Question about Vehicle Parts & Accessories
20 feet of valet remote start
Why does my remote start only work from about 20 feet
  • 43 Answers
Alarm "antenna" mounted to low in car,BEST when mounted as high in car as possible
Posted on Jan 19, 2013
Is there another way to program a remote start remote, The way its suppose to work doesnt.:door open, ACC on, push valet then again and hold. I think the door is not hooked up to read open.
563T Your Valet Alarm W/Remote Car Starter - Dr.Detail
www.drdetailshop.com > MAIN > YOUR VALET
Featuring: Viper, Hornet, Directed Amps, Viper Audio, Compx Subs, Your Valet ... 563TYour Valet Alarm With Remote ... A Free Wiring diagram, Installation parts
Sep 24, 2015 | Televison & Video
I had a avital remote start pot on a 2004 chevy venture van. everything worked ok for a month then the remote locks, poer windows and dome lights quit working. are they all connected together for the...
Avital is one brand of remote starter that features easy-to-use keyless remotes. These remotes can be programmed wirelessly to your engine and then added to your keychain. Once programmed, you will be able to use the remote from as far as a couple hundred feet away in your house, the street or a parking lot. If your remote is not working, you can troubleshoot the remote and get it resynced in seconds.
  • Enter your caricon1.png, leave your driver's door open and insert your key into the ignition.
  • 2 Turn the ignition to the "On" position and press and release the "Valet" button on your remote.
  • Press and hold the "Valet" switch again after releasing the first time and wait for the system's siren to chirp and the LED lighticon1.png to blink.
  • 4 Continue holding the "Valet" button and then press the starter button on your remote.
  • 5 Wait for another chirp and release both buttons to complete the process.
  • Apr 08, 2014 | Cars & Trucks
    How to program a remote control viper 5900 for a chevy Tahoe
    Should be a switch for overriding the alarm under the drivers side dash. Two wires going to it (grey black) with a push button on the end if it. Have the driver door open and turn the ignition to on not running,,,, push the valet button and let go and then push and hold valet button........ Hit lock on the transmitter one time while still holding the valet button down. You should get a chirp for entering program and then when you lock on the remote it will make another chirp. But the chirp will sound awkward. Let go of valet and and turn truck off. And test remote. If that's doesn't work you may need to follow all the same steps but instead if press once and press and hold you will need to push 8 times and hold on the 9th and hit lock on the remote. I'm pretty sure the it's sequence is for alarm security and 8 steps is for remote start only models. Food for though if my mind is working backwards. Best off luck. All else fails I'm sure a shop will do for about 20$
    Oct 28, 2013 | 5900 SST 2-Way Security System / Remote...
    Somehow buttons seem to have been pressed on my remote and now there are 3 "z"'s that have appeared on the remote and I have no idea how to get rid of it. My remote now doesn't make a...
    Turn ignition on, hold the red valet switch down for 2 seconds. Then turn ignition off. Your system is in VALET mode.
    The remote start and alarm system will not work when in valet.
    Aug 06, 2011 | C3RS727LCD 4Channel Alarm with Remote Car...
    I have a Valet 562T remote start in my Ford F250. It will start like it should off remote but only run for about 15 to 20 seconds. It worked correctly untill I had a new oil pan installed. Garage...
    You need to relearn the tachometer signal. Actually they probably did not hook up the tack wire when they put the new engine in. The tach wire is usually run to the non-common wire on one of the fuel injectors. Hope this helps
    Jan 17, 2011 | Directed Dei Valet 561r Remote...
    What is the valet button and what does it do?
    Valet mode on remote starts is there so that when you have someone working on your vehicle the start button for your remote start won't work. Say you're getting an oil change and for some reason the button is pressed, the vehicle wont start with the technician under it and no oil in the engine. In your owners manual it will tell you how to turn Valet mode on and also how to turn it off.
    Dec 06, 2010 | 5303P LCD 2Way Security System with Remote...
    Have had a Dei valet 561r remote on my Honda van for several years. Worked flawlessly. Recently, it began working intermittantly. Did not work for several days. Then worked for about a week. Then nothing....
    sounds like your car battery was also replace or it die
    believe it or not the remote start needs to be reprogram again
    find the valet switch, this what you are going to do
    make sure ac radio and any other accesorie are off
    start the car with the key within 2 seconds or less press and hold the valet swith, and way until the
    led turns on and the parking lights on the vehicle flash about 12 seconds
    no turn off the car close the door and start the vehicle with the remote good luck
    Nov 19, 2010 | Directed Dei Valet 561r Remote...
    Valet 712T keyless entry works inside vehicle only!
    Two suggestions one even if its a new battery change it ,secondly if your new car has metalised window tinting on it and your old car did;nt this can be the reason also ,if so move the antenna to the front screen which won;t have tinting.
    Apr 05, 2009 | Valet 3-Channel Keyless Entry System 712T
    Vehicle Parts & Accessories Logo
    19 people viewed this question
    Top Vehicle Parts & Accessories Experts
    Thomas Perkins
    Thomas Perkins
    Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
