Question about MotoBatt 2000 aprilia rs50 cc battery
Iv got a problem with my aprilia rs50.
Idles but when you go for the gas it just sounds like its dieng...doesnt seem to be a fuel problem but i could be wrong? i think the 2 stroke pump isnt working so i have put some oil in the tank please someone help i have a video of thr problem aswell
Aprilia rs50 starts then dies out in ten seconds or so. Sounds like fuel starvation. Or could a dodgy plug do same thing?
Hi Anonymous, the following applies to carbureted also fuel injected models and the usual suspects are:
1. Severely discharged or damaged battery, 9 volts or lower.
2. Faulty alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Faulty main circuit breaker or ignition switch, check for loose connections and continuity.
5. Faulty system and or ignition relay, check for continuity.
6. Faulty ignition coil, ignition/electronic module.
7. Faulty CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Water or dirt in the fuel system, carburetor or filter.
9. . Restricted, blocked or kinked fuel line.
10. Fuel tank empty.
11. Gas cap is not venting properly or fuel tank venting system blocked.
12. A faulty fuel pump, pressure regulator and or fuel injectors.
13. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
14. Needle and seat stuck closed in the float bowl.
For more information about your issue, please visit the websites below. Good luck and have nice a day.
https://www.tradebit.com/filesharing.php/search/0/aprilia+rs+50+motorcycles
Feb 28, 2015 | Aprilia RS 50 Motorcycles
Aprilia rs50 pulls off very slow
Hi, Anonymous and the usual suspects are:
1. Throttle cables misaligned or misrouted (may also affect idle speed).
2. Damaged or restricted fuel tank venting system.
3. Inlet system air leak.
4. Vacuum piston malfunction.
5. Accelerator pump leaking or no output.
6. Plugged bowl vent.
7. Fuel level in bowl too low.
8. Restricted fuel supply passages.
9. Plugged jets or passages.
10. Worn or damaged needle or needle jet.
12. The enricher valve not seated or leaking.
For more information about your issue please visit the websites below. Good luck and have a nice day.
DOWNLOAD 2004 Aprilia Rs 50
Nov 19, 2013 | 2004 Aprilia RS 50
How to remove starter motor aprilia rs50 2001
Hi, Anonymous I am sorry you can't find the first and best tool you ever bought for your Aprilia but despair not for a mere $10 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
DOWNLOAD 2001 Aprilia Rs 50
Nov 17, 2013 | Aprilia Motorcycles
My aprillia rs50 wont start or go into second gear
Hi, Tsykes26 for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix/test or parts inquiry. If necessary transport your vehicle to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day. https://www.tradebit.com/filesharing.php/search/0/aprillia+rs50
Mar 02, 2013 | 2008 Aprilia RS 125
Aprilia rs50 slowing down when in fith gear
are your breaks binding, have you got a centre stand, can you spin the wheels freely#
Feb 14, 2013 | Aprilia Motorcycles
My aprila rs50 starts fine and runs fine cold but if it heats up abit you pull the throttle and it sounds like its dieng
Instructions
    • 1 Park your RSV 1000R on a well-ventilated, level area, using its kickstand.
    • 2 Start the engine and let it idle in place until the temperature gauge built into the instrument cluster indicates a minimum internal temperature of 180 degrees Fahrenheit. This is the motorcycle's ideal operating temperature.
    • 3 Take note of the engine idle speed, using the tachometer needle, while the engine is running. Ideally, the engine should idle steadily at 1,250 rpm.
    • 4 Adjust the engine idle speed to 1,250 rpm, using the idle adjuster screw hidden between the lower right edge of the fuel tank and the upper edge of the right middle fairing panel. Turn the idle adjuster screw clockwise to increase the engine idle speed, or counterclockwise to decrease the engine idle speed, using a small flat screwdriver if your RSV 1000R's frame (VIN number) precedes ZD4MEE009YS000292. A plastic knob allows the engine idle speed to adjusted by hand on RSV 1000R models with a frame (VIN) numbers starting from ZD4MEE009YS000293.
    • 5 Rev the engine two to three times and observe the tachometer. The engine should return to a 1,250 rpm idle. Adjust the engine idle speed as needed, using the method described, then rev the engine again. Problems may exist within the throttle control, fuel-injection system or engine, if the engine idle speed will not hold steady at 1,250 rpm. Contact your local Aprilia service facility for assistance.
    • 6 Stop the engine, once you have obtained a steady 1,250 rpm idle speed.
Jan 17, 2013 | Aprilia Motorcycles
My aprilia rs50 has something wrong with it i rebuilt the engine and put a new carburettor but it is starting it seems it`s not getting petrol to the sparkplug i think it is of timing but don`t know how to...
Hi, Annejamie787 I am sorry you can't find the first and best tool you ever bought for your Aprilia but despair not for a mere $10 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
DOWNLOAD Aprilia Rs 50
Mar 05, 2011 | Aprilia AF1 125 Sintesi Motorcycles
My RS50 won't rev out?
Hi, Fraser_lewin and the usual suspects are:
1. Severely drained or faulty battery.
2. Faulty regulator/rectifier or high output coil.
3. Faulty power valve, solenoid or installation.
4. Clogged air filter or exhaust.
5. Cracked or incorrect float level.
6. Float needle is not seating.
7. Faulty reed valve.
For more information about your question please visit the website below. Good luck and have a nice day.
Feb 23, 2010 | 2002 Aprilia RS 125
Loss of power - 2002 Injected Aprilia RS50 Scooter
is fuel filter in with fuel pump please
Mar 28, 2009 | 2002 Aprilia RS 125
MotoBatt 2000 aprilia rs50 cc battery Logo
42 people viewed this question
Top MotoBatt Electronics - Others Experts
Bill Boyd
steve forbes
Are you a MotoBatt Electronics - Other Expert? Answer questions, earn points and help others
