Question about GE Nautilus 24" Built-in Dishwasher
Dishwasher not washing - GE Nautilus 24" Built-in Dishwasher
    Sergeant:
    Champion:
  • 249 Answers
What is your problem you are Experiencing right now
Posted on Jan 17, 2013
Bosch classixx dishwasher not heating water on cooler wash works on hot wash
Most dishwashers don't heat the water. They run on whatever temperature water you have it set for. They have heating coils on the bottom but that's for drying, not heating up the wash water.
Nov 30, 2014 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
What is the sequence to reset kenmore dishwasher 665.16719000? The buttons from left to right are pots/pans, normal wash, water miser, china gentle, quick rinse, high temp, air dry, delay wash, start
Press "high temp wash, heated dry, High temp wash, heated dry, high temp wash, heated dry, high temp wash, heated dry, high temp wash"
All the lights will go solid at which point you press cancel to reset the board.
**NOTE** if you don't have a "heated dry" button, use the "air dry" or "energy saver dry" button instead.
Apr 03, 2014 | Kenmore 24 in. 16052 Built-in Dishwasher
DISHWASHER GE PDW7800J00BB DOES NOT WASH ,FILLS WITH WATER BUT NO WASH
It is unclear from your description if the wash pump starts and pushes the water around but never stops cycle or the dishwasher stops as soon as the water is filled.
If you do not hear the wash pump start then it is possible the wash motor is faulty. But if the wash pump starts and never completes the wash cycle then it is possible the heater is faulty and dishwasher is waiting for water to heat up before it can go to next cycle.
See the attached diagram for location of wash pump motor and heater.
Hope this helps you find the problem. Please rate the solution if you found it useful.
Oct 10, 2010 | GE 24 in. Profile PDW7800 Built-in...
Normal wash light blinking, d/w wont start
Wish I could solve this, as I'm having the same problem too. Normal light blinks not matter which wash button is pressed. Cancel light will light, but still NOTHING happens. Same model as yours.
Jul 23, 2010 | Kenmore PRO 24 in BuiltIn Dishwasher with...
Do these 'portable' dishwashers 'heat' water prior to washing? i have customer complaining bout the dishes not coming clean..yet the water entering the dishwasher is cold, does not appear to heat water...
Most dishwashers require a minimum 120 degree inlet water temp. The heating element will boost this up during the main wash cycle to aprox 140. Do not hook a dishwasher up to inlet water temps above 150.
Feb 06, 2010 | GE Hotpoint HDA3500N Dishwasher
Dishwasher not spraying/pumping water in wash cycle
If your dishwasher is filling, draining and the heating element is working then the wash pump motor has probably failed.
You have not provided the manufacturer and model number, so I have no way of knowing if your dishwasher has a separate drain and wash pump motor.
May 03, 2009 | Dishwashers
Frigidaire fdb1050rem2 dishwasher will not drain during was cycle
Checked water temperature at water heater. It was at 110 degrees. Turned water heater up to 125 degrees. Dishwasher works perfectly now.
Mar 30, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
My carlton dishwasher fill and drains but does not wash
sounds as though the wash motor/pump is jammed or has seized therefore no wash.
Mar 16, 2009 | Maytag 24 in. MDBH965AW Built-in...
Maytag dishwasher
Many dishwashers now have seperate drain and wash pumps. Often the wash motor stops because something is caoght in impeller. You need to remove lower wash arm then take of cover...should be torx head screws to get to impeller.
Nov 06, 2007 | Maytag MDB9600A Jetclean II Built-in...
GE Nautilus 24" Built-in Dishwasher Logo
35 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
