Question about Acer Computers & Internet
Windows 7 failed to start. - Acer Computers & Internet
    New Friend:
  • 101 Answers
This can be a number of issues.
1. Is it happening all of the time?
1a. It could be a bad windows install
1b. It could be your hard drive is going out / has gone out.
1c. It could be an update installed incorrectly.
1d. It could be malware.
That are a few things that could cause a windows failed start.
Posted on Jan 17, 2013
0xc000000e windows failed to start no windows installation disc
Fixing Error 0XC000000E manually is a difficult process and it is not recommend unless you are an expert in this field. mostly all of the fixes you need a installation disk. you may have to, take it to a qualified person for this problem. unless you can get a windows installation disk. and do a complete reboot of windows 7. Good-Day!
Jul 06, 2014 | Samsung Np-qx411-w02ub Core I5-2450m...
What's the solution for the long black background with crusader on startup windows 7 ?
Click Start and type msconfig into the search bar->load msconfig->go to startup->untick all the unnecessary tasks.
Next try updating your graphics driver, use driver booster from majorgeeks if you're not sure how.
If this doesn't work use IObit Advanced system care to clean your system.
Failing that, reinstall windows and start again.
failing that get a SSD drive or new harddrive compatible for your system
Jun 21, 2014 | Computers & Internet
I have a Toshiba satellite L755-s5153 when I turn it on it says "windows failed to start. A recent hardware or software change might be the cause. to fix the problem:" but I don't have the original disk...
Starting Windows 7 in Safe Mode is an excellent next step when starting Windows normally is not possible. Safe Mode only starts the most important Windows 7 processes so, depending on the problem you're having, you might be able to troubleshoot or even fix the problem from here.
To begin entering Windows 7 Safe Mode, turn on or restart your PC.
Just before the Windows 7 splash screen shown above appears, press the F8 key to enterAdvanced Boot Options.
Next you can restore your system from a previous known working date from your restore function. If you are using Windows 7 you may follow these step to restore.
1. Start
2. Go to "All Programs"
3. Select "Accessories"
4. Select "System Tools"
5. Select "System Restore"
Do hope this helps.
Oct 16, 2013 | Toshiba L755-S5153 15.6" Laptop
Windows 7 on my laptop
Try to Start PC in The Safe Mode by Pressing F8 Continuously,Before the Windows 7 Boot Up Screen Appears,
then Select Last Known Good Configuration and press Enter,
that should Save ur laptop,
if the Problem Persists,Try to Boot on Safe Mode,if that also Fails,try to repair ur OS files using Windows 7 DVD.
May 12, 2013 | Computers & Internet
Windows 7 pc wont install windows updates after they have automatically downloaded
1. Did you try using Ms Fix it?
2. When did this issue start to happen?
3. The issue started happening on and what did you do: install something like software or a game.
Mar 15, 2013 | Microsoft Windows 7 Home Premium 64BIT...
I press start on laptop, windows 7 will not load up, i have to press F8 a few times to load ,windows 7
Try a cold start, unplug, remove battery, hold down on/off button for 10 seconds, replace battery, plugin, push on/off button, try to start normally. If that fails do a system resotre/ recovery.
Nov 04, 2012 | HP Computers & Internet
Need Webcam Drivers
Was the computer connected to the Internet with a LAN cable when you installed Windows 7. During the Windows 7 installation Windows will automatically find and download the drivers.
The HP/Compaq WEB site may have a WEBcam driver for your model laptop.
If all else fails then try installing Windows 7 again and make sure the laptop is connected to the Internet before you start the installation.
Jun 17, 2012 | Computers & Internet
This application has failed to start because d3d10.dll was not found. and error 8003002: could not start application sky orb. the requested render path could not be loaded.
Download DirectX 10 and install. SkyORB 3D
  • Operating Systems: Windows Vista, Windows 7
  • Requirements: 29.6MB hard drive space to download, 52.3MB installed; DirectX 10 required (Windows Vista or 7 only); updated graphics drivers recommended
  • Dec 31, 2010 | realtech VR SkyORB 2010
    Computers & Internet Logo
    29 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Alun Cox
