Question about Kodak i40 Path-Through Scanner
Error 5 Can anyone help me by solving a problem with the kodak I40 scanner. Just got it new, but everytime when try to scan some forms, within a few seconds an error appears (E 5). The power on turns into red after a few blinks. Disconnecting the cables and switching it off and on doesn't work. After switching it off and on, the power on turns green again, but no chance to scan any forms at all. Thanks in advance
  • freak_magnet Sep 15, 2008
    i also had an error E8 on my Kodak i40 scanner. What does this means? How will I solve it? the unit was working until i encounter this problem. no effect even turning on and off with the scanner.
In kodak i40 scanner error no. 7 is created i am not solved this problem . please help me & give intruction to me for solve this problem thanks & regards santosh patil pune
Posted on Oct 06, 2007
  • 432 Answers
I can't seem to find a error code 5. What software are you using to scan? Did the error start right after your first? Had the scanner been working?
Posted on Jul 12, 2007
Kodak i40 scanner error 8 message but lamps are fine, worked OK last week, any suggestions
Check you have the latest firmware , the old version can cause this on startup especially when cold
Oct 10, 2011 | Kodak i40 Path-Through Scanner
Kodak i40 error e7
E6 means the scanner cover is open .
Please check for any open covers or any movable parts which is not closed.
Feb 26, 2010 | Kodak i40 Path-Through Scanner
Error 8 in scanner i40
Error 8 = Face up light check failure.
Check Top Lamp is lighting up and not Flickering.
Check connections to Ballast (Inverter) and Lamp.
Jun 30, 2009 | Kodak i40 Path-Through Scanner
Check kds.log -this is my massage error when i press scan option at canner kodak i 260 "check KDS log" messge error appears when scan option chosen on i40 Kodak Scanner.
Try Calibration routine. If it fails check optics are clean and not scratched. If it still fails change the lamps.The KDS.log is encrypted and can only be accessed via a license key. This is only Available to Kodak reps or through RTS ltd service calls.
WWW.Responsets.co.uk.
Mar 25, 2009 | Kodak i40 Path-Through Scanner
Kodak i40 Scanner - paper jamming
First clean with a damp cloth, then try Isopropyl Alcohol. Dont use solvents. Check if papers are sticky. Stapled papers are 'sticky' even after removing staples. loosen them if required. Notmally rollers last 200,000 to 250,000 scans
S. Mohan, Chennai, India
Mar 17, 2009 | Kodak i40 Path-Through Scanner
Scanning problem
May be you have selected multipage option. Then all the pages will be part of the same file, you can view them in 'Windows picture & Fax viwer' You need to page down to see the images. Scan only the first page and check the file size. If this file size and the earlier one are different, then it confirms that you have chosen multipage option!
Aug 26, 2008 | Kodak i40 Path-Through Scanner
Kodak i40 Front loading scan
Try downloading the latest Firmware for the Kodak i40 Scanner at the following Kodak.com page: http://graphics.kodak.com/docimaging/US/en/Products/Document_Scanners/Desktop/i40_Scanner/Support/Drivers_And_Downloads/i30_and_i40_Scanner_Firmware/index.htm
Follow the instructions carefully, and make sure that the scanner and the PC DO NOT turn off while doing the Firmware update. I recomend connecting both to a UPS with a known good battery while doing this upgrade.
This should install the latest features including the one that enables front feed.
Otaron
Jun 02, 2008 | Kodak i40 Path-Through Scanner
Acrobat 8.1
Upgrade to Acobat 9.0 Pro. It seems to work in that can scan pages for a document, HOWEVER, adding/appending to already scaned pages for a document seems to crash 9.0. For example, say I scan in pages 1 - 4. I cannot then scan pages 5 -6 as part of the same document--crashes Acrobat.
I think this finally proves the problem is Acrobat 8.0 and NOT the i40 drivers.
Apr 28, 2008 | Kodak i40 Path-Through Scanner
Problem for kodak scanner
Face down lamp error, check lamp/ballast connections.
If its still a problem replace the lamp.
Oct 06, 2007 | Kodak i40 Path-Through Scanner
Kodak i40 Path-Through Scanner Logo
807 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Clive
Clive
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
