Question about Hotpoint Dishwashers
Hotpoint slimline dish washer comes up error
Error comes up on digtal display
    Sergeant:
    Champion:
  • 249 Answers
What error comes up when you try to start the unit
Posted on Jan 17, 2013
  • 171 Answers
SOURCE: Dish washer is not working
Hi kssami9,
I'm Harvey the Master Plumber.
Your problem is: Your dish washer kenwood model kdw243a is not working and displaying the error code E3 please give you the solution.
First try to reset the d/w. Just turn it off at the circuit breaker for ten minutes.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 28, 2008
SOURCE: hotpoint dish washer aquarius
I had the same problem with my Hotpoint Aquarius the eco and fast light flashing, it would go through the pre wash cycle and stop.
I cleaned the filters etc; and it still didn’t work.
I turned the machine off and unplugged it at the mains,
I drained all the water, turned the machine on the side and took the bottom off, I removed the drain pump off the bottom (this was held on with a single screw after taking the screw out slightly turn it to one side as its like a bayonet fit on a light bulb also remove the wire connection and a rubber drain pipe)
Once the pump was removed I could clearly see the impellor it was very tight and I couldn’t spin it after a closer examination I could see a foreign object jamming it I removed this with a pair of tweezers, replaced the pump and put it all back together and it now works perfectly.
I hope this can be of some help.
Peter.
Posted on Dec 17, 2008
  • 221 Answers
SOURCE: Dish washer not filling with water when put on
There are a few things that can cause this problem, it could be a defective water inlet valve, it's usually located behind the lower kick plate on the left or right hand side of the dishwasher, When the washing cycle is started it sends voltage to the water inlet valve to open which allows water to enter the machine, or it could be a faulty float switch, when water enters the machine the float switch raises up which signals the water inlet valve to shut off, the float switch is located inside the dishwasher at the bottom, you can check the float switch by raising it up and down to see if it's stuck in the up position. Good luck.
Posted on Mar 21, 2009
s_s_m_o_k_i_
  • 162 Answers
SOURCE: hi, i have a hotpoint slimline SDW60 dishwasher
download the user guide here >> http://kitchen.manualsonline.com/manuals/mfg/hotpoint/hotpoint_dishwasher_product_list.html
Posted on Jul 29, 2009
  • 6 Answers
SOURCE: Whenever I switch on the dish washer, it displays
You might want to check and see if the dishwasher has a plug in to the wall or hard wired to a box but you might try killing the power to the dishwasher for a few mins and let it reset itself
Posted on Aug 17, 2009
What does error message F-10 mean
Please consult the electrical schematic attached to the machine. It's has all the error codes listed and what to do to troubleshoot.
Jan 03, 2016 | Hotpoint Ultima WT960P Washer Front...
I have an hotpoint sdw60 dish washer that is flashing 2 yellow lights, these are numbers 5 and 7 (fast and dry 40c) and (delicate 50c) can anybody tell me what this means.thankyou
Hotpoint Indesit dishwasher flashing lights fault error codes ...
? 15:08
www.youtube.com/watch?v=FRLbrBPHcnE
May 3, 2015 - Uploaded by how-2-repair.com
http://www.how-to-repair.com/help/hotpoint-aquarius-fdm-dishwasher-flashing-lights-and-there-fault-codes ...
Oct 02, 2015 | Hotpoint Dishwashers
Hotpoint aqualtis aqgd169s no power wont turn on not even had an error code come up
If the machine is dead, I would check the cable from the main boad leading to the front display on the door. Often the cableharness breaks at the hinge. (one of cables). If that is not the case, eather the main board or display board is dead.
May 26, 2014 | Hotpoint Ariston AW125 Front Load Washer
Close door error on display when door is closed on WDM73
Th eswitch that teel it that door is open is out of position or bad.
Jun 19, 2009 | Hotpoint Ultima WDM73 Front Load Washer /...
Machine wont work and flashes f12 on function display
F12 is classed as a communiction error.
Either faulty connections or electronic panel
May 27, 2009 | Hotpoint Ultima WD72 Front Load...
F13 error during drying cycle
Hi, that indicates that either the fan motor is not working/ blocked or the dryer thermistor (thermostatic sensor) is playing up. Of course, the pcb reads the sensor so it could also be that causing the error.
May 06, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint WF860 Washing Machine displaying error F-65
there is no F65, perhaps it's F05 which means it will not empty water (not oumping out). Should av gone to specsavers !
Apr 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hi kssami9,
Thank you,
Sep 27, 2008 | EuroTech Dishwashers
Hotpoint WF640
the f-01 error code on your hotpoint all in 1 washer/dryer is a short circuit code for the motor. the only way to clear the code is to have a service tech come and inspect the reason for the error.
May 12, 2008 | Hotpoint Aquarius WD640 Front Load...
Dishwashers Logo
53 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
