Question about GE GSL25JFPBS Side by Side Refrigerator
Just replaced mother board on Ge gsl25jfpabs to fix problem with cooling and running constantly. still not cooling but we can hear motor and fan running. no cold air blowing into fridge section. wh
Damper does not seem to be blowing.
    Problem Solver:
  • 15 Answers
NEED TO MAKE SURE FRESH FOOD DOOR IS HITTING LIGHT SWITCH TO OFF POSITION IF NOT NEED TO ADJUST DOOR UP ASSUMING THE FREEZER SIDE IS WORKING OK
Posted on Jan 18, 2013
Krames
  • 18 Answers
SOURCE: Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Posted on Nov 15, 2008
jumptrout51
  • 3361 Answers
SOURCE: the refrigerator section is not cold
Replace the freezer fan motor.
Posted on Feb 21, 2009
SOURCE: ge model gsh25jfrfww not cooling just clicking
Replace the main board on the back i got the part for $130 at a wholesale parts store
Posted on Mar 06, 2009
SolutionGuy
  • 331 Answers
SOURCE: Frost in frostless freezer, fan not blowing into warm fridge
There are 2 things that cause these to not defrost. Kinda like the "Achilles heel" of GE fridges. The first one is the Defrost heater itself. And the second is the evaporator thermister (GE calls it a "sensor"). They are both very easy to replace. The part numbers are; WR51X10101 (heater) and WR55X10025 (sensor). If you don't have a local appliance parts retailer, just plug those numbers into a search engine. I highly recommend getting both parts because if the sensor hasn't failed yet, it will. The same goes for the heater...
Now for the fun stuff... Turn the temp knobs all the way counter clockwise to kill power to the fridge. Unload all the food from the freezer and remove all the shelves and the basket. Remove the screws that are holding the evap panel (the flat panel on the back wall, it's about 2 1/2 ft tall). Remove the panel to expose the evaporator. You'll see the heater at the very bottom of the evap connected by 2 screws, remove these and pull the heater out. Your new heater comes with instructions on how to install it.
After you have done that, look at the top of the evap. On the left, you'll see a little white sensor clipped to one of the evap tubes (shiny little clip), that has 2 wires feeding it. Remember which tube it's clipped to then unclip the sensor and pull it toward you. Snip the wires right at the base of the old sensor and completely remove it (leave the wires in there). Now separate those 2 wires and strip about 3/8" of insulation off. At this point, you are ready to follow the instructions that came with your new "sensor". Oh! and if it's all frosted up on the evap? Take this time (before you re-install the panel) to use a blow dryer and melt it away. All that'll be left to do is rebuild it.
There ya go! Job completion time= ~45 minutes. Easy breezy, right?
If this has been helpful, please don't forget to rate my solution. Thanks!
SG
Posted on Apr 05, 2009
tborn6
  • 700 Answers
SOURCE: GE Model GSH22JFTA Top of Fridg and Freezer not cold
check the door gaskets for air leakage
Posted on May 21, 2009
My GE refrigerator is no longer cooling. Model GSH25JSTC SS. I just replaced the mother board WR55X10942 and it is still not cooling. Water dispenser, fan is working fine.
Is the compressor running? Is it any good? Is the thermostat control working and cycling the compressor on? Is the self defrost mechanism stuck in defrost cycle (shuts down compressor), etc?
Is the motor getting power?
U need to check all of these areas.
Apr 08, 2015 | GE Refrigerators
My ge profile refrigerator evaporator fan motor stops while the compressor is running
this is normal as if one compartment is cold enough but not the other compartment the sealed system has a valve in the refrigerant circulation system to channel the refrigerant flow to the compartment that is calling for cooling so that fan will cease operation in the compartment thats cool enough
Dec 14, 2012 | GE Profile Stainless Bottom-Freezer...
Hi I have a GE model# DSS25KGRE BB fridge. The fridge runs constantly, meaning it cools until the coils get all frosted up. then the defrost heater kicks on and 'thaws' the coils. I have tried
OK, first check the condenser coils and fan to be sure they are free of lint and dirt buildup. Dirty coils will keep the unit from cooling correctly and the unit will run endlessly. Post back the results to me and we will take it from there.
Regards,
Richard Roth
http://appliancecafe.com
Nov 30, 2012 | Refrigerators
I have a ge sbs model pcp23shmffbs. the condenser fan motor is running slow, but turning freely. the fan motor is rated at 11.3 volts dc and supply to fan motor is only 6.7 volts. is the condenser fan...
If the motor is running, but running slowly, you will need to replace the motor. If there was a problem with the PCB, (control board) the motor would not run at all and you would see other problems with the refrigerator.
Here is a link to the motor.
Jan 28, 2011 | GE Refrigerators
GE model gsl25jfpabs, freezer is cool like refrigorator, but won't freeze....
Look for frost on freezer back wall.
dirty condenser, condenser motor not running
bad compressor
Mar 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Compressor & Evap. Fan both work for 12 hours then evap stops
I believe that because defrost is done by the mother control board this is why this is happening the part of the board that controls defrost is malfunctioning and the only way to resolve the problem is to replace the mother board part number WR55X10656 You can find the replacement board at these places below. Sea Breeze
http://appliancepartsse.blogspot.com/
Aug 25, 2009 | GE Refrigerators
Ge refrigerator model PDS20MBSAWW
gee seems to me if your are getting the proper voltage witch you say you are sounds to me like a bad condensor fan motor. is the compressor running, maybe shut off because it was to hot.and you are right the motor voltage is from the board. we have had alot of mother board failures on the ge line. but that would be the problem if you were not getting power to the motor.on some models the power comes from the relay /overload hooked to the compressor. if the compressor doesnt come on and you hear a clicking from it every few minutes then you could have a bad
overload and relay that is mounted to the compressor.if thats all good then id say order another motor.
ALL BRANDS APPLIANCE REPAIR
5008 W. LINEBAUGH AVE #8
TAMPA FL 33624
OFFICE # 813-908-2002
FAX # 813-908-5559
WEBSITE allbrandsappliancerepair.com
EMAIL customerservice@allbrandsappliancerepair.com
Jul 11, 2008 | GE Hotpoint Top-Freezer Refrigerator
Ge frigde
if it is the fan at the compressor not running, the system pressure will rise and cooling will ******, verify 120 volts to the fan motor if you have 120 volts ac replace the condenser fan motor
Apr 06, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Side by side cooling problems
replacing evaporator motor and mother board
Apr 02, 2008 | GE GSH25JFR Side by Side Refrigerator
Noisy air flow problem, I think
the GE refrig has a variable speed fan motor controlled by the mother board located on teh rear of you refrig. the noise your hearing is the fan speed ramping up and down. if this noise is constant its possible the contoller on the mother board is bad and the board needs to be replaced. hope this helps...
Dec 07, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
GE GSL25JFPBS Side by Side Refrigerator Logo
100 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
