Question about Canon ES400V Camcorder
Canon V400 - playback too fast
Hi, I just purchased old stock, but new, Canon V400 to enable me to play and hopefully save a bunch of Video 8's I had, survived tsunami. I put in the first tape, great, have picture and sound, but it is running too fast. The camera does not appear to have the choice of SP or LP. I presume it is run on SP mode as standard, and the tapes have been recorded in LP. Any help would be much appreciated!
3 Suggested Answers
jerryg50
  • 1689 Answers
SOURCE: Switched back and forth between SP and LP in playback
The control track on the tape is not being sensed properly, or there may be a fault in the capston circuit, or capston drive.
There are a number of issues that can cause this:
This can be a dirt film on the control track head, or the main video drum heads, or warn head surfaces. It may also be an alignment problem due to warn parts. The electronics that read and process the control track, or video synchronization processing may have a fault.
The first thing you can do as a user is to clean the tape path. It is safest and usualy works well to use a cleaning tape for your camera type. Follow the instructions for the cleaning tape. The cleaning tape has a surface on it that is supposed to clean the head surfaces without causing a disturbance. Usualy the time required is about 5 to 10 seconds, depending on the model of the camera and the type of tape format.
Read the instructions that comes with the cleaning tape. It is not recomended to re-wind and re-use this tape.
Past this point, the camera will have to be serviced.
Jerry G.
Posted on May 02, 2008
welcomejee
  • 10594 Answers
SOURCE: LP/SP mode
Seems your Canon doesn't support LP mode playback. Please see its user manual and check its specifications for LP mode playback.
Posted on Aug 17, 2008
Playback 8mm camcorder tape fuzzy
8 mm and the newer super 8 mm video tapes are different. You can't use super 8 mm in old player. And old tapes won't play well in new super 8 mm players. Like Sony!
Nov 04, 2013 | Video Cameras
Blaupunkt camcorder video 8 no picture on playback
Your heads are still dirty, You need to hold a piece of white photocopy paper against the heads and rub it to clean the dirt off. Don't use anything soft as it catches on the head and can cause damage.
Mar 09, 2012 | Video Cameras
How long is my Trio supposed to play? I'm only getting 4 hours on a full charge.
As per the company specifications it should provide up to 8 Hours of Continuous Playback. I'd suggest that you set the light out time at 10 seconds keep power saving mode and reduce the brightness. Also dont play at full volume.
This will help you to increase the playback time. Though not up to 8 hours. Make sure not to overcharge the battery.
Also the video playback time is 3-4 hours. As you have not specified whether you are reffering to audio or video playback time, so I am assuming its audio playback time. If its video or mixed then your player is ok..
Hope this helps..
Mar 18, 2011 | Mach Speed Trio Portable MP3 Player
I have a really old Canovision8, E40, 8mm camcorder that doesn't work anymore. What's the best solution to convert the tapes to DVD or to the computer?
You need Hi-8 camcorder/ Hi-8 player to playback your old Video-8 tapes, hook that camcorder/ player with DVD Recorder, play video-8 tapes and burn DVDs directly.
Dec 27, 2009 | Canon ES400V Camcorder
Sony Hi-8 plays new recorded video buy not playback
Are they PAL or NTSC tapes ? They may not be compatible with your new equipment.
Jun 13, 2017 | Sony Handycam CCD-TRV40 Camcorder
I have a canon SD 580. When I playback the video clip it's always in fast forward mode and I can't play it normal speed. Any help?
Make sure you are shooting your movies in "Standard" mode. If you have the mode set to something else, especially "Time Lapse", the playback may not match 'natural' motion.
In any case, you can control the speed of the playback. When you first enter the movie playback mode, there should be a movie control bar along the bottom of the LCD. Instead of the "Play" button, select the "Slow Motion Playback" button (single arrow with single bar next to the normal Play button), and control the speed with the left or right arrows on the multi-controller.
May 02, 2008 | Cameras
Problems with playback of HI8 tapes...
What's happening is that the tape in the cassette is being chewed on one side by the camera's tape transporting mechanism during playback, hence the distorted image and sound. The mechanism might be damaged (misalignment) or just dirty. Try not to play other tapes on this unit because they will become permanently damaged. The best way is to find another camcorder (if cleaning does not help). Note that some old cassettes of long recording time will exhibit this behavior more often because of thinner tape used.
Dec 06, 2007 | Video Cameras
Camcorder won't playback most Hi8 tapes
may be your camera not design to play the analog tape...there are some model that can playback a analog tape...i think your camera is for digital playback only.... check your user manual
Aug 11, 2007 | Sony DCR-TRV285E Digital-8 Digital...
Canon ES400V Camcorder Logo
209 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
