Question about Drive MedQuip MQ 6000 Compartment Compression Nebulizer
Mq6000 compressor works, plenty of air, but no mist
Tube and mouth piece clear of debris
My Hi Super air conditioner is leaking into the house. What is the problem and how can I fix it?
It is just the condensation generated by the cooling which has to be drained from the unit via a drain tube. When the drain tube is blocked by debris (often by dust build up) the water cannot drain out and will overflow from the unit. Often these blockages will occur where there is a bend in the drain tube and sometimes these drains are not installed very well.
Open the front of the unit and locate the drain tube. You will need a long piece of strong wire or cable to run down the tube to try and free the debris and get the water flowing again. You can do the same at the other end of the tube also if need be. You may need to tip some water down the tube to help clear it also.
I think you will find it is fairly easy to resolve yourself.
Jan 08, 2016 | Heating & Cooling
Husky Air Compressor wl660800AJ...my problem is the compressor will not shut off after it reaches the shut off pressure it keeps running? checked and supply tube clear....
Hello
Replace the pressure shut off switch.First drain the tank and shut off all power.Remove switch and inspect for any debri or water in the tube to the switch.
Also check the settings.max i think is 150psi.So it should fill to say 145 and shut off.
Sep 26, 2011 | Air Tools & Compressors
Rinsed my humidifier with water and wiped the base down, refilled it and now it seems to be making the mist in the base butbisnt making it's way out of the mouth of the dolphin
The tubing to the mouth of the dolphin or the misting nozzle is clogged with mineral buildup and scale.
To clean this, do the following.
Empty the water in the tank and replace it with a 50/50 solution of White Vinegar and Bottled Distilled Water. Allow the unit to sit for 30 minutes, then turn it ON. If mist does not appear within 10 minutes from the mouth of the dolphin. Turn the unit OFF and allow it to soak over night. In the morning, turn the unit ON and allow it to run. Once the mist appears where it should, run the unit until the tank is half empty. Then empty the tank of the remaining solution and refill with Bottled Distilled Water and run the unit until it is empty. This will flush all the remaining solution from the tank, tubing & nozzle.
In the future I would recommend using Bottled Distilled Water on a regular basis, rather than tap water. Doing so, will eliminate the problem of scaling.
Hope this helped you and thanks for choosing FixYa.
Sep 07, 2011 | NewAir AU-200E Humidifier
Transmission oil leak, clear fluid on passenger side , when ever car stops
Probably Air conditioning condensation (normal) or rain water build up in wiper motor area due to leaves or other debris clogging the drain tubes. If its leaking in car the drain tube into the engine compartment is plugged up. Just needs unplugged with compressed air or a piece of wire.
Aug 15, 2010 | 2001 Daewoo Nubira
My Nokia 6303c mic is not working,when i make a call I cannot be heard
The problem is that the mouth piece on your phone is malfunctioning that is why people call or people that calls you barely hear you.
All you need to do is to replace the mouth piece of your phone and you will see that after the replacement of the mouth piece, anybody that call you or people you call will hear you clearly.
Just change the mouth piece as advice and you will see that the problem is solve. meanwhile, you can be using hands free pending the time you will replace the mouth piece.
Take care
Aug 04, 2010 | Nokia 6303 Cell Phone
Water in ac box
Take a stiff piece of wire, something like a coat hanger. Bend the end over so it will not catch on the drain tube. Push it up into the drain line as far as it will go. If this does not clear it then you will need a flexible wire of some sort. You can try an air compressor and blow into the drain line but do not use much air or you will do damage to the line. A slight amount of air pressure may remove the obstruction. If that does not clear the drain then you will have to get to the drain from inside the vehicle. First try getting to the drain line and squeezing it together. That may just be enough to dislodge the obstruction. If not you will have to completely remove it and clean it out. Good luck.
Jul 12, 2010 | 2004 Mitsubishi Endeavor
Water is not draining properly from the air conditioner condenser
did you find where the drain out put is in the air conditioning assembly box located on the firewall. It should be a clear or black hose coming off of the air conditioning assembly. If you use a coat hanger or a piece of wire about the same diameter of a wire coat hanger and use the wire and stick it up the hose to clear the debris out of the way(probably leaves and such pretty common).
Oct 12, 2009 | 2004 Mitsubishi Endeavor
Washing Cycle won't start
Check the fill control switch. It has a small tube going to it.Clear the tube, and use a piece of tube to blow into the switch, it should click at about one to 2 psi, no harder than you can develop with your mouth. Make sure debris is not getting into the tube from the drum.
Apr 28, 2009 | Washing Machines
My solution in the nebulizer is not foaming or misting!
you may need to switch out your mask unit, the cup the medication is put into has a very tiny hole for air to circulate through. if that hole has been tampered with, or is partially clogged you will not get a mist. you should change out your mask and tubing regularily for sanitary reasons.
hope you get it running again!
Mar 20, 2009 | DeVilbiss PulmoMate Aerosol...
Very little mist coming out
You'll read a lot about making sure that the filter is clean and that the medicine cup is cleaned and that hard water can effect the operation of the nebulizer. However, the problem is most likely in the pump. Even though the pump is running, it is not pushing enough air into the medicine cup. You may even feel air coming out of the tube. When unrestricted, the air will come out, but, once restricted by the medicine cup, the air may not be fast enough to nebulize the liquid. If you want to confirm this, take the tube and hold it to the end of a bike pump, if, while pumpung, you successfully see mist, then you know for sure.
Fixing the pump is not too difficult. Over time, the chamber where the air is compressed becomes dry and, just like a dry bike pump, the air escapes from the chamber due to poor seals. The pump is pretty simple. Make sure it is unplugged from power and remove the screws holding the housing together. Inside you will see the motor, a fan, a power switch and the intake and outtake tubes. Follow the outtake tube to the pump. The junction where the tubes meet the pump is the location of the air chamber. You may need to remove the screws that secure the tubes to the chamber. Once apart, take some grease and lightly coat all of the interior surfaces of the chamber. When finished, reassemble and you're good to go!
Jan 25, 2009 | Mabis CompMist Compressor Nebulizer
Drive MedQuip MQ 6000 Compartment Compression Nebulizer Logo
26 people viewed this question
Top Drive Health & Beauty Experts
Colin Taylor
ray gallant
Are you a Drive Health and Beauty Expert? Answer questions, earn points and help others
