Question about Canon imageRunner C3100 Copier
Canon Imagerunner C3100 shows error code E00012-0001
  • 113 Answers
Drum motor error
Check the connector and replace the motor
Posted on Jan 19, 2013
SOURCE: canon c3100 Imagerunner error code E000006-0000
E code Overview
The machine is equipped with a function that checks its state; it runs a check at such times as programmed, and indicates a code on its control panel upon detection of a fault. The tables that follow show codes together with detail codes and the causes associated with the codes and timing of detection. They also offer how these errors may be reset. press (add func)>(2)>(8)>(add func) on control panel u will see service mode 1)press [copier] > [func] > [error] > [clear] 2) reboot the machine
Posted on Sep 06, 2009
  • 5 Answers
SOURCE: error code E00072-0202 on canon imageRunner clc1180
change the brush,cleaning
Posted on Dec 24, 2008
  • 153 Answers
SOURCE: Canon imageRUNNER 2020 alternates between displaying Error Code E019 and saying "Waste Toner Full".
hi you have a waste toner error code, the waste toner is apart of the drum unit in these machines so you will need to order a new drum unit for it.
easiest way to fix the problem.
Canon Tech
Posted on Jun 01, 2009
  • 153 Answers
SOURCE: how to configure imagerunner c3100 as a printer on a network
what do you need to know?
you need to put a static IP address or set it to DHCP and load the canon print driver.
you need to create a tcp/ip port on the ip address of the copier
Posted on Aug 23, 2009
Testimonial: "Thanks for your help. I've had it work since I got now."
  • 108 Answers
SOURCE: What is Canon C3100 error code E000008 0001
Hi, Problem in the Fixing (Fuser) Assy. Fixing roller service life error.
Fix. Replace the Fixing Assembly or have it repaired.
Service manual can be had here;
http://www.techmanualarchives.com/canon-ir-c3100_3170-service-amp-parts-manual-25168.html
Contact me for further help, I think I might have a used one, ultimate_sacrifice@msn.com
Posted on Mar 13, 2010
Canon Ir C3100 Error 000070-0002
A E000070-0002 deals with the transfer belt. I believe it deals with the two tension arms, one may be broken...... It is not easy to get the unit out of the copier.... Good Luck
Jun 26, 2011 | Canon imageRunner C3100 Copier
Canon6570 printer Error Code E000012-0001. thanks!
sir i have a canon 6570 image runner
0001 code is coming again & again
plz ask me what i do
Jan 23, 2011 | Canon imageRunner C3100 Copier
My ImaeRunner C3100 showing an error message i.e. E000070-0001. How to solve it.
Hi. you have to take out the drum unit and clean 2 sensore under the transfer belt unit
Nov 01, 2010 | Canon imageRunner C3100 Copier
When i get my c3100 started i get an error code e 000013-0000 . can you tell me what the problem is
Waste toner bottle full, open front door, one screw, make sure small cut out in the neck of the bottle is clean afterwards.
Oct 31, 2010 | Canon imageRunner C3100 Copier
I have error code e000020-0081 on a conon c3100 copier
You need to clean the image patch sensor, wich is located above the drum unit in copier.Use a lint free clotch.
OR, how many copies do you have with your drum? If over the 60000 replace the drum unit.
Apr 20, 2010 | Canon imageRunner C3100 Copier
The reading of the fixing roller life counter has reached its upper limit.just reach the counter reading at svc mode.
Mar 06, 2010 | Canon imageRunner C3100N Copier
take drum out and clean patch sensor you may need a new drum
Nov 18, 2009 | Canon imageRunner C3100 Copier
Canon c3100 Imagerunner error code E000006-0000
E code Overview
Sep 03, 2009 | Canon imageRUNNER C3200 Copier
E070-003
when i open the printer the unit will int.rot. and then the error will appear. tnx...From Canon Support Product : imageRUNNER C3100 / C3170 Title : E00351-0000 Problem
May 05, 2009 | Canon iRC3100 Printer
298 people viewed this question
old marine
old marine
