Question about Ovens
Manual for firenzi SF904 fan oven - Ovens
3 Suggested Answers
SOURCE: I Have a firenzi oven, the electric went off ,
I have exactly the same problem. I found out that you could hold button 2 down while turning power on, but this didn't work for me... var viewReq = new Array();function vu(u) {var i=new Image();i.src=u.replace("&","&");viewReq.push(i);} vu("http://googleads.g.doubleclick.net/pagead/adview?ai\x3dBQHenXgRHTarfAc6m8AO8mtSYDM-1tesBl4qClxel7-_HBAAQARgBIAA4AVCAx-HEBGC7vq6D0AqCARdjYS1wdWItMzM4NDk0NjI4NTM1MTk1NqABx5L46gOyAQ13d3cuZml4eWEuY29tugEKMzAweDI1MF9hc8gBCdoBSGh0dHA6Ly93d3cuZml4eWEuY29tL3N1cHBvcnQvdDM2NzY3OTAtZmlyZW56aV9vdmVuX2VsZWN0cmljX3dlbnRfb2ZmX3JfbpgC1AepAp9IXDEvwbo-wAIByAKxu74N4AIA6gIkNjE1My9maXguaG9tZWdhcmRlbi9tYWpvcl9hcHBsaWFuY2VzqAMB6AONCugDjwL1AwAAAATgBAE\x26sigh\x3dKqwNoW_2lVE") body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(/wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; }
Posted on Jan 31, 2011
SOURCE: i have a firenzi fan oven but don't know the
there is a manual on-line
Posted on Aug 21, 2011
In all models, is the top oven a fan oven?
look in the oven and if you see a fan then it is a fan oven
Nov 21, 2015 | Ovens
Indesit FID 20 WH fan double oven.when main fan oven turned on the fan does not operate .have to turn off and manually spin fan.turn oven back on and it seems to work.what could be the problem.thanks in...
The fan nneds replacing, as it has a tight or worn bearing/s, the fact that you turn it manually and it then goes, temporarily frees it enough to get it running, but the the only guarantted solution is to replace the fan motor.
Feb 17, 2011 | Ovens
Belling built in fan oven (XOU60FP)is overheating
Have same problem, I am repairing our 648HM double oven. Top oven overheats. I am an electronics engineer. I found that top oven fan has failed, this is the first thing to replace. The grill element also failed which maybe due to the overheating oven. NIGEL
Apr 03, 2010 | Belling XOU174 Electric Single Oven
Dec 20, 2009 | Ovens
I have a ' Firenzi ' electric oven which has ceased to function after a recent power cut. The word ' STOP ' appears on the display. Can you help? Regards Norman Dayton
HI. This will occur when a surge has entered the unit, due to the power outage. Normally, there will be a power surge when the power is re-introduced to the home circuits after a brief outage. This will damage most unprotected electronics in this situation. The most vulnerable area in the unit will be the main control board. I would advise to try a hard rest. You can initiate this by simply shutting down the appropriate circuit breaker, or unplugging the unit for 5 minutes. Once the 5 minutes have passed, kindly re- introduce power to the unit, and try to run a baking cycle. If the word stop, or PF illuminates on the display, this will confirm that the surge has damaged the board. It must be replaced, in this case.
Nov 13, 2009 | Ovens
Omega Europa 20-1 oven. What do the symbols mean?
Fan symbol - defrost (fan only - does not use thermostat)
Fan symbol within a circle - fan forced oven
3 little triangles - static grill (keep oven door open)
3 triangles above the fan symbol - fan grill (keep door closed)
Oct 03, 2009 | Ovens
STOVES fan oven - inlet fan on regardless HOB GRILL or OVEN
It is correct. The exhaust fan comes on to exhaust any heat.
The oven fan is for more even baking.
Apr 22, 2009 | Stoves Premier 600EMa Electric Single Oven
Main cooling fan switches on and off rapidly
hi there,
could i get the exact model # for your stove please?
Sep 14, 2008 | Tecnik Ovens
Ovens Logo
502 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
