Question about Whirlpool Duet GHW9150P Front Load Washer
Want to know the proper length of the drain hose from washer to drain. I can shorten it to about 6" if need be
  • Scott Thornton Dec 06, 2013
    the pipe must be higher than the water level or a siphon effect will occur.
    President:
  • Whirlpool Master
  • 662 Answers
You cannot shorten it to 6 inches. The pipe must go up from the bottom exit up to nearly the height of the washer then down anywhere to drain pipe in wall or washbasin. But the drain hose must go first up and then down - important.
You can give me 4 thumbs, if helped that is.
Posted on Mar 28, 2013
2 Suggested Answers
marka19
  • 1430 Answers
SOURCE: Getting an error code: 6 . . . F . . . 6 . . . F.
You can enter your model # here for diagrams and illustrations http://appliancehelponline.com/frontloadwasher.html Also check the page for videos and tutorials that should help.
Posted on Jun 07, 2010
My Inglis washer also gets stuck on rinse
If you have ever experienced the problem where you washer continually fills but never reaches the proper level (not an overflow). Or, the wash tub water level cannot be maintained, because the water level keeps dropping. You may be experiencing what is known as "siphoning". This occurs when there is no air gap for the drain line at the standpipe. The standpipe is the drain pipe at the wall where the washer drain line is placed. With no air gap, a vacuum is created, and water will begin to drain from the wash tub prematurely. To prevent this from occurring, follow this advice:
* The standpipe should be 2 inches in diameter to allow a sufficient air gap between the top of the standpipe and the drain hose.
* The standpipe should be a minimum of 34" from the floor, and should not exceed 72 inches in height.
* DO NOT seal the top of the standpipe. Many consumers seal the standpipe in the belief that this will prevent overflows, or get rid of drain odors. This often creates more problems than solutions.
* DO NOT place the drain hose too far down into the pipe. Water stays in the drain trap area of the standpipe. If the end of the drain hose rests in this area, no air gap is created, and this can also cause siphoning. 4 to 6 inches is sufficient.
* The drain hose length must not exceed 10 feet in length. Excessive drain hose length can cause drain problems and back wash.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 06, 2009 | Kenmore 24032\24036 Top Load Washer
Tip
How to Prevent Washer Siphoning
If you have ever experienced the problem where you washer continually fills but never reaches the proper level (not an overflow). Or, the wash tub water level cannot be maintained, because the water level keeps dropping. You may be experiencing what is known as “siphoning”. This occurs when there is no air gap for the drain line at the standpipe. The standpipe is the drain pipe at the wall where the washer drain line is placed. With no air gap, a vacuum is created, and water will begin to drain from the wash tub prematurely. To prevent this from occurring, follow this advice:
  • The standpipe should be 2 inches in diameter to allow a sufficient air gap between the top of the standpipe and the drain hose.
  • The standpipe should be a minimum of 34” from the floor, and should not exceed 72 inches in height.
  • DO NOT seal the top of the standpipe. Many consumers seal the standpipe in the belief that this will prevent overflows, or get rid of drain odors. This often creates more problems than solutions.
  • DO NOT place the drain hose too far down into the pipe. Water stays in the drain trap area of the standpipe. If the end of the drain hose rests in this area, no air gap is created, and this can also cause siphoning. 4 to 6 inches is sufficient.
  • The drain hose length must not exceed 10 feet in length. Excessive drain hose length can cause drain problems and back wash.
I hope these tips are informative and will help prevent some of the more common washer drain problems that can easily be mistaken for a more serious problem. You can save yourself a service call, just by double checking your installation.
on Dec 04, 2009 | Washing Machines
Tip
on May 12, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
All of the water filling my kenmore washer is flooding out bottom
Jun 15, 2009 | Kenmore HE2 Plus Front Load Washer
Washer is filling up to wash but water goes out of tub before
Mar 16, 2009 | Washing Machines
Want to know how much water my model 44092 washer should use.
Mar 15, 2009 | Kenmore Energy Star 44092 Front Load...
Kenmore washer 23801-loses water during wash/rinse cycle before cycle completes
* The standpipe should be a minimum of 34” from the floor, and should not exceed 72 inches in height.
Mar 12, 2009 | Kenmore Washing Machines
Hot water comes, but does not fill the Washer, and therefore does not rotate the tumbler. It is a Maytag commercial washer
Jan 28, 2009 | Washing Machines
My washer doesn't wash.
Jan 26, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
257 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
