Question about Pantech Pocket
Wifi will not connect - Pantech Pocket
    New Friend:
The below info is from user manual ... downloadable version @ www.pantech.com
Connectivity
This chapter introduces useful tips on how to connect to the
network available that enables applications of the phone to
run.
Using a Wi-Fi network
Connecting to a Wi-Fi network
1. Tap Settings from the applications menu.
2. Tap Wireless & networks > Wi-Fi settings.
3. Tap Wi-Fi to activate the technology.
4. Select and tap a network. You should enter the password
if the network is secured. indicates a secured Wi-Fi
network.
5. Tap Connect. Once the network is remembered, the phone
will automatically connect to it when in range.
Activating Wi-FI Connecting to a Wi-Fi
network
Note The icon next to each network indicates the strength of the
signal. For example, indicates the signal is poor while indicates
the signal is strong.
Using the Easy Setting
1. Tap on the top of the home screen and drag it down, or
press n in idle mode and tap Notifications.
2. Tap in Easy Setting. The icon turns red when the
function is on.
About network notifications
You are informed by default when a Wi-Fi network is available
around you. The message in the status bar indicates a
network is available. Tap Network notification in the Wi-Fi
settings if you do not want to be informed the availability of the
network.
Setting Wi-Fi networks
4. Tap Network notification if you want to know an open
network available.
5. Tap Automatic connection if you want the phone to
connect to Wi-Fi network automatically.
6. Tap WPS button connection if you want to establish a
new wireless connection using the Wi-Fi Protected Setup
(WPS). You should press WPS button on your Wi-Fi access
point within two minutes.
Searching for Wi-Fi networks
Posted on Feb 19, 2013
How do I stop continually trying to connect to wifi and failing
Unable to Connect to wifi problem - Solved for me ' Apple Support ...
discussions.apple.com > Support > Apple Support Communities
Apple Inc.Jun 7, 2012 - I tried the "forget the connection" workaround but it always came back. ... recognizing and joining the wireless network, but are not connecting ... Ipad won't connect to wifi after update iOS 7.0.6
Mar 1, 2014
New iPhone 5s - constant "Incorrect WiFi" password
Nov 25, 2013
Wifi ISP keeps failing
Sep 10, 2013
New Macbook Air - wifi connectivity problems
Jun 13, 2013
More results from discussions.apple.com
How to fix limited or no connectivity Wi-Fi issues in Windows 8
www.fixedbyvonnie.com/.../how-to-fix-limited-or-no-connectivity-wi-fi...
The connection is limited ... He couldn't connect to Wi-fi on battery power. ..... Will this work if we have limited connectivity when trying to connect through a LAN cable? .... I found another solution, If you are running Windows 8 and your laptop keepsdropping the WiFi .... Investigate router or access point issues Failed
Dec 28, 2015 | Tablets & eReaders
I can't connect to wifi and when I can I can't setup my gmail account or any other apps I have try everything I know
I'll give you some help on ANDROID. Go to apps, settings\ WiFi. Turn it on at top of screen. Any available WiFi accounts will show up. Then go to top right push the three dots, click advanced and make your choices. Click back to WiFi screen and click the WiFi you want to connect with, enter the key that your WiFi needs to connect, or use the WPS option if available on you WiFi. If the WiFi has WPS, push the button on the WiFi and connect your tablet or phone by pressing connect.
Nov 29, 2015 | Tablets & eReaders
Apple wifi connection problems
go to internet connect in preferences, make sure airport is in range of wifi, check to see if other devices are able to connect to your wifi, check settings for your wifi.
Feb 21, 2014 | Apple iMac Computers & Internet
No wifi
"Problem with Cradlepoint CBR450 Compact Broadband Router without WiFI"
it does not support WIFI will need to get one that does support WIFI to connect that way.
Feb 03, 2014 | Cradlepoint CBR450 Compact Broadband...
Ds won't connect to wifi nintendo24 won't for the wii won't connect to the wifi
you need to get wifi at your house before you can use the wifi on the ds
Mar 24, 2013 | Video Game Consoles & Games
How to connect to wifi?
Goto your phone connection settings:-
Select -> Wifi -> On.
Search any Wifi Network and Connect..
Feb 26, 2013 | Samsung Omnia Pro B7320 Smartphone
Tethering lg phoenix no connection
Expecting your PC (having no inbuilt/internally installed WiFi adapter) to pick up tethering/hotspot WiFi signal (from your phone) without a WiFi adapter attached/connected into your PC's USB port is the same as expecting your PC's low battery to charge to full capacity when the power cable is not connected to the power supply point.
Get WiFi adapter connected to your PC first and then attempt to connect to your phone's wifi tether/hotspot
Nothing is wrong with your phone please
Oct 12, 2017 | Cell Phones
Edimax BR-6574n wifi VPN connection problem
I have reseted the router configuration back to Factory Default, and set it up again from the beginning. I think the problem was at the firewall settings.
Aug 24, 2009 | Edimax PRI-682 Router (PRI682)
Pantech Pocket Logo
300 people viewed this question
Top Pantech Cell Phones Experts
Abdul Mannan
Abdul Mannan
Jax Planet
Jax Planet
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
