Question about Yamaha Music
Were to find replacement drive belts for yamaha mt 120 4 track
Need drive belts for mt 120 4 track cassette recorder
Erase track
My Yamaha electone organ el25 no sound but all lights on
Aug 17, 2013 | Boss Micro BR Digital Recorder
My cp300 destroys songs stored in memory. What's up?
Make sure you CHANGE tracks as if you record over the same track it is destructive. It would be easy to forget to change to an unused track and overlay previous data resulting in loss of the original song.
Feb 15, 2011 | Yamaha CP300 Stage Digital Piano...
Trying to wright some tracks in song mode to cd so i could listen in the car but it will not let me. Any suggestions?
I have a similar Yamaha that makes me re-record the 16 tracks of the song onto the stereo track (left and right) then save. See if under the record setting if it has an option to "record to stereo track" or something similar. Hope that helps.
Dec 16, 2010 | Roland Mv8800 Production Studio
I want to record vocal voice trhought mic on psr 9000
You could record short "samples" to be used in building new voices, however, it does NOT appear that you can record a vocal song with the PSR9000. The Tyros II and III have the capability to record vocals but the PSR9000 and Tyros I do not..
When playing back an arrangement, you can re-sing the song and have the vocal harmonizer track the arrangement.
Jul 29, 2010 | Yamaha Music
Midi Output
If you only have a stereo output from the DT you need to record audio to a sequencer track so you can remix it better.
Dec 10, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
I was just wondering if its best to record seperate tracks at different times of if its ok to mic my guitar and mic the vocals using two inputs but recording at the same time?
Whichever works best for you is best. You can always lay down a scratch track for each like this and then lay down another track to replace whatever you didn't like using the scratch track as a guide. Erase the scratch tracks that you don't need before you mix down. I hope this helps.
Nov 26, 2009 | Fostex Mr 8hd CD 8 Track Recorder with CDr
Electronic drum kit, with USB out, problem
Sounds to me like you have the midi tracks outputting to the microsoft midi mapper or wavetable synth, which is built into the sound chip in your pc, and that this is conflicting with the mobilepre sound card - midi is just data, no audio, needs to drive some kind of synth. what you want to do is disable your internal sound card thru device manager, then just use the m-audio mobile pre as the input/output sound card in ASIO mode - you'll need to monitor via the headphone jack on the mobile pre or plug speakers into the line outs on the interface.
Then do tutorial 8 (in help files) on using soft synths - INSERT>SOFTSYNTHs creates a midi track and an audio track in a track folder.
Good luck.
The dude.
Aug 07, 2008 | Yamaha Dtxpress Iv Special Electronic Drum...
Music Logo
95 people viewed this question
Top Yamaha Music Experts
Matthew Spark
Matthew Spark
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
