Question about Whirlpool Calypso GVW9959K Top Load Washer
Calypso washer won't drain
Washer won't drain. ld shows on display. also leaking some water
    New Friend:
  • 4 Answers
It sounds like you may have something stuck in the pump...try and locate the pump(normaly at the bottom of machine)and unscrew the cover...be aware that the machine may still have water in it....once you unscrew the cover,have a look and a feel inside...there may be a coin or other object stoppint the pump from turning...remove any foreighn object...replace the screw on cover and try to drain the water again....this should solve your problem.
Posted on Jan 17, 2013
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
My whirlpool calypso won't drain after I removed the rug particles wrapped around the drain pump fan. Showing LD code
You will need to replace the pump. Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 14, 2012 | Washing Machines
We are getting ld error code, also machine motor dosen't seem to be running when we try another cycle
Ld flashes when the water level does not change after the drain
pump is on.
➔ Is the drain hose clogged?
➔ Is the drain hose height greater than 96′?
➔ Is the pump running?
TECH SHEET
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 17, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Washer stops when Ld comes up on display before final spin, but washer drains fine.
ld flashes if it takes longer than 5 min to pump out water to the point where the operating pressure switch resets.check the drain line for kinks,check drain for blockage,check pump operation.
Jan 19, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Won't fillCalypso whirlpool washer model#GVW9959KQ1 LD on display
LD is long drain error, the machine does not fill because it is in fault mode, but error is on drain system.
If there is a drain problem, the parts that must be checked are drain hose, pressure switch, drain pump assembly, timer control.
Check if the drain hose at the back is kinked or blocked.
Test the pressure switch, blow into the small hose, and use a multimeter to check if switch has continuity.
Remove access panel and get to the drain pump hose to check for ablockage. You will need to disconnect the hose and collect the water.
Keep a container ready to collect water when you undo pump hose.
Ifall the rest is OK, test and eventually replace timer board.Problemwith water pump are far more commonly causing this problemsthenfaulty timer board.
Parts and diagrams available here.
Oct 13, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
We have a Kenmore Elite Calypso, it is not washing
"Ld" (Long Drain) flashes
Is the drain hose kinked or clogged?
Press STOP/CANCEL to clear the display.
• "CA" or "Cl" (Current Limit)
Is the washer overloaded?
Here is a manual:
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0102048.pdf
See page 17.
Sep 15, 2009 | Washing Machines
Calypso washer - LD Code - clothes still wet
harborstuff,
The code on your machine stands for 'Long Drain'. Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. I would bet that the bath mats left a bunch of stuff stuck in the recirculation pump hose, or pump itself, and the water cannot be drained fast enough. Check the intake and exit hoses of the recirc pump. It's easiest to get to the pump through the front panel of the machine(click here). Looks like this: click here. Hope this helps.
(Definitely get under there and check to make sure the pump hoses are not clogged. At $129 it's an expensive fix for a $10 bath mat that clogged up the hose with fuzz. 'know what I'm sayin'' :o) )
-samson39
BTW, I have the maintenance manual & have experience at replacing the recirc. pump, control board, motor board, touchpad, & lid switch so far.
Jul 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washer won't empty water....
Ld Long drain "Ld" flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Mar 18, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Display on my Whirlpool Calypso washer shows LD I checked but there is no water coming out of the hose. checked line ok.
"LD" flashes implies the drain hose is kinked or clogged. Check the line as well as the line it feeds into for a clog and make sure it is free to drain then if OK, Press STOP/CANCEL to clear the display. Hope this helps...
Aug 13, 2008 | Whirlpool Washing Machines
What does ld mean?
ld mean long, drain. the machine was unable to drain out water in a given amount of time, calypso is imfamous for collecting lint in the pump assy, id open that up and have a look
May 02, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
46 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
