Question about Magnavox 32MF338B 32 in. LCD HDTV
Problem with streaks about 1/2" wide 3/4 up the picture that almost go away after 45 minutes on
  • 1,238 Answers
That is good if still working
Posted on Jan 17, 2013
  • firebug58
    firebug58 Jan 18, 2013
    What kind of solution is that?
Brother 7220 black streaks
Clean the roller and the inside of the machine, asny residue on the roller will cause these black streaks. If cleaning doesn't cure the problem you will need to replace it.
Jan 18, 2012 | Brother MFC-7220 All-In-One Laser Printer
Hi, My Canon 3245 Imagerunner is streaking.
First, the streaks appears when copy from glass or adf, when printing or all?
Solution #1:
How many copies did you do from last drum changing? if over 80 000 copies, replace the drum unit.
-in case that streaks appears when copy and print
Solution #2:
If the streaks appears only if you copy from adf or glass, clean the glass and dry it out. Both glasses, narrow on left side beneath the adf/cover and glass for copy of original.
Solution #3:
If the streaks are wide and solid, with possible toner left overs, you need to replace fixing film.
Hope that helps!
Apr 04, 2011 | Canon ImageRunner 3245 Black and White...
I have a LG 42LB5D 42" 1080 LCD television that
hi, usually you can correct this issue with only a few system checks, dark streaks can be caused by damaged pixels on the screen, in which case you need to replace the TV.
  • Inspect where the dark streaks are on the television. If the streaks occur at the same place on the top and bottom of the screen, they are due to the formatting of a movie or television show you are watching. This is normal. Also, if the streaks appear on the left and right of the screen, they are due to the show being filmed in full-screen instead of wide-screen. This also is normal.
  • Change the input setting so you are viewing the contents of a different device. If the dark streaks are gone, you know they are due to the device connected to it. However, if the dark streaks remains no matter what input the TV is connected to, the problem lies with the television.
  • Inspect the cable connection. Oftentimes when connecting a computer to an LCD TV, you can have strange dark streaks across the screen. Use a DVI-to-HDMI cable connection when plugging in your computer, then press the "Menu" button on your TV remote, select "Picture" and chose "Square Pixel." See whether the image adjusts and the dark streak goes away.
  • Contact the manufacturer of your LCD television if the dark streak remains. This streak can be caused by a defect in the television; if the TV is still under warranty, you can have it replaced.
  • Feb 02, 2011 | LG 42LB5D 42 in. LCD Television
    Dark shadow-like vertical streaks thru LCD screen (Sharp)
    Hi, I have a Sony Grand Wega LCD Projection TV that has a blotted gray streak across the front of the screen. I only use a damp cloth to clean the window and that doesn't seem to help. It really shows up on light pictures and is unnoticed when the picture is a little darker. What can I do to fix this problem???
    Aug 19, 2009 | Philips 32PF5531D 32 in. LCD Television
    Dull srtipe over almost the middle of medium 3 to 4 mm wide
    In the menu under troubleshooting there is a selection called Eliminate Light Streaks. Run it a couple of times that should take care of that, It will blow out the blocked jets.
    Mar 19, 2009 | Xerox Phaser 8400 Laser Printer
    Streaks in prints
    What I would do is remove all cartridges, wipe the belt w/clean cloth use an air can to clean the machine, check the drum on each cartridge see if there is something, it could be there was a change in Voltage and it burnt the drums. change 1 more toner cartridge to see if that color goes away, if it does then you will know if the drums are the problems.
    I've had a problem w gen toners doing the exact same thing, so I had to OEM and it went away. Good luck>
    Feb 02, 2009 | Xerox WorkCentre M-24 Color Copier
    Canon a60 viewer streak
    This is a definate problem with the viewer. Try replacing the batteries first, otherwise ... you will want to contact Canon technical support and seek repairs by calling the number found on your limited warranty card.
    Please mark as FixYa!
    Nov 23, 2008 | Canon PowerShot A60 Digital Camera
    Hitachi UltraVision has blue streak on right side of screen.
    convergent systems.. I callled Hitachi....
    it cost $600 to relpace the part... all 3 colors red yellow blue,.... tech took the part out and will replace it in about 3 or 4 days.
    I was told by technician that it was a very very good tV in fact he said he would buy it from me for $300 and take it away.. I am considering that ... but a new one with Picture in picuture will be 2000 or more
    Apr 06, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
    Black streaks on printout
    Your fuser is worn out. Needs to be replaced.
    Mar 27, 2008 | HP LaserJet 5p Printer
    Magnavox 32MF338B 32 in. LCD HDTV Logo
    26 people viewed this question
    Top Magnavox Televison & Video Experts
    Demonic-2011
    Demonic-2011
    Tom Chichester
    Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
