Question about The Companion Group Kozy World Portable Companion Heater
Cannot get pilot lit burns blue flame but goes out
Gas log set was working but click sound went out now pilot burns blue but wont stay lit
    New Friend:
    Problem Solver:
  • 7 Answers
The best approach first would be to blow out the dust. There are one to two breather ports that easily get clogged. If that doesn't work it may be a bad thermocouple. It can be checked with a volt meter set to multicolored. Disconnect the thermocouple from the valve and attach the black lead to the thermocouple itself and the red to only the tip that makes contact inside the valve. Light the pilot and hold in button to begin watching the readings. 18-24 millivolts is the desired range.
Posted on Feb 10, 2013
3 Suggested Answers
  • 47 Answers
SOURCE: I just bought a brand new Kozy World blue flame
The thermocouple is bad or not aligned properly. It is the metal bar in front of the pilot light. This bar senses the heat put off by the pilot light. If it does not get hot it will not allow the gas to flow. You either need to align it so that it is in front of the pilot light and receives enough heat to allow the gas valve to operate or possibly the thermocouple has gone bad and needs replacing.
It could also be that you are not waiting long enough. The thermocouple must sense the heat for at least one minute or more before it will let the gas valve turn on. Turn everything to off for at least five minutes. Re-light the pilot light and let it burn for at least one minute and then try turning the knob to on.
Posted on Nov 25, 2010
heatman101
  • 43501 Answers
SOURCE: the pilot works and the flame comes on but when
Uswually when that happens it is because the pilot is too weak... the pilot is not focused on the thermocouple properly or the thermocouple is weak...
You will need to figure out which of these things are causing your problems...
heatman101
Posted on Jan 04, 2011
Pilot light wont stay lit on gas logs
If the pilot lite comes on, but will not stay on after it has had enough time to heat the thermocouple, you got a bad or the wrong thermocouple. It does take some time to heat that thermocouple.
Nov 26, 2013 | Woodland Direct CD Vent Free Gas Log Set...
Totai heater wont stay on after lit
Without a pilot flame sensor signal the pilot light will not stay on and the heater won't work. Try Replacing the pilot flame sensor, the pilot flame burns on to it and it connects to the valve. It looks like a wire.
Nov 26, 2017 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rheem 22V50F1 pilot won't stay lit. Changed thermo couple & it lit, ran then went out. Let it sit overnight & it lit, ran then went out. What next? p.s. The unit is 5 years old. Thanks
If pilot lights and flame is robust and clear blue, and pilot goes out later, then some suspects can be excluded: air in gas line, low gas pressure, thermocouple is overtightened (finger-tight + 1/4 turn), thermocouple not positioned correctly in the flame, dirty pilot tube.
If flame is yellowish and small: then clean pilot tube and combustion parts.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Remaining suspects can include: air in gas line, low gas pressure, bad gas control valve, tight house so household vent fans pull air down water heater vent that blows out pilot, hot attic with inadequate ventilation, water dripping down vent.
Open following links to read troubleshoot resources.
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Aug 16, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
5yr. old aquastar 125x lp wont stay lit after about 5min. use. just started happening out of the blue... a clicking noise preceeds the flame shutting off. any ideas?
The gas valve makes a single click sound when the pilostat shuts off. That is a safety holding coil for units with standing pilot lights and closes if it thinks the pilot went out. In electronic ignition, the same holds true except the sensor is electronic.
Mar 31, 2011 | Bosch & Tankless LP Hot Water Heater
I have an Empire gas heater. It does not stay lit. It will go out after about 30 minutes to two hours. When we first started having this problem if you set it where it wasn't completely level it would stay...
Look at your thermocouple. Is it glowing red from being heated by the pilot flame? Is the pilot flame blue or yellow? You may have a dirty pilot orifice that is not heating your thermocouple enough to keep it lit after the burner cycles off. A yellow flame will eventually burn the tip of the thermocouple, which causes more frequent problems and eventually it will not work at all. If you have a can of compressed air with attached straw, use it to blow out the pilot orifice (with the gas off) where the pilot flame usually burns. Then examine the tip of the thermocouple and see if it is still round and smooth. Jagged or irregular tips mean it should be replaced. A blue pilot flame and a new thermocouple should do it. Hope that fixes it for you. Douglas
Jan 04, 2011 | Heating & Cooling
My 30,000 btu Blue Flame gas wall heater wont stay lit, pilot light stays lit but the blue flame went out and had smell of gas I shut off the gas supply but, dont know what is the problem thanks, marty
you could have a overdraft problem causing your flame to go out. check your draft setting at the burner and make sure it's not open too wide. If it is, simply close it it slowly and make sure that the flame remains totally blue.
Nov 27, 2010 | Heating & Cooling
My pilot light kept going out. I cleaned it
You may have to get a new thermocouple.
This is a small copper tube that goes from the pilot light area to tha gas valve.
It feels the heat from the pilot and keeps the gas valve open for gas to flow to the pilot or to the logs when in the lit position.
Without the gas valve will stay closed.
Jan 06, 2010 | Vanguard International Blue Flame - Medium...
Pilots lites , holds ok for minutes,but once move
Hello KJGreen, It sounds, based on your description, as though the thermocouple is faulty and should be replaced. If the pilot light stays lit and you've left it on for several minutes before turning the knob on to light the log set, then that indicates that the thermocouple is bad.
The thermocouple is a safety device (heat sensor) designed to stop the flow of gas to the burner in the event the gas flame goes out and the pilot goes out. The sensor will only allow the gas valve to open once it has reached the preset temperature.
To confirm that the thermocouple is defective, I would light the pilot light and allow it to remain lit for up to 10 minutes before I attempted to turn on the log burner. If, after 10 minutes, the log burner still won't stay lit, then you know that the thermocouple needs to be replaced. Otherwise, the burner should light, since after 10 minutes, the sensor should be hot enough to signal the gas valve to open.
If you are going to have this replaced, please make sure you use only an approved supplier, since an incorrect replacement part could cause an unwelcome malfunction of the gas log burner. Safety should be primary when dealing with open flame burners.
Hope you find this Very Helpful and best regards!
Nov 23, 2009 | Vanguard International Infra Red - Large...
Pilot lites; but, as soon as I turn on gas flame
sounds like your thermacouplar is going out and needs replaced. Sometimes these will act like they are working fine , but when the pilot stays on for awhile and later goes out it is a sure sign that it is bad
Nov 08, 2009 | Procom ML300TBA Heater
Blue flame heater pilot wont stay lit
There is a therma-couple that the flame burns against. When it is working correctly it allows gas to travel to the flame. When it goes out you get no gas, as a safety feature. Replace the therma couple and it should work again.
Oct 06, 2008 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Heating & Cooling Logo
107 people viewed this question
Top The Companion Group Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a The Companion Group Heating and Cooling Expert? Answer questions, earn points and help others
