How can I check water temperature as I think it's too high
  • Washing Mach... Master
  • 17,130 Answers
You can use a thermometer to check the temperature but if you are not able to set the temperature to a lower point it can be related to a faulty thermocouple. Remove the wiring to the element and the sensor and check or replace. click on : element
Posted on Jan 18, 2013
Loc error code Frigidaire frontloader
From the frigidaire site.
Error code - Fault condition
E11 Fill time too long.
E13 Water leak in tub or air leak in air bell.
E14 Reed switch.
E21 Water not pumping out fast enough.
E23 Drain pump relay on control board failed.
E24 Drain pump relay on control board failed.
E31 Better models. Pressure sensor not communicating with control board.
E35 Better models. Pressure sensor indicates water overfill.
E41 Control board thinks the door switch is open.
E42 Door remains locked after cycle is completed.
E43 Control board problem.
E44 Control board problem.
E45 Control board problem.
E46 Control board problem.
E47 Board thinks the door PTC circuit is open in spin.
E48 Board thinks the door PTC circuit is closed.
E52 Bad signal from tacho generator.
E55 Motor overheating.
E56 High motor current.
E57 High current on inverter.
E58 High current on motor phase.
E59 No tacho signal for 3 seconds.
E5A High temperature on heat sink.
E5B High temperature on heat sink.
E5C High temperature on heat sink.
E5D Communication problem.
E5E Communication problem.
E5F Communication problem.
E67 Input voltage on microprocessor incorrect.
E75 Better models only. Water temperature sensor circuit.
E76 Better model only. NTC temperature for the cold water valve over the limits.
E95 Communication error.
EB1 Incoming power frequency out of limits.
EB2 Incoming line voltage above 130 VAC.
EB3 Incoming line voltage below 90 VAC.
EF1 Clogged drain pump.
EF2 Too much soap.
Jul 24, 2014 | Frigidaire GLTF2940ES Front Load Washer
Rover 25 1.4 2004 hot engine and radiator fan problem
Yes, it is possible to install a thermostat backwards, though unlikely. If the thermostat isn't opening properly, the hot engine coolant won't be flowing over the cooling fan switch and give you high temps. I would first determine if the thermostat was opening at all, and if it is, is it opening at the proper temp. I have had many new thermostats that, while new, didn't work correctly. To check the cooling fan motor, turn on the AC(if equipped) and the fan should engage. If no AC, disconnect the cooling fan switch, and the fan should engage. Check for power and ground at the fan motor. If you have both power and ground, the fan motor is faulty
Apr 21, 2013 | Cars & Trucks
I have recently replace my salt cell after 6 yrs and now I'm getting a "high salt amps reading". The pool is 20,000 gallons and I installed a T-15-Cell. My salt level says 3900ppm but my...
I would first clean the cell according to the manual. If a small amount of conductive material in across the cell plates cleaning may remove it. Then I would use an independent method of testing the salinity. This could be bringing a sample to a pool supply store. I would use this value to determine whether to add or remove salt. One thing that can affect the equipment's indication of "high salt amps reading" is temperature. Many pool owners are having this indication with very high summer temperatures. Using a lower salinity with high temperatures could help. The main thing is to keep the chlorine concentration to between 2 and 4 ppm.so your pool remains sanitary. Make sure the stabilizer level is correct and circulation is good. I hope this helps.
Please vote on this answer. Thank you.
Aug 24, 2011 | Hayward Pool & Spa
Humidifier fan runs but does not remove water. I don't think the compressor is turning on.
There are 5 basic, yet solvable reason for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have an analog unit
(no LED screen), set the humidity extraction knob to Maximum.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I hope I was able to help you troubleshoot and solve the problem. Thanks for choosing FixYa.
Aug 21, 2011 | Dehumidifiers
Temperature guage goes to high, but it doesn't appear that the van is overheating (no steam/fluid leaking) Radiator & thermostat were recently replaced. Guage will jump to high when idle, but...
FLUSH RADIATOR, HEATER CORE AND ENGINE BLOCK.ADD 50 / 50 ANTIFREEZE AND WATER ALSO REPLACE RADIATOR PRESSURE CAP.IF TEMPERATURE GAUGE STILL STAY HIGH THE ENGINE COOLANT TEMPERATURE SENSOR COULD BE FAULTY.
Aug 21, 2011 | 1996 Ford Econoline
Kenwood KDW 243A Dishwasher has an E3 fault and will not wash the dishes, can you tell me what is causing this please? Thank you
The error (E3) relates to the water heating but not reaching the required temperature. This can be due to a couple of things generally. The sensor which detects the water temperature can be faulty or the heater element itself is faulty and not heating the water to a high enough temperature. I think it's needing to be replaced.
Check to see if there is a thermostat screwed up into the underside of the tub on the rear right side. If there is, test the thermostat to see if it's open circuit, if it is you'll need to change it.
Jun 12, 2011 | Kenwood KDW243A Builtin Dishwasher
I have West ponte Mdf 65 Ae BA8 dehumidifier 1 year old. Filter is clean. It worked last summer but now after the winter it is running fine but no water is comming in the bucket eventhough basement is...
You may have the humidity/moisture level set to high. Try lowering it to 35%. Or if you don't have a LED Screen on your unit, turn it to maximum.
In addition, most dehumidifiers don't work well if the air temperature is between 40 & 60 degrees F. Keep in mind, the temperature at floor level in a basement is colder that the air temperature at chest high level. Raising the unit up, off the floor on something sturdy enough to handle the weight (with a full tank of water) and the vibration, may help.
Hope this helps you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 03, 2011 | Dehumidifiers
Washing Machine starts, squirts water, then stops.
E5E  IS FOR  Communication problem. THERE IS 100 %WIRE SHORTING SOMEWHERE.PLEASE CHECK OUT.
ALSO OTHER ERRORS Error code - Fault condition
E14 Reed switch.
EF2 To much soap.
Nov 12, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
