How to resset TK1 on a sharp mx-2700 colour copier
SOURCE: Help
Sorry bubbabear 64, you are wrong you need to reset the copier with sim 14, once you have cleared the jam, there is no sensor in the fuser so often if the paper gets crumpled in there is doesnt trigger and sensors so the customer trys to copy again and again, seen it many times.
John Sharp Tech
Posted on Jul 22, 2008
  • 117 Answers
SOURCE: add user codes to a sharp mx-4501n mpf
Try exploring the device's web management interface.
Use your wenb browser to connect to the device's IP address.
the default credentials for the unit are user: admin pasword: admin
if that does not work, try password: Sharp (note that the S is capital and the rest are lower case)
Posted on May 07, 2009
  • 120 Answers
SOURCE: hello i have copier machine sharp mx-450u,with
As a general rule, U machines are not designed to be turned into network printers, that's what the MX-M450N is for. You can put an MX-NBX3 on it, it might work properly and it might not.
The NBX3 can only function properly with a hard drive in the copier, otherwise you're outta luck!!
Your driver type may be wrong. If you are currently using PCL6, try PCL5e.
Other than that, try getting a new driver from the Business Copiers section of sharpusa.com. You may have to see which model will work for you. Look for the PCL driver for MX-NBX3, then look for MX-M450U, then MX-M450N.
Posted on Jul 09, 2009
  • 33 Answers
SOURCE: i have sharp mx 2700 .mechine is working but no
Most likely the back light is blown out....try shining a flashlight down on to the displat and you might be able to see the display but this will reqire a qualified tech to repair
Posted on Jul 20, 2010
  • 19 Answers
SOURCE: I just received a new sharp mx-m260 copier and now
which model do you have. you have listed two different models in you post mx2300 is color MX260 is b/w.
Anyway the mm9 is a memory module for fax not a fax kit. The fax kit is a Fxx7 I think
Posted on Aug 18, 2010
I have a sharp 2700 copier with code H5-01
HI
H5-01 means you have had five consecutive jams, it would suggest there is either something blocking the paper path, or the paper is not being picked up at all.
Try resetting the machine by the following:
Program, *, clear, *
It will then ask for a simulation code, enter 14 and press print, are you sure?, press yes. Clear all, clear all, should reboot the machine and try again.
If it continues to jam, try a different cassette.
Cheers
Andy
Apr 23, 2015 | Sharp MX-2700N Color Copier
Sharp mx-2300/2700 e7-06 error
control board error might want a tech come out mite re-flash the copier firm ware, worse case replace control board.
Jul 02, 2014 | Sharp Office Equipment & Supplies
UNABLE TO PRINT TO COLOUR
If your machine has to have codes entered in, this blog entry may help you out.
Setup and Manage User Codes Account Control on Sharp Copier
Jun 11, 2014 | Sharp MX-2610N Color Copier: MX2610N...
Maintenance require code vc
The VC code on a sharp mx-2700 is the cyan developer has reached its maintenance cycle of 60,000 copies. to clear this code enter sim mode #, *, C, * then 24-5 to clear dv count.
Jan 28, 2014 | Sharp MX-2700N Color Copier
Maintenance TK1
TK1 Primary transfer unit counter has reached preset value or number.
To correct error, replace primary transfer belt/rollers. Enter calibration/diagnostic mode and reset counter.
Jan 15, 2014 | Sharp Mx-2310u Color Copy/print/scan
I have a MX - 3500N colour sharp copier. Magenta colour is completely missing whenever i photocopy.
How many ink cartridges does it have [ 1 black & 1 color ]
OR 1 black & 3 color ?
Aug 10, 2013 | Office Equipment & Supplies
WE NEED TO CHANGE THE DEVELOPER IN OUR SHARP MX 5001N COLOR COPIER
The developer change is quite easy, have you ever done anything like this before?
Is it just black or colours as well?
Jul 12, 2011 | Sharp Office Equipment & Supplies
I have sharp mx 2700 .mechine is working but no display in the screen.i can make a copy .no display in lcd screen
Mar 22, 2010 | Sharp MX-2300N Color Copier
107 people viewed this question
k24674
jasbo
jasbo
