Hi! I need to fix a friend's computer, and the problem is that lot of errors appear when I am turning it on, and to be able to run the windows I need to press F1 tot go to Bios, than exit and save changes,and than press F2. Only after that windows will start loading. Then I turn on the computer I get the following errors: 0194ystem security: Asset ID Antenna has been removed 0162:Configuration error - Default configuration used 0197ystem security. Unauthorized CMOS change detected 0192ystem security: IBM Embedded security hardware tamper detected ERROR: System security:IBM Security hardware reset ERROR:Administrator password and boot sequences have been cleared
    Novelist:
  • 250 Answers
Simple tips to fix this issue:
  • Clean the Temporary Stuff and Browser Cache
  • Remove Obsolete Registry Entries
  • Disable Startup Programs & Services
  • Customize Windows for Best Performance
  • Uninstall Programs and Disable Windows Features
For Instant Fix use Reginout system utility.
Posted on Jan 18, 2013
SOURCE: BIOS Password
am not able to reset BIOS password even after removing the CMOS battrey. I need to change the boot sequence, please help.
Posted on Dec 06, 2008
sparky1500
  • 1066 Answers
SOURCE: Toshiba Satellite M45-S169 won't boot
you must restore your bios settings to the correct ones. contact toshiba customer support for the correct toshiba settings.
Posted on Dec 24, 2008
  • 101 Answers
SOURCE: I CANNOT BOOT MY IBM THINKPAD 2367..HELP
Both errors are related to the backup battery which is located under the main battery. It is probably dead. You can get one on eBay for $3.29 w/free shipping or pay a shop $20 to put one in. If you do it yourself be very gentle plugging it into the tricky little slot - it is possible to break the connector loose from the motherboard but it is an easy repair if you have patience and dexterity. As for the password, try just hitting enter. It is the supervisor password to change the BIOS settings and was probably never set.
Hope this helps.
Jon
Posted on Apr 13, 2009
  • 4 Answers
SOURCE: I forgot the master BIOS password.
disconnect the intal cmos battery, there may be a jumper near by, j1 or something like unconnect the jumper, whilst the cmos battery is disconnected switch on the laptop, then let the post screen load, switch off, re-connect the cmos battery and re-enable the jumper, switch on, should work fine now, if you don't see the jumper, you won't be able to reset the bios password, refer to a service manual for your laptop model for the location of j1.
Posted on Apr 04, 2010
CreativeTECH
  • 1719 Answers
SOURCE: laptop not used for some years. could enter bios
I received an IBM laptop with same issue a few months back. The error message due to the drained out CMOS RTC (coin-cell battery), which retains and other BIOS settings.
The system is OK and all you have to do is to get the CMOS/RTC battery replaced by the a professional.
Good Luck!
CreativeTECH
Posted on Dec 31, 2010
Poor performance very slow lots of viruses on samsung npr519
1st Condition:-
Laptop runs slow issue may appear if the system is infected by some malicious application. You have to search and remove that application from your system. For your convenience download and install a powerful antivirus program.
2nd Condition:-
Mostly laptop runs slow issue occurs due to broken Windows registry entries. Fixing registry will help you to boost up your laptop. You need to download and install a Registry Cleaner program to fix corrupt or broken registry entries. To download a reliable registry cleaner, go to famous website download.cnet and search there Reginout. Which I personally use and recommend the friends. After downloading run all of its tools one by one except Internet Optimizer, to clean all the junks and registry errors from your computer.
Thanks
Oct 11, 2013 | Computers & Internet
Error 0xc000000f while formatting hard drive
try some formating toos .. like hiran boot cd or disk or diskformater ...u can use usb bootable device to install windows, u can make ur personal pen drive to bootable pen drive.
Jun 02, 2013 | Packard Bell Computers & Internet
My desktop sceen shows Blue screen with error memory dump contect ur hardware vender
Try running the Check Disk Utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
May 14, 2012 | Computers & Internet
I need to change computer font
right clik on desktop go to properties
display properties will show go to appearance tab
click on advance change the item box and font to display in xp
Sep 22, 2011 | Microsoft Windows XP Professional
My pc is running really slow... can u please help me????!!!!?????
