Question about Blueant Radio Communications
Blue Ant S4 the pair list is full
Ne Phone. Try Pairing. Device just says pair list is full. No recipe for emptying pair list.
5 Suggested Answers
  • 125 Answers
SOURCE: pairing h700 to sanyo s1
After your phone has found the H700 you have to tell your phone to pair with it. It will then ask for the code. Punch in 0000 and confirm. After a little bit the H700 will flash blue several times rapidly and then start blinking about every 5 or 6 seconds. It is then paired with your phone.
Posted on Jul 13, 2008
  • 14 Answers
SOURCE: Pairing a motorola n136 with a lg vx5500
your phone probably is not capable of syncing into that kind of blue tooth, if not go see your cellphone dealers store they will help you.
Posted on Jan 10, 2009
  • 3230 Answers
SOURCE: where do i find my blue ant password?
password for any Bluetooth headset is 0000.
try this...
Good Luck!!
Thanks
Posted on Jul 17, 2009
SOURCE: Having trouble pairing phone with Blue Ant ST3
  1. If the Supertooth 3 is on, turn it off by holding down the green Multi-Function button for about 5 seconds (until you hear a voice announce "BlueAnt ST3 powering down").
  2. Hold down "Vol " and the green Multi-Function button until you hear a loud siren/distinctive tone.
  3. The Supertooth 3 will turn on. Hold down the green Multi-Function button for about 5 seconds to turn it off again.
  4. The Supertooth 3 has now been reset: all pairing and other information has been deleted. When you turn the Supertooth 3 back on again it will prompt you to select a language and then go into pairing mode.
You will now need to re-pair your phone with your Supertooth 3.
Posted on Aug 25, 2010
Will blue ant Ce0678 pair with I Phone 5s
It does with most Apple products and should with 5S.
Here is a link to try and help. Good luck!
Pairing Your BlueAnt Supertooth 3 BlueAnt Wireless
Aug 23, 2014 | Radio Communications
PS 7200 SYNC WITH SAMSUNG S4 PHONE
Hello. When you pairing a blue tooth with a samsung if required a code it would be 0000 unless is a specific code by the manufacturer.
Fix: turn off the blue tooth on settings on the phone and turn it on. Let the phone scan for devices, if it says found p that should it. When you see it on the phone press on it, the phone and Bluetooth should pair by doing so. I hope this helps. Good luck.
Mar 04, 2014 | Samsung GALAXY S4
I can not pair my phillipson bluetooth #BCK08A to my blackberry curve. How do u pair them together?
Make sure you are in "pairing mode" by holding down the Multi Function Button (MFB) until the red and blue flashing alternately. When the device is off, holding down the MFB for about 5 secs will turn the device on; however, don't release the button and continue to hold until red and blue flashes. Then, you are in pairing mode.
May 06, 2011 | Philips Cell Phones
How do I pair bluetooth from one phone to a new phone? Removing bluethooth from my old phone to another phone.
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Sep 12, 2010 | LG Dare VX9700 Cell Phone
Can not transfer songs from my old phone to my new phone via blue tooth the both phone have connected but when i try to send information it comes up not connected
Hi, you will need pair both phones together before you can be able to send .
Take care.
Aug 20, 2010 | HTC Wildfire Cell Phone
How to connect a blue tooth with cell phone
HOW TOCONNECT BLUETOOTH
Take care.
Aug 08, 2010 | Cell Phones
I need pass key for Jabra BT530 to pair with cell phone.
Take care.
Aug 06, 2010 | Cell Phones
BlueAnt pairing with iphone...help
Just got off the phone with Apple and Blue Ant tech support.
If everything is workon g on both devices you probably need a memory dump on your headset.
1. Power off both devises
2. Power on iphone
3. Power on blue Ant - not in pairing mode - you should see 1 blue blinking light on MFB
4. Make sure iphone bluetooth is on and searching for devices
5. On Blue Ant, hold both volume buttons and MFB at the same time until you get a fast blinking blue light.
6. Check iphone it should now recognize device.
7. When Blue Ant shows up on phone press it so it completes the pairing priocess
Jun 24, 2009 | Blueant Z9 Wireless Headset
I have an audi S4 2007 what is my blue tooth pairing code???
When u want to pair your bluetooth phone the first time, you must do this in the first 30 seconds after ingnition. This is the only period your audi bluetooth carkit is in search mode. Follow these steps to make it work:
Put your bluetooth phone in search mode, then start your car. Your phone will now detect something like AUDI UHV-1 or similar. Connect to this device, and enter either code 1234 or else code 0000. Your phone will then connect. Command your phone to keep the Audi device listed as a save connection, which can automatically connect. The next time you enter your car it will connect by itself (after ignition that is).
Dec 21, 2008 | 2007 Audi S4 Convertible
Radio Communications Logo
110 people viewed this question
Top Blueant Radio Communications Experts
aliasger yq
Paul Chapman
Paul Chapman
Greg P
Greg P
Are you a Blueant Radio Communication Expert? Answer questions, earn points and help others
