Question about Acer AL2023
Acer AL2023 no OSD
OSD out
Where is the on/off switch?
Switching the power
1 Auto) Far left of the 5 buttons on the bottom
2/3 ) On the right
Minus / Plus
4 OSD functions) Second from left
5) Power: the middle button
Adjusting display settings
If the OSD is active, press Auto to exit a selection in the OSD. If the OSD is
inactive, press Auto and the monitor will automatically optimize the
position, focus, and clock of your display.
If the OSD is active, press Minus or Plus to toggle between the OSD
options. If OSD is inactive, press Minus or Plus to adjust the volume.
Press to view the OSD. Press again to enter a selection in the OSD.
Power on/off
Green: power on
Orange: in sleep mode
If the led does not light up at all then either the power lead is faulty or there is no power in the power board.
Feb 14, 2015 | Acer X222W
HOW DO YOU MOVE THE ARROW KEY ONCE YOU ARE IN THE MENU?
You use the button with the <> arrows to move through the menu selections. Use the menu key to select the function you want to change.
Below is an excerpt from the Acer manual. The manual can be found at http://www.retrevo.com/support/Acer-X203H-Monitors-manual/id/23224bh549/t/2/
Front Panel Controls
1.Power Switch:
To turn ON or OFF the power.
2.Power LED:
Lights up to indicate the power is turned ON.
3.Empowering / Exit:
1) When OSD menu is in active status, this button will act as EXIT-KEY(EXIT
OSD menu).
2) When OSD menu is in off status, press this button to select scenario
mode.
4.Auto Adjust button / Exit:
1)When OSD menu is in active status, this button will act as EXIT-KEY (EXIT
OSD menu).
2)When OSD menu is in off status, press this button for 2 seconds to
activate the AutoAdjustment function.The Auto Adjustment function is
used to set the HPos, VPos, Clock and Focus.
5.< / >
Press < or > to select the desired function.Press < or > to change the
settings of the current function.
6.MENU / ENTER:
Activate OSD menu when OSD is OFF or activate/de-activate adjustment
function when OSD is ON.
Jul 02, 2011 | Acer X203H bd Monitor
Why does my Acer monitor display OSD LOCKOUT whenever I start up?
hold the power button for a few seconds it should say osd unlocked.... if that doesn't work unplug the monitor for a minute or so and plug it back in.. that should fix it
Mar 01, 2009 | Acer AL1715 (Black, Silver) 17" LCD...
Acer AL511
Hi...there,
I thinks your OSD Setting time set to high... Open on screen display on your monitor, go to OSD Settings and look for OSD hold time and setting to 10 seconds. If that doesn't work...reset to Factory Resettings.
Jan 12, 2009 | Acer AL511 15" Flat Panel LCD Monitor
Hcl lcd monitor osd locked
my moniter was automatic restarted, and osd lock not open,where is is osd open option?
Dec 19, 2008 | Acer AL1916W 19" LCD Monitor
OSD Lockout
Have you opened the monitor's onboard menu and checked the OSD settings? Do that and see if you can change those settings there. I would also open the Device Manager and check for problems. If you see any yellow question marks, that hardware has a problem.
Sep 12, 2008 | Acer AL1715 (Black, Silver) 17" LCD...
OSD popping up
well most osd problems are occuring due to corruption of the rom chip that holds the data you can flash the data back but... not my fav thin gto do.
a nre video board will be your best course.
Ebay
Jun 09, 2008 | Acer AL1715 17" LCD Monitor
OSD problem on my Acer AL1715 17 in.
I had a simalar problem with my Dell 2001FP. The issue is that there is false triggering of the switch; you need to open the front panel, and remove the swictch from the circuit by: 1) analyze the circuitl; its usally pretty simple - a voltage drop circuit. 2) disable the switch by either removing it with a solder gun or, simply by using a sharp blade and cutting the PCB track leading it to it, as I did.(much easier - and reversible!) Fixed my problem.
Apr 15, 2007 | Acer AL1715 17" LCD Monitor
Computers & Internet Logo
21 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
