Question about Dell Inspiron 1501 Notebook
Battery Problems w/Dell Inspiron 1501
Since last month, everytime I turn on my laptop I get this message: "This battery cannot be identified. This system will be unable to charge this battery. Press F2 two times to enter Setup. Press F12 and any key to enter boot menu." My battery life has decreased tremendously and the computer will shut off after about 15 minutes w/out the use of the adapter.
I tried calling Dell for help, but since my warranty is up they are pretty much useless. I want to know if there is anything that I can do to help my battery before I spend close to $200 for a new one. I tried pressing F2 and F12 like the message said, but I am not really computer savy so I did not know what to do once the menus popped up! Please let me know if there is a way to troubleshoot my battery. Thanks!!
  • 3 more comments
  • tedious123 Feb 05, 2009
    I had the same exact problem but unfortunately my battery does not charge at all so I cannot use my laptop anymore. Don't wait too long to get a new one or else you REALLY won't have a battery life.
  • Anonymous Feb 06, 2009
    battery problem with dell inspiron 1501
  • Anonymous Mar 08, 2009
    Same problem, system cannot recoginize battery on boot and warranty just expired.
  • jessne19 Mar 21, 2009
    Thanks for the suggestions. To "tinosb", after you reinstalled the Operating Systems cd, and then reflashed BIOS, does your battery work fine now? I know you said the message does not pop up, but how is your battery life?
    Also, what does reflashing the BIOS mean? I don't exactly know how to do this.
    Thanks!
  • delaluna Mar 28, 2009
    I am with tedious... I waited too long and no longer have a laptop i can use
The BIOS flash was EASY (not scary like I thought it would be) and the problems disappeared immediately. Whew! I was worried about flashing the BIOS, but like I said, it was simple. Thanks for the advice, folks.
Don in Tucson
The Virus Slayer
Posted on Jan 03, 2010
I had the same problem. When: "This battery cannot be identified. This system will be unable to charge this battery. Press F2 two times to enter Setup. Press F12 and any key to enter boot menu." appeared. I realy didn't know what it means. So by reinstaling Operation System I also tried to reflash BIOS. After reflashing BIOS that message disappeard, so i don't need to press anything while booting.
Posted on Mar 21, 2009
  • tinosb Mar 21, 2009
    I start from the end. The utility for reflashing BIOS can be found on dell website under Drivers and Downloads. Find your laptop and in results go to Bios. It is actualy BIOS update.
    After the message appeard, batery began losing capacity very fast. That is cost of incorrect charging.
    Now Power meter says 25-30 min of batery life after fully charged. But I can run my laptop another 45 min over that time. So in total it is 1h15min. Hopefully calibration will help to increase batery life. Problem is, I didn't find any calibration tool for INSPIRON 1501 so I just dry my batery to the end. I know, it is realy hard solution, but it's only way how to find out what is going on.
    I do think if I vould reflashed BIOS earlier, I could save batery even more.
    I hope it can help someone to avoid similar problems as I had. And maybe save some many neded for new batery.
    Thanks.
    I start from the end. The utility used for reflashing BIOS I downloaded from Dell website. It is actually BIOS update. Go at Dell web and choice Drivers and Downloads. Find your model and there you’ll find the BIOS update.
    Now battery. After the mentioned message appeared, battery life began falling down rapidly. That was caused because of incorrect charging. System was not able to recognize and charge battery as it should be. Unfortunately I didn’t find an original calibrating utility. So I solved it by completely discharging battery. I changed option in Power Options Properties, to avoid computer turn into Stand By mode. I was nice surprised when my laptop could run 45min on top. Even after OS had showed 0% of battery. I know it is a strange solution. But it works. Before it, system said only 25-30min. After 2 complete cycles of discharging it says over 1hour which is nice success.
    I did it to late, so I lost much of battery life. But I hope it will be helpful to save many needed to buy new battery.
