Question about Video Game Consoles & Games
My gba doesn't work
During power operation it turns on then suddenly the LED indicator turns off
Whenever i on my gba it shows loaded battery at the corner and at the top it shows not responding
Posted on Mar 01, 2009
    Problem Solver:
Your battery is most likely damaged. Buy a new one. Or get a new system.
Posted on Jan 25, 2009
My Notebook all of sudden doesn't power on.
I find that many times when a laptop won't power on either on batty or plugged in, the thing to try is to unplug it, then taske the battery out for about a minute and then put the battery back in and try again.
Dec 13, 2012 | Toshiba Satellite L755-s5248 15.6" Laptop...
Hi, My g. door opener doesn't work. The
5 Blinks on the logic board LED indicates that possibly the motor has overheated. If you have unplugged the unit and waited minimum of 30minutes before plugging it back in, and it still will not operate, then the logic board will need to be replaced.
I hope this helps
May 12, 2011 | liftmaster Chamberlain Garage Door Opener...
The unit beeps
I am getting these directly from the user manual (available here: http://www.apcmedia.com/salestools/ASTE-6Z7VAQ_R3_EN.pdf)
Issue: On Battery - UPS is supplying battery power to the load connected to the Battery outlets.
Visual Indication: Power On LED - ON (off during beep)
Audible Indication: Beeping 4 times every 30 seconds
Stops When: UPS transfers back to Power On operation, or when UPS is turned off.
- OR -
Issue: Sleep Mode - During On Battery operation the battery power has been completely exhausted and the UPS is waiting for utility
power to return to normal.
Visual Indication: None
Audible Indication: Beeping once every 4 seconds
Stops When: Utility power is restored, or if utility power is not
restored within 32 seconds, or the UPS is turned off.
All other issues are CONSTANT tones, which you did not specify, or there are no audible tones associated with it.
Apr 07, 2010 | APC Back-UPS ES 350 - UPS ( external ) -...
The front LED flashes red & blue when I turn it on. What does this mean?
LED Indicators - LaCie 2big Network
The LED indicators above the drive bays and the front LED indicate drive status and activity.
During Startup
  • Front LED – blinks red/blue until both disks are powered on, then turns solid blue.
  • Rear LEDs – blinks red/blue until corresponding disk is powered on, then turns solid blue.
NOTE: If the device is not able to initiate the boot process following disk startup, the front is solid red.
During Bootup
  • Front LED – solid blue
  • Rear LEDs – solid blue
NOTE: If a disk is failing, both the disk’s corresponding rear LED and the front LED will be solid red.
During RAID Synchronization
  • Front LED – solid red
  • Rear LEDs – The LED corresponding to the original disk will be blinking blue and the one being synchronized is blinking red
  • Once both disks are synchronized, their corresponding rear LED and the front LED will be solid blue.
Apr 06, 2010 | LaCie 2 TB 2big Triple Interface External...
Waste inki absober is full. The indicator orange
You can remove the top of the printer to remove and clean the pad or reset the printer and continue without cleaning.
These are the instructions which worked for me on my Canon pixma ip470 and has work on many other Canon models:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Feb 15, 2010 | Canon PIXMA iP90 Mobile Printer
Indication light "RED" on continuously during operation. Unit fires up, heats up and blows hot air. Why is LED "RED" on when unit shuts down?
not knowing wich one is on, this red light could be your power indicator light..
it stays on during any operation,
you should be able to see it through the sight glass
if it were flashing,,,, there would be a problem
Oct 13, 2009 | Goodman GMS90703BXA Heater
Panasonic NV-GS50 - Display indicates "To Service"
This means you need to get it serviced, because it has detected a fault or error.
Sep 06, 2017 | Panasonic NV-GS50 Mini DV Digital...
DS light will not turn on
well charge fur about a week it happend to me and this worked
Oct 01, 2007 | Nintendo DS Lite Console
GBA SP Backlight not working
The Back Light is an led under the frount of the display.
you might try to see if it geting power or bad.
Sep 14, 2007 | Nintendo Game Boy Advance SP Console
Video Game Consoles & Games Logo
173 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
