Question about Epson Stylus Pro 9600 InkJet Printer
Where is encoder's strip? - Epson Stylus Pro 9600 InkJet Printer
  • Epson Master
  • 511 Answers
Encoder strip is plastic strip behind the carriage. It's for horizontal measuring. If it's dirty, the result of printing will be "doubled".
Posted on Jan 19, 2013
MFC-665cw unable to print 50
Did you have a paper jam before this happened? If yes then the paper must have pushed the encoder strip out of alignment.
hen you open the printer so that you can see the print head, move the print head with your hands, pull it to the middle. The space immediately to the front of the printer is blocked by the plastic shield. you can curl your fingers down under this shield. you will feel the encoder strip, which is about 8 mm wide, and is a plastic ribbon, or strip. It runs from left side to right side across the printer, in a vertical orientation. This is the encoder strip. Past this you can feel a longer rubber belt, which is about 3 mm wide. This is not the encoder strip, it is a belt and you don't need to be concerned with this.
Place your fingers on the encoder strip on either side of the print head, and flex it, bending it up and slightly back and then release it. Try this several times. Do this with power on. Once the encoder strip is back into it's slot the printer will start a cleaning cycle and start working.
Solution found here originally.
Oct 16, 2012 | Brother MFC-665CW All-In-One InkJet...
DCP-J125 Uable to print (36)
The message Unable to Print (followed by a two character code) will appear on the display for one of the following reasons:
- Dirty encoder strip
- Foreign object, such as a paper clip or ripped piece of paper, stuck in the machine
- Mechanical malfunction
The most common cause of the issue is dirt on the encoder strip. Clean the encoder strip by doing the following:
CLEAN THE ENCODER STRIP
NOTE: The images shown below are from the representative product. The customer's model may look different from the picture.
1. Locate a lint free cloth such as a T-shirt, DRY eye glass cleaner cloth, DRY monitor cloth or wash cloth.
DO NOT USE ANY TYPE OF PAPER PRODUCTS (EX: paper towel, tissue paper, napkin, filter, news paper etc.) This will help ensure the dirt is removed from the encoder strip.
CHECK FOR FOREIGN OBJECTS & PAPER JAMS
2. After thoroughly cleaning the encoder strip, look inside the machine and in the two corners for jammed paper or foreign objects and remove them if any are found. Pieces of paper may be jammed under the print head.
If the print head is locked to the right side of the machine, press and hold the STOP/EXIT key for 5 seconds. This will cause the print head to move automatically to the middle of the machine and allow you to look for debris in the right corner.
3. Leave the scanner OPEN and turn the machine around so you are looking at the back of the machine.
4. Open the Jam Clear Cover and look inside the machine for paper. Remove any jammed paper that appears; then close the Jam Clear Cover and turn the machine back around to the front.
5. Gently close the scanner cover and verify the error message cleared from the display.
If you cleaned the encoder strip ONCE and the message continues to appear on the display, clean the encoder strip again. It is common to clean the encoder strip multiple times to resolve the issue.
If you cleaned the encoder strip at least TWICE and the message continues to appear on the display, unplug the machine from the power outlet for 2 seconds and plug it back in to cycle the power.
TEST THE MACHINE
NOTE: After a paper jam has been cleared, the Brother machine may complete a 2 minute cleaning cycle to remove paper dust from the nozzles before printing.
May 01, 2012 | Brother Office Equipment & Supplies
Reinstall the encoder strip
Here's an article on the Lexmark website that will give you an idea on how to reseat the encoder strip on your Lexmark X6170 printer.
Error 0502 on the Lexmark X6150/X6170 Printer LCD Display
I hope this information has been helpful.
Dec 12, 2011 | Lexmark X6170 All-In-One InkJet Printer
My Hp z6100 carriage jamms in the middle along the encoder strip during printing and gives me error 86:01. I have tried cleaning the encoder strip and still having the same problem
Maybe u need another encoder strip If u dammaged the strip while cleaning.I've cleaned mine only once with water and a soft a wet clout.Cleaning must be verry gently
Jul 29, 2011 | HP Designjet Z6100 InkJet Printer
Hardware error 0502 from A dell 940
Here is how to fix error 502.
