Question about Home
Warm water in shower and cold in sink
I have luke warm water in shower and cold water on hot in the sink/ some rooms i can have warm water in the sink then i can turn shower on and the sink water gets hot ????any ideas before i go crazy????
    New Friend:
  • 169 Answers
How long has this been like this? Have you replaced any faucets, or have you installed a new water heater recently?
Posted on Jan 22, 2013
Blessedbygod
  • 85 Answers
SOURCE: Shower water temperature regulation
The temperature is adjustable. The valve has a disc you pull off the front of valve and then rotate the seat I believe counter-clockwise. If you get the paperwork for this valve from moen it is very explanatory. I can help further if needed, Let me know!
Posted on Nov 11, 2009
Magaiver
  • 707 Answers
SOURCE: Valve will not mix enough hot water with
Their is a mixer valve if it is a one handle unit which is built in. It may be one half turn out of timing.
Posted on Aug 10, 2010
  • 4348 Answers
SOURCE: When turning on the hot water on dedicated hot
Pull apart the front of the valve and there is a limiter that is set to limit hte hot water, you need to adjust that limiter. I find many valves are shipped with teh setting too cold.
Posted on Oct 09, 2010
  • 1015 Answers
SOURCE: I have a one handle Delta shower knob. I have
On your single handle the first thing you do is remove the handle. To do this locate allen set screw on handle and select the right size allen wrench to fit it. Loosen set screw and pull handle out away from wall to remove it. There should be a plastic disc on the handle stem, slid it out to remove it.Remove chrome sleeve..On valve body there are marking that show hot or cold settings. Seperate teeth on geared flanges and rotate set stop toward h mark on valve body. Each tooth will change temperature about three degrees. Make trial setting and reassemble and try it out. If you want it hotter just repeat adjustments. If you try to go to far you will not be able to mesh gears,simply back off alittle bit and try again.Hope this helps you. Thanks
Posted on Nov 22, 2010
  • 100 Answers
SOURCE: I am not getting any
I'm not familiar with the Ace Hardware shower faucets, but I do know that this problem is caused by a fault in the cartridge. Replacing the cartridge is a simple procedure. First goto Ace (in this case) and see if you can get a new cartridge. You will have to shutoff the main water shutoff to perform this.
Your handle should have a pop out cap in the front facing you. You need to pry this out.
Then, you should see a philips screw in the center. Unscrew this.(Some handles also have a small hex screw on one of the sides of the handle. Look for this)
Again, I'm not familiar with Ace's shower faucets, but at this point, normally you'll see a stem which is part of the cartridge. You will need to remove this (usually with a wrench-lefty loosy) and swap out that part. Put everything back together and you should be fine.
(The reason this problem usually happens is that there is a safety tab (on the cartridge) set by the previous installer to not let the "user" go beyond a certain temperature as to not scald themselves. If this tab has shifted, worn, or broken, this problem can arise.)
Hope this helps!
Posted on Dec 03, 2010
My oil fired hot water heater provides only sporadic hot water. For example, when I am home alone it takes 2 minutes to get luke warm water in the shower, then it is only warm for a few minutes, then...
It sounds like your thermostat on the water heater isn't working properly. try turning it up higher and if this doesn't work I would have a service techy look at it.
Mar 24, 2011 | Water Heaters
SINGLE VALVE SHOWER FAUCET TURN ON TO GET HOT WATER ONLY GETTING WARM WATER LUKE THE OTHER TUB AND SINK FAUCET COME OUT HOT HELP PLEASE
I can think of a few possibilities. 1) Something is blocking the hot water in to the mixing valve. Fixing this would probably mean cutting out the valve (then redoing the water lines with a new valve (possible option)).
2) The hot water line is losing too much heat going to this second faucet. (If the two tubs are on different floors this is more common. Many places are plumbed with one line with Ts to all fixtures.) Insulating the water lines might help; alternatively an point of use water heater would help.
3) The hot water and the cold water in are reversed. (Test by leaving the water on full cold and full hot for a few minutes each.) If you get full hot when it should be cold, valves with a cartridge are easy to fix. Open the valve assembly, remove the cartridge and reinsert it after turning it around (side closest to you when you removed it goes in first). Otherwise, the incoming plumbing needs to be redone at the point where the cold and hot lines come into the shower.
I hope this helps.
Dec 15, 2010 | Price Pfister Home
I have a Grohe shower system that has the temperature control it was working fine and now the water only comes out luke warm. the handle goes from 65 degrees to 110 degrees. I live in a older highrise...
WEll, the question is do your sinks have water that is hot enough? If no, perhaps your water heater is set too low. If yes, many shower controls have hot limiter and if you pull the handle, often there is a spline assembly that stops the travel from going hot, adjust to allow more.
Dec 13, 2010 | Grohe Home
When turning on the hot water on dedicated hot water faucets, the water is almost scalding. However, when turning on the shower and tub that has only one faucet handle (mixes cold and hot) and put the...
Oct 09, 2010 | Delta & Single Handle Shower Faucet
Cold water is leaking on to hot side causing luke warm water
i have a 7570 salora that took the top off and i can't get it back together right
Feb 19, 2010 | Moen 7065 Vestige Single-Handle Kitchen...
Nov 10, 2009 | Moen & One Handle Tub & Shower Faucet
The water coming out of my faucets, washing machine, shower, etc. is not getting hot.
Your heater is on? Do you regularly drain off sediment?
Have you contunity tested your elements (power off)? Volt tested the same (power on)?
Has anyone fooled with the thermostat?
There is the possibility the dip tube (cold water going in) has broken off and instead of sending the cold water to the bottom, the cold goes straight from the cold water entrance pipe to the hot water exit pipe. Normally, one would expect cold water to sink and hot water to be on the top but, when you are drawing water off the top, with a broken dip tube, the water travels the shortest distance required, thus, your luke warm water.
I hope you can find your trouble by following one of these hints.
Thanks
a
Oct 18, 2009 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
Have a combi boiler and the hot water from my taps are running cold to luke warm. My British Gas engineer has told me it is nothing to do with the boiler but is caused by a faulty thermostat cartridge in...
Modern shower valves have an "anti scald device" in them to prevent scalding from to hot water.
They come preset at 120 degrees.
Sometimes they can start to malfunction and all you get is warm, not hot water, they can also be intermittent.
This will only effect the shower valve though, not the other faucets.
Dec 06, 2008 | Heating & Cooling
Home Logo
79 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
