My Samsung DVD home theater system HT-X40 does not stay on. It says "protection" then shuts off automatically. I can't access the menu to take the protection off because it shuts off to fast. When I
    Genius:
  • 1,054 Answers
Protection display usually means there is a problem with the amp.
Posted on Jan 17, 2013
SOURCE: my home theatre system (sAmsung
Protection mode on a Samsung player most likely means that the unit is overheating due to a non or low functioning fan. Before taking it somewhere to be serviced turn the unit on and see if the fan in the back is functioning (it should be on whenever the unit is on). If it is not you can try gently blowing it out with a can of compressed air.
I am sure that you can have it serviced but it might be cheaper to purchase a new player.
Good luck and take Care,
-WN
Posted on May 06, 2008
SOURCE: cant use dvd player, the
i have a samsung dvd theater system ht dm150 it will sometimes read the dvds dut majority of the time it wont read any dvd i even used a cd cleaner on it. 80% of the time it will play music cds.
Posted on Sep 07, 2008
drlalitv
  • 488 Answers
SOURCE: I have a samsung DVD
If it is, the protection message usually meant either a speaker had blown, or more commonly a wire to a speaker had come disconnected or broken/shorted.
Try unplugging the speakers one at a time, and if you have a set of speakers of the same rating to try, try plugging them in as you remove the originals (obviously doesn't need to be done in the setup positions in the room, just have them beside the player to check it works.)
This might then identify which speaker or cable is the problem one for you to replace or repair.
If this is the speaker overload/short mesaage as I think it is and the above doesn't cure it, it would appear the amplifier board has a short somewhere and that's an electronics engineer job time
Hope it helps!
Posted on Nov 18, 2008
  • 98 Answers
SOURCE: I have a samsung ht-x40
Check the components near the fan in the back to see if any caps are fried (looks like it exploded)causing the protection circuit to come on if this is fine then check the fan to see if it if freely moving.
Posted on Dec 05, 2008
SOURCE: samsung dvd home theater HT d5610
I am looking for and to purchase an antenna for my HT D5610. Thank you for any help you can provide me with.
Posted on Feb 01, 2009
Power ON
over voltage to the system causes ur system to shut off.
get it checked or replaced if  warranty is still valid.
Mar 14, 2010 | Samsung HT-Z210 Theater System
Samsung HT-X40 also shuts off after displaying Protection
You probably have the same problem that myself and several others have had, and let me guess, its outside of the warranty? How good are you with a soldering iron? If you are not afraid to do some soldering you can fix it, check out these instructions that i found:
http://lemurt.wordpress.com/2008/08/18/defenition-of-waranty-void/
you will need 474k or .47uf 100v capacitors and a soldering iron, but you can fix it, worked for me.
Aug 08, 2009 | Samsung HT-X40 System
I got ahtx-40 and after running for a while it displays protection and the power goes off. helppppppp!!!!!
I have the same HT-X40 home theater as you do, and my problem seems similar to yours. It'srelated to overheating. First check the fan and air flow from it. Ifit's OK, the problem can be inside the unit. In my case one of theoutput filter capacitors got broken - it had a crack on its body.Replacement of the capacitor fixed the shutdown on protection.
Anotherquestion is what damaged the cap. Preliminary I consider placement ofthe capacitors as a possible problem - they are too close to the outputinductors which can get relatively hot even at normal workingcondition. For details you can check:http://craftsman-hambs.blogspot.com/2009/09/samsung-home-theater-ht-x40-shut-down.html
Jun 11, 2009 | Samsung HT-X40 System
Protection and shut down.ht-tx35
protection error message means that your unit's fan is not working
it is a feature to keep your unit from overheating
check if there is anything blocking the fan of your unit from rotation
Jun 09, 2009 | Samsung HT-X40 System
Dvd home theather system
The audio amplifier IC are fried and need to be replaced
Mar 31, 2009 | Samsung HT-X40 System
Help
has to be in digital cable going in and the dvd has to be dolbit dts avb sound track ok to enables itself
Feb 10, 2008 | Samsung HT-X40 System
Televison & Video Logo
433 people viewed this question
Top Televison & Video Experts