There are a number of reasons but mainly 2 kinds causing a PC running slow. Outdated hardware or poor system maintenance. If possible, try upgrade hardware configuration such as add more RAM etc. Otherwise try this program Speed up PC to diagnose & fix the slow pc for issues. Best regards!
Jul 17, 2011 | Computers & Internet
My text and my friends texts don't appear on the screen but appear in the editing window but after pressing enter it disappear. i tried to uninstall all the other messangers and players from my pc...
Good Day Dr_Mosaeed!
I know how hard it feels when you want to communicate with others using Yahoo! Messenger and you can not because the message you type will not appear on chat window. And even the message that your friend send to you will not appear.
Dr, this problem is usually caused by an Internet Explorer glitch that block the execution of the scripts in Yahoo Messenger.
You can fix the error by enabling the scripts in Internet Explorer.
Here is what you must do to repair the problem and to assure that it will not appear again:
First, download the latest Internet Explorer version 8 and install in your computer.
To download, go to http://windows.microsoft.com/en-US/internet-explorer/products/ie/home - choose the operating system you are using before hitting the Download button. Once downloaded, run the application to install Internet Explorer version 8. Once completely installed, run the Internet Explorer.
Secondly, enable the scripts in the Internet Explorer.
While Internet Explorer is running, press the Tools menu and navigate to select Internet Options.
When an Internet Options window appears, select on Security tab. Click on the Internet Globe icon and press Custom Level... button.
When Security Settings - Internet Zone window appears, scroll down and navigate to ActiveX controls and plug-ins and Scripting.
Make sure
the following is enable:
Under ActiveX controls and plug-ins
* Script ActiveX controls marked safe for scripting - enable
Under Scripting
* Active scripting
- enable
* Scripting of Java applets - enable
Once it is enable, press the OK button. Press Apply button and hit OK. Close the Internet Explorer.
Lastly, if your Yahoo Messenger is running, you must restart it. Please, you do not need to reboot your computer.
Then, try opening a chat window and type a few words before hitting Enter. See if your message finally appear.
Hope this fix will solve your problem. If not, just leave a message here and will try a thorough analysis with your chat message problem.
If this will fix your problem, please do not forget to rate my answer. A simple press on the YES button will show your appreciation.
Thank you for asking Fixya.
Jun 18, 2011 | Yahoo Messenger
I open my new laptop (Toshiba) when i try to boot the system and instal windows XP this message was appear: A problem has been detected and windows has been shut down to prevent damage to your...
Hi. You need to try install other higher windows version like windows vista or windows 7.i already encounter that problem i fix it using windows 7 installation.try it's work.
Jun 03, 2011 | Computers & Internet
My laptop computer is running slow? how can get rid of junks stuff on the laptop?
Your friend is a program called CCleaner. Run it, rerun it, do whatever you need. It's heavenly.
http://download.cnet.com/ccleaner/
May 24, 2011 | Computers & Internet
Hi Experts! I was using WD essentials 1TB and till two weeks I was working brilliantly, and all of a sudden the Hard disk drive stopped appearing in My Computer ( I am using windows XP). I can see...
There are several walkthroughs on how to recover data
Try loading Windows Recovery Environment on Windows 7 disk
1. First we will be needing a windows 7 dvd (Any windows 7 disk will do ..home, ultimate...etc.)
2. Boot the windows 7
3. under the Install Now windows, click on Repair your computer
4. Choose Command Prompt among the list
5. type Notepad
6. From the Notepad GUI (Graphical User Interface) -> Click File -> Open
7. Open windows will appear
8. Try to path where the external hard drive is in. And select all files that you need to save. By simply copy and paste from where you want to save the files in
Hope this helps
May 19, 2011 | Western Digital - My Passport Essential SE...
System restore utility not getting activated by known methods
I'm a certified computer tech and have been doing this for years. system restore often causes more problems than it fixes. I recently ran into this issue on a friends computer. upon investigating his computer was infected with a nasty virus that infected all of his restore points. go to housecall.antiviurs.com or another security website and run a free online virus scan. check that first, if that isn't the problem try manually going into system restore and running it (start > all programs> Accessories > System Tools > system restore). it may be able to be fixed with the system restore. if not you may want to consider either taking it to a technician or backing up your files and reloading the comptuer.
Apr 17, 2009 | Computers & Internet
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
