Question about Samsung LE32R41BD 32 in. HD-Ready LCD Television
I am getting horizontal flickering white lines on my lcd tv. It is more on AV input. With HDMI and VGA port the line position and size varies with resolution selected. With 480p all lines dissappears but all other resolutions these lines are visible. With component YPbPr input the screen is excellent clear with no problems. I am just unable to get rid of these lines. I did a factory reset but did not work out.
SOURCE: White horizontal flickering lines
If still under warranty, take it back. but first check your cable input connections or cable signal may have went bad. Lastly it could be the signal module inside.
Posted on Jan 02, 2008
SOURCE: SAMSUNG LCD TV horizontal lines
causing of horizontal lines is leaky or defective capacitors. check big value capacitors around the board at Horizontal area. check the filter capacitor as well. good luck
Posted on Apr 20, 2008
SOURCE: LCD TV SCREEN PROBLEM RED HORIZONTAL LINES OF DOTS ALL OVER SCREEN PLEASE HELP
I unplugged the TV and now the picture is back.I read that the LCD's are vunerable to static build up so unless my daughter is using her TV I unplug it.
I was thinking about getting a large LCD for the family room but I'm not going to until they improve on this technology.
Good luck to everyone!.
Cheers.
Posted on May 08, 2008
SOURCE: how to adjust from 480p to higher resolution up to 1080
several things use hdmi cabling, also change resolution (can sometimes be changed on front of direct tv receiver) or may have to go through menu to change to the different resolutions. also turn the native mode OFF! having the native mode on for directv will give sometimes give you odd pictures. also whatever resolution you choose through directv menu's make sure your tv is also set to the same resolution
Posted on Apr 05, 2009
This should be repairable. It may be the LVDS Cable or the Main board problem. The only other problem is the T-Con Board.
Posted on May 23, 2009
Feb 12, 2017 | Samsung Televison & Video
Aug 24, 2016 | Televison & Video
Feb 22, 2016 | Samsung Syncmaster S20b300b - Led Monitor...
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
Jan 18, 2016 | LG Televison & Video
Sep 25, 2015 | Samsung Televison & Video
May 06, 2014 | Sony Bravia L-series Kdl-32l5000 32-inch...
Jan 23, 2013 | Samsung LN-S4692D 46 in. LCD HDTV
Jul 23, 2008 | Televison & Video
Jan 02, 2008 | Samsung LN-S3251D 32 in. LCD HDTV
677 people viewed this question
