Question about Dryers
WTMC3300US/01 need to locate the heater element
    Scholar:
  • 197 Answers
Http://www.ebay.com/itm/Bosch-Nexxt-Dryer-Model-WTMC3300US-01-Fan-Blower-Housing-5070000460-/160948680806?pt=LH_DefaultDomain_0&hash=item257949f866
Posted on Jan 18, 2013
2 Suggested Answers
  • 127 Answers
SOURCE: Need user guide for Bosch Dryer Model
try this link to the .pdf file for your unit..
http://www.managemyhome.com//mmh/lis_pdf/OWNM/L0807475.pdf
best of luck,
ttfn
Posted on Oct 25, 2009
Where is the thermal fuse located on bosch wtmc3300us dryer?
usually located on the blower element and sometimes along the back wall
Feb 26, 2016 | Bosch Dryers
No heat from wtmc3300us Bosch dryer. Pushed reset and the heater started working. Next load and no heat. If it tripped the overload again, what now?
Looks like you may have an over heat problem. Look for a problem with your vent system and pipes. If its partially blocked you will trip the heater over temp thermostat.
Apr 07, 2015 | Bosch Nexxt WTMC 3300 Electric Dryer
How to check heating element
PLACE UR METER PRONGS AND BOTH ENDS OF THE HEATING ELEMENT AND IT SHOULD SHOW ohms OR CONTINUITY A CLOSED CIRCUIT
Mar 09, 2015 | Bosch Dryers
Dryer no heat but runs
no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or
overheating.
The heating elements are located inside the heater ducts. If you think a heating element is faulty, test it with avolt-ohm-multimeter (VOM)set to the RX1 scale. Disconnect the leads from the power terminals and clip one probe of the VOM to each terminal. The meter should read about 12 ohms. If the reading is higher ohms, the heater is faulty and should be replaced. Replace a faulty heater with a new one of the same type and electrical rating. A heater connected to a 115-volt line usually has an 8.4-ohm resistance; a heater connected to a 220-volt line usually has 11 ohms resistance.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
OR you may have a broken centrifugal switch in the motor because this switch activates the motor and the heater as well. supposed to be if the motor does not run , the heater should not heat in order not to create fire but you said that even the motor is not running, the heater is still heating, then there could be a problem with the motor centrifugal switch that is connected to this interlock switch that should trigger the heater.
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
Aug 17, 2014 | Bosch Dryers
Can we install a a ptg 74pvp tankless hot water heater in a closet? Would we need to install grating in the closet wall to provide more fresh air?
Rheem Tankless Water Heater Selection and Installation Videos
  • Introduction - time 04:11
  • Pre-Qualifying the installation - time 01:13
  • Selecting the Right Product - time 01:48
  • Key Differences Between Tankless & Storage Heater- time 01:27
  • Choosing the Location - time 01:20
  • Installation: Major Components - time 00:58
  • Installation: Tools Required - time 00:48
  • Installation: Mounting the Heater - time 01:15
  • Installation: Plumbing & Gas Connections - time 04:29
  • Installation: Side Wall Vent Termination - time 02:41
  • Outdoor Installation - time 01:21
  • Connecting the Remote Control - time 01:42
  • Turning on the Water Heater - time 01:00
  • Commercial vs. Residential Products - time 01:47
  • Manifolding Multiple Units - time 01:43
  • Troubleshooting & Additional Support - time 01:01
Feb 02, 2011 | Rheem Tankless Hot Water Heater...
Bought 01 dodge, 2yrs ago, has 300,000 miless,
Well, Hate to say this to you but your Cummins 24v turbo diesel does not have glow plugs. The fuel temperature necessary for proper ignition is heated by an element inside your fuel filter housing.
Mar 25, 2010 | 2001 Dodge Ram 2500 Truck
Need user guide for Bosch Dryer Model WTMC3300US/01
best of luck,
ttfn
Oct 25, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
Dryers Logo
126 people viewed this question
Top Dryers Experts
