Question about Uniden Cordless Phone
Motorola c6 problems
Is just flashing base 1 and wont work
My uniden DSS7855 with 1 base station and 3 handsets wont connect when i dial a number and hit the talk button it tries to connect and then comes up "'out of range" much appreciated for any help...
Clear the Handset's Base Data
  1. To remove the base data from a handset when out of range of the base, press and hold the 'end' button and the '#' button simultaneously until the phone beeps.
  2. It will now be de-registered from the base.
Note: This requires that the base and handset can communicate with each other.
Clear the Base Handset Data
  1. To de-register all handsets from the base, remove power to the base, and remove the handset from the base.
  2. Press and hold the 'flash/find hs' button while applying power.
  3. Wait for the beep and release the button.
  4. The charge light will now flash.
  5. Sit any handset in the cradle.
  6. When the flashing stops, re-register the handsets to the base.
Re-Register a Handset to the Base
1. Remove Handset Battery.
2. Reconnect battery while holding down "*" and "#" key.
3. Then press the right upper key under the LCD.
4. Press the "End" key.
5. Wait a few seconds and then the phone will be ready to register to the base.
Nov 12, 2010 | Uniden Lands Phones
We have a eircom 6010 siemens phone and it is constantly falshing base 1 and wont allow us to make or recieve a call on the handset
I have and eircom siemens phone and it is also constantly flashing base 1 and wont allow us to make or receive a call
Debbie
Jan 20, 2010 | Lands Phones
Uniden DSS7855+1, flashing ''welcome! please wait...'', wont work
This is not a direct solution to your problem, but a workaround for a similar situation. I have two headsets and two charging stations. One of the headsets was stuck with the message ''Welcome! please wait''. When I put the phone on the charging station it usually sits on nothing would happen, but when I put it on the other station the phone came back to life. The non-working charging station will still charge the phone so it is worth keeping.
Mar 04, 2009 | Uniden Lands Phones
Not registered
hello there i think this is because you need to register the second handset with the base here are the instructions
REGISTRATION
Registration links the base to a cordless handset. Once a handset is
registered it can use the base’s phone connection. A cordless handset will
not operate until it is registered to the base. During the registration
process, keep the handset near the base.
1. Press the flash/program button on the base until LINK HANDSET shows
in the display. 2NO is the default setting.
2. Press the 1 number key or press the MESSAGES/CID (or) button
on the base to scroll to 1YES.
3. Press flash/program to confirm handset is linked to the base. WAITING
HANDSET REGISTRATION shows in the display.
4. Press the flash/program button on the handset until LINK BASE? shows
5. Press 1 on the handset keypad or cid/vol (or) button on the
handset to scroll to 1YES.confirmation tone when the handset is successfully linked to the base.
6. Press flash/program on the handset again to confirm. You will hear a long
please leave rating if you find this usefull hope this helps thanx for using fixya!!
Jan 26, 2009 | GE 27958GE1 Cordless Phone
Both phones are flashing base 1 with no ring tone on a bt studio 1500
Hi
Had the same problem with my BT Studio 1500 phones both flashing "BASE 1" . Again could not find solution on web! BUT phoned the free BT helpline on 08001456789.
They told me to switch off electricity supply to the base unit then switch it back on.
(The fault is due to the base unit losing the signal and just needs to be "rebooted")
Hey IT WORKS!!!!!
Don't buy a new set of phones!!!!!
Groucho
Jul 14, 2008 | Lands Phones
Problem Siemens Gigaset 4000 and 4200
If you had a storm, and the only handset that works shows line in use, then your base has gone bad and needs repair. The reason the phones are flashing base 1 or something to that effect is because they don't see the base anymore, which typically means no phones will see your base, so its odd that one phone is actually seeing the base. Either way, you can try re-registering the phones to the base, but if you get the line in use after they register (if they will register), then your base is bad. If they won't register, your base is bad. For additional assistance you can go to www.cordlessrepair.com
Jun 15, 2008 | Lands Phones
Phones will not register
Try this:
Pick a handheld, press Menu - H/set settings - Reg Handset - Select Base 1, enter 0000 as password. Now on the bottom of the base station press and hold the Register button in for about 10 seconds or until the h/set beeps.
Geno
Jan 15, 2008 | Siemens Gigaset 4215 Cordless Phone
Uniden Cordless Phone Logo
75 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
