SOURCE: front loader won't spin and
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
SOURCE: water fills in, but wash cycle won't
Its either in the lid switch or timer. Examine the lid switch. Try starting the wash cycle and press in on lid switch to make sure it activates. If the lid switch is good and you dont hear the motor trying to activate during wash than its in the timer. Does the timer advance? Please comment me back If you need further assistance.
SOURCE: Kenmore washer 90 series continue
Sounds like the fill switch needs to be replaced. A good way to test it is to set your machine on low fill and see if it fills past 3/4. If it does, it's the fill switch.
SOURCE: We pulled our stacked washer
Hi, I got a samsung WA85B5 washing machine running for nine years already, but last week the electronic mulfunction in such a way that when the power plug is turn on, the electronic turned on automatically without pressing the 'power' button and non of the button on the panel works. I installed a new circuit board today but ends up a different problem. After I plug in the power I press the 'power' button and the LEDs light up, all the other buttons function properly ( delay timer, water level, function,course) except the 'start' button. After setting everything it refuse to start. Please help. Thanks in advance. Yip
Hello John,
The most probable reason the washer is not filling is because of a blown fuse that is part of the lid switch asm. By UNPLUGGING THE WASHER and removing the 2 INNER screws on the the control panel and the control panel can be rotated down to see the fuse in the lid switch asm. Here is where the fuse is on the switch asm. its circled in red
Hello & Welcome to FixYa
Dishwasher not filling problem is caused by clogged inlet valve, first try to clean the inlet valve and the water line coming to the inlet valve. If the issue returns replacing the water inlet valve is recommended repair. Please get back to me if you have any other questions.
Kevin
