Question about Jeep Wagoneer XT - Wilderness Stroller
Trouble Steering I just bought a stroller in a grage sale, it's barely been used because the owner had twins & needed something that held 2 car seats. Well, I'm finding it very difficult to steer if we have a child in the front seat. It's like the weight of the child restricts the steering. Is there some kind of repair that we can do, to fix this issue?
  • salhaabd Feb 02, 2009
    wheel driving is veer veer hard and difficulty in adrive please help you .ibuy from garage sale about 100 doller thank you
The steering and suspension systems of the car are fairly robust and generally not too much goes wrong with them. With the advent of rack and pinion steering and the use of MacPherson strut suspension tech, a lot of moving parts have been eliminated. Things still can go wrong and cause a vehicle to become hard to control. When something is wrong the very least that will happen is your tires will wear out very quickly and at most, lead to an accident. In your case... You'll notice it takes much more strength to turn the steering wheel. This is especially noticed when you are trying to park. The problem seems to be getting worse. Possible causes: 1.Low tire pressure: Check and adjust tire pressures. 2.The steering gear needs to be lubricated: Lubricate steering gear parts as required. 3.The wheels are out of alignment: Have the wheels aligned. 4.A part of the steering linkage is damaged and doesn't not move freely: Replace steering gear parts as required. 5.Your steering box needs to be adjusted: Adjust steering box as required. 6.You have a problem with the power steering pump: Repair or replace power steering pump as required.
Posted on Aug 15, 2007
SOURCE:
1. How do I open and fold the DuoGlider stroller? 2. How do I attach an infant car seat?
The steering handle has a red switch on it. Pull the switch to the right and then twist the handle grip forward. The stroller should start to collapse.
Infant seats sit rear facing. You'll have to recline the stroller seat. Then the clip on the infant seat will grab the food tray and lock it in. Your stroller might have come with an additional strap to secure the seat once you have it locked.
Dec 18, 2010 | Graco DuoGlider 7924 Twin Seat Stroller
Trying to lean back the seats on twin stroller
The bar is usually located at the head of the stroller seat. Usually you can feel it by running your hand along the back of the seat. Hope this helps.
Jun 16, 2009 | Evenflo CitiTour Twin Seat Stroller
Need to clean. how do I take it apart to clean the material?
Some stroller seat pads do not come off so if they are very dirty you can spray some shout on it and wash it with hose outside then lett it dry,I had to do this with a bob I found at a garage sale.
May 11, 2009 | Cosco Cameo Stadium Tandem Twin Seat...
I bought a Cosco Eddie Bauer car seat and stroller for my grandson at a garage sale, but I do not know how to put the car seat in the stroller.
@jancstar1: It is not illegal to sell used car seats in the U.S. It is illegal to sell RECALLED car seats.
Apr 25, 2009 | Baby Gear
Opening it
There are two plastic grips on the handlebars of the stroller. Pull both of them upwqards at the same time to either open and lock the stroller, or fold and close the stroller.
Jul 10, 2008 | Graco DuoGlider 7924 Twin Seat Stroller
OPENING THE STROLLER
OK, after about an hour of messing with the duoglider I bought at the local baby exchange I finally figured out how to open the stroller back up. There is two grooves on the red latch. The groove that looks like your finger fits in is the one your looking for. Stick your finger in the groove and push down. The latch will snap right out. It is decieving because it looks like that red latch is screwed on both sides. I hope this helps. Any problems email me at [email protected]
Instructions
Hi jess - below is a link for your manual. It will say it is for the SC-525 but I talked to InStep and they told me they both use the same manual. This has pictures so I thought it would be easier than trying to tell you how to do it. If this solves your problem PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks and have a nice day.
http://www.instep.net/productInstepPDFFiles/97pdf-1.pdf
Jeff
Jun 06, 2008 | InSTEP SC760 Twin Seat Stroller
Bertini twin stroller
I have a used one for sale - where are you located
Jan 11, 2008 | Bertini Twin Steerable - Classic Check...
Eddie bauer/cosco stroller model 01-068 built 2003
Here's their link: http://www.eddiebauer.com/eb/custserv/ae_splash.asp?nv=22376&lp=h2d&referringurl=http%3A//www.eddiebauer.com/eb/cat_splash.asp%3Fnv%3D24356%257C24361 You can either email or call them.
Aug 25, 2007 | Eddie Bauer All-Terrain Tandem 01-068 Twin...
Baby Gear Logo
195 people viewed this question
Top Jeep Baby Gear Experts
Dorel UK
Dorel UK
Marvin
Marvin
john h
Are you a Jeep Baby Gear Expert? Answer questions, earn points and help others
