Question about Panasonic Room Air Conditioner CWXC104HU
Hi sir inquire or panasonic split air conditioner indoor unit moter part no ARW41H8P30AC,8P 30W DC280-340V
  • 619 Answers
SOURCE: Panasonic CW-17700R Air Conditioner
It depend the area of the room and aircon you use try consult near applianes near you.Ask Panasonic on line .
Posted on Jan 08, 2008
  • 306 Answers
SOURCE: Panasonic air conditioner. Very small
It is okay for water to come out of unit unless if it comes into your living space. Then your angle of the unit is off and needs to be readjusted. lean the unit away don't have it level. Needs small amount of angle for excess condensation to run outside.
Posted on Dec 03, 2008
johnnyboy138
  • 3 Answers
SOURCE: I have fujitsu Air conditioner
you can also check the coil and see it is dirty
Posted on Jan 18, 2009
  • 400 Answers
SOURCE: i hve purchased panasonic split a.c. b4 1 month
Ok, there are a few things to check.
1. Batteries on the remote.
2. Reset remote - switch sometimes in battery compartment and sometimes behind cover, need to press with sharp nib or pen.
3. Check on indoor unit that remote has been selected on the manual/auto switch, located under the cover on right hand side.
4. Remove indoor unit cover complete, (three screws behind the louvers and one on the electrical cover). Change the remote sensor board.
Posted on Mar 10, 2009
  • 340 Answers
SOURCE: I have a problem with my Panasonic CU-80C51HE
low on freon You need service. Tom
Posted on Jun 17, 2009
Panasonic mini split air conditioner css9nkua. what does run code h99 mean?
H99: Indoor heat exchanger anti-freezing protection
Causes: - Insufficient refrigerant;
- Air filter dirty;
- Clogged cross flow fan.
Apr 29, 2015 | Panasonic CS-S9NKUA Ductless Mini Split...
How do i stop the leak on my panasonic air conditioner
You need to blow out the drain hose, it's clogged. You can use a water hose to flush out the line.
Sep 19, 2014 | Panasonic CS-MKE12NKU Mini Split Wall...
Chunlan kfr-700k
Check this link to see if you can find the manual you are looking for here:
http://shop.panasonic.com/shop/model/36PEF1U6?t=specs
Aug 26, 2014 | Panasonic S-36PF1U6 31,200 BTU Mini-Split...
My indoor lg mini split unit the cool light flashes 4 time what's wrong
Indoor unit faults = CH04 or C4
Fascia LED's
- RED = None
- GREEN = 4 Flash
Contents = Drain Pump / Float Switch
Case of Error = Float Switch Open Circuit (High Level Water Alarm)
Indoor Status = Off
clean your condensate drain line you can do this with a shop vac,
Read more: http://dgoma.es/multisplit_lg/lg-multi-split-units-error-code/#ixzz34dr3Cu00
Follow us: dgoma on Facebook
May 26, 2014 | LG LMN127HVT LMN127HVT 12 000 BTU Ductless...
Troubleshoot whining Noise On Panasonic Outdoor Condenser
You will have to post a video to have any diagnostic performed sight unseen.
Aug 22, 2013 | Panasonic CS-S22NKU-1 21,000 BTU Ductless...
E 7
Multi Splits and Multi V = indoor unit is set to run in a different mode from the master indoor unit. Set ALL indoor units to cooling or ALL to heating to clear.
Splits = Compressor Over Current (CT2), Check loose wiring/condenser coil for clean
Jan 10, 2011 | AmcorAire UCHW-H24AF2 Split System Air...
I have problem regarding water tapping in indoor unit of split a.c.
dear sir /madam
please do every week clean your split type a/c,s filter it,s main coz who responsible for block the drain water line and after that split indoor drain ac unit drain water from inside of the unit , try to find out the drain water line of indoor unit of air conditioner the make clean it and also check it i mean keep some fresh water for make test its drain line it have been open or not if water is going easily then ,it,s ok
it,s up tp you if you think you can do it or contact to it,s technician for do solve this problem.
thank you for using fixya for get solution
hope answer the question
please vote!
Jul 07, 2010 | Whirlwind FH-778 Air Conditioner
Panasonic cs-pw9gke i need wiring diagram
Split A/C-Cold:
You need four wires(two #10 and two #12) to the outdoor unit, leaving you house, and three wires(#10) coming from the breaker to tye indoor unit inside your house.
Split A/C-Cold and Hot:
You need five wires(two #10 and three #12) to the outdoor unit, leaving your house, and thee wires(#10) coming from the breaker to your indoor unit inside your house.
This ypical arrangment(all of them use three wires fro the breaker), yet there are other units which may require 6-7 wires connected to the the outdoor unit depends on the added features to the unit.
Regards,
Gulftecheng
Dec 05, 2008 | GE Quiet-Aire Ductless Split System Air...
Mitsubishi Mr. Slim Mini Split MS-A12WA Indoor Unit
no sir gary,
the water would not go to the drain pan if you install it vertically.
water would just drop anywhere and would ruin a lot of things...
tnx 4 using fixya,
drcool
Sep 13, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Air Conditioner unit won't switch on outdoors
can you give us some model numbers and a make? Get both the inside and outdoor unit numbers please. Thanks.
Oct 10, 2007 | GE AJCH10ACB Built-In Room Air Cool Unit
Panasonic Room Air Conditioner CWXC104HU Logo
322 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