Rick
» Reposition the Encoder Strip on the A940 All-In-One Printer
To reposition the encoder strip, perform the following steps:
  1. Remove the power cord from the unit.
  2. Lift the lid of the unit, just below the scanner portion of the All-In-One, to expose the inside of the unit where the printer cartridges are located.
  3. Gently slide the ink cartridge carrier to the middle of the printer.
Figure 1: Out-of-position encoder strip
  1. Gently move the top part of the printer belt to the right.
  2. Using your index finger, gently push encoder strip down and then back up to get it back into the slot located on the back of the ink cartridge carrier.
new_note.jpg Note: There is a small slot that the encoder strip fits into, which is located on the back of the ink cartridge carrier.
While working with the encoder strip, check it for dust or any unclean spots. If any detected, try to clean the strip by wiping it gently with clean cloth.
  1. Gently press the strip first to the rear and then forward to ensure that it is seated correctly.
  2. Manually move the ink cartridge carrier to the left, then to the right to check the positioning of the encoder strip.
Figure 2: Correctly seated encoder strip
new_note.jpg Note: If the encoder strip moves at all, it has NOT been repositioned correctly.
  1. Once the encoder strip has been re-seated, close the lid to the unit.
  2. Re-connect the power supply to the All-In-One.
  3. Press the Power button. If the encoder strip was re-seated correctly, the Hardware Error: 502 code will not appear.
Jun 14, 2011 | Dell A940 All-In-One InkJet Printer
When printing it starts to print then the cartrideges slam back and forth then it errors
Open the printer cover and access the cartridge area. Remove the cartridges. Check the transparent strip(encoder strip) and make sure it's not unseated from its position. If it is, - Switch off the printer. - Slide the cartridge carrier to the middle of the printer by taking the top part of the belt and moving it gently to the right. - Place an index finger on the encoder strip on either side of the cartridge carrier. The encoder strip is a clear strip running the length of the printer, above or behind the cartridge carrier. - On the back of the cartridge carrier, there is a small slot that the encoder strip fits into. Slightly push the encoder strip down and then back up to get it into the slot. - Then lightly press the strip first to the rear and then forward, if necessary.
Try to print again.
Apr 26, 2011 | Lexmark Z600 InkJet Printer
How do I remove the Encoder strip on a designjet 500 24"
1. Remove the left hand cover
2. Remove the right hand cover
3. Remove 1 T15 screw that secures the Encoder strip to the left encoder holder
4. Release the Encoder strip from the left hand side
5. Release the Encoder strip from the Service station holder on the right side
6. Remove the Encoder strip from the printer
Apr 09, 2011 | Office Equipment & Supplies
My printer shows "Hardware Error
Feb 18, 2011 | Dell A940 All-In-One InkJet Printer
Clear carrier jam
In your case It seems like the Encoder strip is broken or its out of printer . However if you see encoder strip inside the printer connected from left to right, try these steps.
Solution:
1. Cleaning the encoder strip:
a. printer should be off and disconnected from power.
b. open the front cover.
c. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer and you can move the cartridges carriage to clean the strip completely.
d. Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod.
e. Close the printer and try again to print.
2. Repositioning the Encoder strip.
a. Remove the power cord from the printer.
b. Open the front cover.
c. Gently slide the ink cartridge carrier to the middle of the printer.
d. Gently move the top part of the printer belt to the right.
e. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
f. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
g. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
h. Once the encoder strip has been re-seated, close the scanner lid.
i. Re-connect the power cord to the printer and try again to print.
Incorrect position of encoder strip
Correct position of Encoder strip
Hope it should fix the issue.
Oct 26, 2008 | Dell 924 All-in-One InkJet Printer
Clear carrier jamed
There could be 4 possibilities.
1. Ink cartridges lids are open which is not allowing cartridges to move freely.
2. Ink cartridges carriage will not move from its original position(left) when front cover is opened
3. Encoder strip is Dirty.
4. Encoder strip is Out of position.
Solution:
1. Open the front cover and check if ink cartridges lids are properly snapped in.
2. Turn the printer off and pull out the power cable from power socket, open the front cover and manually center the ink cartridges carriage.
Clean the metallic rod inside the printer using WD40 or Kleenex from Left corner to right corner properly.
3. Cleaning the encoder strip:
4. Repositioning the Encoder strip.
Oct 20, 2008 | Dell 924 All-in-One InkJet Printer
Epson Stylus Pro 9600 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