    Thanks
  • 31 Answers
There may be an option in the bios (press F2) once there you have to use your arrow keys to move around, look for a tools option and see if there is a calibrate battery option. if not, I'm sorry to say but there is no other choice, you will have to get a new one, and in a years time, this will probably happen again. some laptop batteries just have a poor design. you can prolong battery life by removing it when you know it is going to be bligged in and in use for a long time, completely drain the battery every 30-60 days then give it a full charge (12-20 hours of charging with the laptop being used).
Posted on Jan 25, 2009
    Problem Solver:
  • 10 Answers
Hi Friends,
Problem with Dell Laptops?
For solutions for your problem you need to visit a site by just Click Here .
For any hardware problem with Dell Laptop you can Click Here
Posted on Jul 23, 2010
My dell inspiron 1501 will charge the battery but as soon as i unplug the laptop turns off.
It's either the battery or charging circuit on the system board. If you have replaced the battery with a new one then it's probably the system board. A new system board could run between $150 to $300. Then there's the coat of labor.
Feb 17, 2013 | Dell Inspiron 1501 Notebook
I am using a Dell Laptop and it is inspiron 1501. But its battery is not charging. I get 2 error message the adapter can not recognise... The battery can not recogise.. Something like that. The laptop gets...
try to remove the battery from the computer, after unplugging it, plug in the AC adapter without the battery and check if it will turn on. if it doesnt then 2 possible reason
1. the AC adapter is busted, you can try a known good Dell AC adapter. if its still now working with a know good AC adapter then
2. its the motherboard that needs to be replaced.
Hope this help
May 19, 2010 | Dell Inspiron 1501 Notebook
I just put a replacement battery on my Inspiron 710M. On startup I get a message that says, "The battery cannot be identified. This system will be unable to charge batteries until this battery is removed."...
This battery is not compatible with this laptop. Dell batterys have a sensor that tells to laptop is it dell battery or not. Unfortunately you have to replace battery with correct one.
Aug 02, 2009 | Dell Inspiron 1501 Notebook
Dell inspiron 1501 work fine turn off last night now wont turn on
You mentioned trying a different battery, try a different AC adapter.
When plugging in the ac adapter to the wall, see if the POWER LED comes on on the adapter, then when you connect it to the computer, see if the LED stays on.
If the issue occurs with both AC adapters (No battery installed) then the motherboard has failed. If one ac adapter works but the other doesn't then the adapter is bad
Feb 01, 2009 | Dell Inspiron 1501 Notebook
Battery cannot be identified Every time I boot up my Dell Inspiron 1501 I get the following message: "Warning: The Battery cannot be identified. This system will be unable to charge this battery."...
Generally this is an indication that the battery has failed. The normal life span of a PC battery is 300 to 500 recharge cycles (Roughly 12 to 18 months) so the most likely answer is buy a new battery since this one is already out of warranty
Jan 27, 2009 | Dell Inspiron 1501 Notebook
Cannot identify Battery
When I turn on my Dell Inspiron 1501 laptop, I get this:
Warning: the battery cannot be identified.
Press Any Key to Continue.
Press <F2> 2 times to enter SETUP.
Press <F12> and Any Key to enter Boot Menu.
what should i do?
Jan 06, 2009 | Dell Inspiron 1501 Notebook
Replacement battery for Dell Inspiron 1501 won't charge
If your old battery was doing the same (not charging), then is is because the charger is not charging the battery. Do you have a friend with a Dell laptop? Maybe you can use a borrowed charger to test and see if it will charge the batteries. To answer your question , no Dell does not have anything built in to prevent you from using a 3rd party battery.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 28, 2008 | Dell Inspiron 1501 Notebook
Laptop wont turn on
I have fixed these before if your a/c adapter has a light and that light is on then you have a busted dc jack which can be expensive to fix. Email me @ texantothebones@yahoo.com if u need more info
May 28, 2008 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 Notebook Logo
5,236 people viewed this question
Alun Cox
