Flames goes out when pilot is released
Flames goes out on pilot when control knob is released. Heater will work if I tape the control valve depressed
    Scholar:
  • 155 Answers
It sounds like the thermocouple that senses whether the pilot is lit is bad. You need to replace the sensor.
Posted on Jan 17, 2013
hotuna
  • 288 Answers
SOURCE: windchaser patio heater
You have to hold the button down for 30 seconds at least before turning the knob to ON. If you are doing this and it still goes out after you let up on the knob, then it needs a new flame sensor, or thermocouple. Same thing different names.
Posted on Mar 06, 2008
SOURCE: Nexgrill patio heater won't stay lit
I called Nexgrill technical support at 1-800-913-8999. They are sending me a new thermo couple to keep the valve open when ignited - so the patio heater will stay on. I needed to give them the serial number (inside the propane tank door) and fax them a copy of the receipt.
Hope this helps.
Posted on Jul 18, 2008
  • 8 Answers
SOURCE: Patio Heater pilot lights won't stay lit
crappy pilot flame (not properly heating the thermocouple), bad thermocouple, thermocouple loose where it screws into the pilot safety valve, bad safety valve magnet.
One or more of those is the problem.
Oh...there is also a saftey switch...in case it tips over. It will also cause the pilot to not stay lit (if the switch or wires that go to i are faulty)
Posted on Jun 18, 2008
  • 333 Answers
SOURCE: dyna-glo rmc-fa100a won't stay lit after releasing pilot knob
You should hold the pilot knob in at least 1 to 2 minutes, if it still goes out you need to replace the thermocouple. I hope this helps you out.
Posted on Nov 29, 2008
SOURCE: Glo-Warm Wall Gas Wall-heater parts...
We had a problem keeping the pilot light to stay on, and this site recommended that it could possibly be the thermocoupler that was causing our problems also. We ordered the thermocouple, put it on,hooked it back up and it worked great! Thank you so much.
ordered thermocouple from www.masterparts.net
Posted on Feb 24, 2009
Pilot light blew out by a fan..I turned the control off..How do I Ignite Please
First locate where to light pilot. You can do this by following thin aluminum colored tubing from control valve to inside heater.In general on top of your gas control valve is a knob. Turn indicator of this knob to pilot and depress knob. This will start gas flow to pilot at end of thin tube. Hold this knob in the depressed position and light pilot. DO NOT release knob for 30 -45 seconds. Then release knob and pilot will remain lit. Then turn knob to on position. If pilot will not stay lit you may need a new thermo coupler, which senses heat from flame to keep pilot gas flow open.
Good luck
Mar 10, 2015 | Heating & Cooling
2006 water heater. Is it only run on gas. How do i turn it on.
If it is a regular gas hot water heater You need to turn the knob on the gas valve to pilot. Depress and hold the knob down. while doing that press the green button on the side of the valve . you may have to repeat that a few times. that button makes a spark to light the pilot. You need to hold the knob down for about a minute more to let the thermocouple heat up and signal the gas valve that it has a flame. release the knob . if the pilot flame stays on ,turn the knob back to the on position. If that does not work repeat if still not working give more info. Make and model of heater
Feb 03, 2015 | Water Water Heaters
Totai heater wont stay on after lit
Without a pilot flame sensor signal the pilot light will not stay on and the heater won't work. Try Replacing the pilot flame sensor, the pilot flame burns on to it and it connects to the valve. It looks like a wire.
Nov 26, 2017 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Can't locate pilot on vulcan lg300
TO LIGHT THE PILOT
1.Open the door. 2. Turn the thermostat OFF The thermostat is located behind the door. 3. Push the gas control valve knob and turn to OFF. Wait 5 minutes for unburned gas to vent. 4. Push and turn gas control valve knob to the "L" in PILOT. 5. While still holding the knob in, light the pilot with a lit flame. Continue to depress the knob until pilot remains lit when knob is released. If the pilot does not remain lit, repeat step 3 through 5. 6. Depress and turn gas control knob to ON
Jun 02, 2011 | Frymaster FPEL217 Deep Fryer
I have a hayward H250 and the pilot lites easily and quickly as long as the gas control knob is depressed on "pilot" as soon as the knob is released to switch it to "ON" the pilot...
Unit dosn't seem to bve sensing flame. Clean your flame sensor. Its connected to your pilot light assembly usually. Its a metal rod that sits inside the flame. Could also be bad and need replaced. Hope this helps.
May 16, 2011 | Heating & Cooling
40,000 btu Charmglo patio heater, brand new, pilot light stays lit as long as you keep the knob depressed. As soon as you release the knob, and turn it to the high position, the pilot goes out! Please...
There is a thermocouple that detects that there is a pilot flame so that main gas won't come on unless there is a pilot. That thermocouple is faulty. These are available from a plumbing supply house. The thermocouple will be attached right in the flame from the pilot and connects back into the gas valve.
Dec 24, 2010 | Garden
How do i light pilot light?
Remove front cover,or just lower section if you can. they usually just need to be lifted up about an inch or so and pulled out. However some have covers that snap in place. After you remove cover locate gas valve. It should have a control knob on top with markings for on, off, and pilot. Set control to pilot. Follow lines from gas valve to burner compartment, one goes to main burner one ,small copper colored line is the thermocouple, other line is the pilot. Turn thermostat down as far as it will go. Make sure gas supply valve in line to heater is on and then depress pilot control , when you have pilot control depressed have a match or other small flame source close to pilot assembly. If it lights then hold down on pilot control for a couple of mins. Slowly release pilot control and if it stays lit turn gas control to on. Turn thermostat up to call for heat and burner should light. If pilot doesn't stay lit when you release pilot control then try again holding pilot down longer. If it still won't stay lit then thermocouple will need replace. Good luck. Thanks
Nov 22, 2010 | Williams 6508732 Gas Heater
Pilot will no stay lighted consequently the main burner will not remain lighted either unless the knob is continually depressed. To alleviate this, I light the burner keeping the knob depressed and at the...
First of all, calm down. This type of problem is typical of many gas appliances.
Are you running propane or natural gas?
Make sure the pilot port is clear of dirt and flows clear. The pilot orifice is tiny, and do not drill it out or anything. Just make sure it's clear.
After you do that, look to see if there is a gas adjustment on the main valve for the pilot flame. It is usually located under a screw on the valve, and the adjustment is actually a screw itself.
Low gas pressure can cause this problem, best seen by watching the pilot flame as the main burner lights. If the pilot flame goes down with main burner light, then it's a gas pressure problem.
If the pilot flame sufficiently covers the thermocouple under all operating conditions, chances are the thermocouple needs replacement (purchased at plumbing supplies or hardware stores.).
Dec 10, 2009 | Williams 2509612 Ceramic Mid-Size Heater
ProCom blueflame heater pilot light difficult to light
You pilot ignator is plugged.I take a small wire and run it in the hole every year and I also Blow the heaters out real well with air.THis has always worked far me.I need a phone number or email address to Pro Com because i'm having problems with a new one i just bought and I can't find the papework.Could you pleas eif you have this info email it to me
Good Luck
Jay
jaycalk@yahoo.com
Jan 07, 2009 | Procom (177653) Utility Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
