Question about GE WBSR3140DW Top Load Washer
Washer will hum and will not drain water out!
Washer will wash/agitate, but when it reaches the rinse/spin cycle it just hums and will not spin and drain out the water.
  • 112 Answers
You will have to either look under the machine or take the back off.
You will see the big motor which does the washing.
You will also see a small motor which drains the machine.
Disconnect the power supply and remove the pipes from the small motor.
It could be blocked up from congealed washing powder.
Or something may have blocked the pipe from the drum to the drain motor.
If it all looks ok and still doesn`t work, then the motor has siezed.
Very easy to replace
good luck
Posted on Jan 25, 2009
Why won't maytag MVWC6ESW go into rinse cycle?
The cold water valve screen in the washer water valve is clogged. You have grit in your water and it will continue to happen until you get a filter system installed on to it.
Mar 18, 2016 | Maytag MVWC6ESWW Washer
My 5 year old Roper washing machine fills up, washes/agitates the cloths, drains them when the washer get to the rinse line to start the rinse cycle it stops, and all I hear is a humming. The machine will...
I'm not familiar with roper washing machines so I'll ask the question does it have two fill hoses. Most European machines now only have one fill. If it has two then it sound like the machine takes the initial water from the one fill and the rinse cycle water from another. The humming sounds like the valve for the other fill needs replacing. These are quite inexpensive and easy to fit. Power off.. remove lid ....switch of water...take out valve when you establish which one is affected and replace
Oct 17, 2013 | Whirlpool WTW5700S
My Kenmore washer (series 90) stopped working in between the rinse and spin cycles. It will not drain (half full as we speak), agitate or spin. It will fill with water but once it reaches the proper water...
Something stuck in Pump. Pump on your model is driven by washer motor, so if Pump can't turn, motor can't work and will hum until it overheats and shuts down.
Sep 28, 2017 | Washing Machines
Kenmore washer stops spinning a few seconds in to the cycle.
Sounds like the brushes are struggling to get enough power to the motor to spin. Renew motor brushes
Apr 21, 2012 | Kenmore Washing Machines
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
Top load washer won't go through cycle
modle problem here its the main board common fault with this model good luck
Mar 26, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
It wont complete cycle and empty the water just hums for a while and then turns its self off
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Jan 17, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Kicking out water during wash cycle - spin instead of agitation
Try these
  1. Check the drain hose, it should be at least as high as the top of the wash tub, about 38 inches.
  2. The drain hose must sit loosely in the house drain. Do not seal the air gap around the drain hose or a siphon will occur.
  3. Check the drain control lever
  4. Test the drain control coils
  5. Check the cam bar
pls rate my suggestion..
Jul 19, 2009 | Maytag LSE7806A Top Load Stacked...
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Washer does nothing during rinse then leaks during spin cycle
hi thanks for the question i would check the drain hose your problem is the washer is not draining check the drain hose thanks the appliance doc
Sep 27, 2008 | Maytag Atlantis MAV6000 Top Load Washer
GE WBSR3140DW Top Load Washer Logo
281 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
