.
Oct 15, 2008 | Hotpoint WMA13 Front Load Washer
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
21 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
